ROS Nodes
This section contains instructions on how to use provided ROS nodes for VOXL.
To play with the ROS nodes, first follow the quickstart guides to setup ROS on host PC and setup ROS on VOXL.
voxl-nodes source code.
Known Issue Running ROS Through SSH
Nodes:
The VOXL Nodes package (voxl-nodes.ipk) is included in the VOXL Software Bundle and includes the following ROS nodes:
