VOXL CPU Monitor
voxl-cpu-monitor checks the current state of the CPU, GPU, and memory including statistics such as clock speeds, usage, and temperatures. This is the “Resource Monitor” for MPA. It publishes data once per second to the cpu_monitor
pipe for other processes to read.
voxl-inspect-cpu
The primary client for this pipe is voxl-inspect-cpu. See its source code for a good example of using this data.
Data Type
cpu_stats_t
voxl-cpu-monitor publishes a cpu_stats_t struct to the pipe as defined in cpu_monitor_interface.h. Note, this struct will become standardized and included in modal_pipe_interfaces.h at some point. For now it’s in the voxl-cpu-monitor package.
typedef struct cpu_stats_t{
uint32_t magic_number; ///< unique 32-bit number used to signal the beginning of a packet
int32_t num_cpu; ///< number of CPU's
float cpu_freq[MAX_CPU]; ///< CPU freq (MHz)
float cpu_t[MAX_CPU]; ///< CPU temperature (C)
float cpu_t_max; ///< max core temp (C)
float cpu_load[MAX_CPU]; ///< CPU load (%)
float cpu_load_10s; ///< CPU load for past 10 seconds (%)
float total_cpu_load; ///< calculate total cpu load (%)
float gpu_freq; ///< GPU freq (MHz)
float gpu_t; ///< GPU temperature (C)
float gpu_load; ///< current gpu load (%)
float gpu_load_10s; ///< gpu load for past 10 seconds (%)
float mem_t; ///< Memory Temperature
uint32_t mem_total_mb; ///< total memory in MB
uint32_t mem_use_mb; ///< used memory in MB
uint32_t flags; ///< flags
uint32_t reserved; ///< spare reserved bytes for future expansion
}__attribute__((packed)) cpu_stats_t;
flags
Several flags can be set in the cpu_stats_t struct to indicate high-level conditions. Most importantly are the flags for CPU_OVERLOAD and CPU_OVERHEAT. The intention is to allow CPU-intensive processes to monitor these flags and pro-actively lower their workload to free up CPU for more flight-critical processes such as VIO.
The CPU will automatically throttle its clock speed back when it gets too hot to protect itself, but it may be advantageous to avoid that scenario all together if possible to keep the CPU at full speed for the benefit of other running processes.
#define CPU_STATS_FLAG_CPU_MODE_AUTO (1<<0) // indicates CPU clock scaling is in Auto mode
#define CPU_STATS_FLAG_CPU_MODE_PERF (1<<1) // indicates CPU clock scaling is in performance mode
#define CPU_STATS_FLAG_GPU_MODE_AUTO (1<<2) // indicates GPU clock scaling is in Auto mode
#define CPU_STATS_FLAG_GPU_MODE_PERF (1<<3) // indicates GPU clock scaling is in performance mode
#define CPU_STATS_FLAG_CPU_OVERLOAD (1<<4) // indicates the total CPU usage is over %80 use
#define CPU_STATS_FLAG_CPU_OVERHEAT (1<<5) // indicates the max CPU core temp is over 90C
Configuration
voxl-cpu-monitor has no configuration file, but in keeping with MPA standards you can use voxl-configure-cpu-monitor
to enable/disable the service. It is enabled by default from the factory and when running voxl-configure-mpa
Source
The code is available on Gitlab
