VOXL-CAM v1 Manual
NOTE: The following documentation is in beta. Any feedback is appreciated.
  1. Hardware Requirements
  2. Get Connected
    1. Connect Micro USB to VOXL CAM
    2. Connect Power Cable to VOXL-CAM
    3. Place in Caddy for Desktop Development
    4. Power On
    5. Find VOXL-CAM Access Point
    6. SSH into VOXL
  3. Viewing Localization Data from Tracking Sensor
  4. Viewing Point Cloud (and Stereo Tracking Images)
    1. Software Requirements
    2. Configuration
    3. SSH into VOXL-CAM
    4. Launch RVIZ on Desktop
  5. Software Setup (only needed if you mess with things)
    1. Setup ADB
    2. Installing Required Packages
    3. Configure Cameras
    4. Enable Core Services
Get Connected
BETA For the beta units, please keep a fan on the back aluminum plate when the device is powered on in a static state to avoid the unit from overheating.
If you intend to use adb later, connect right angled USB cable into the VOXL-CAM as shown shown below and connect the other end of the cable to your host computer. Otherwise continue on and you can connect over WiFi.
VOXL-CAM-USB
Connect the keyed 4-position connector from the VOXL Power Module v3 into the VOXL-CAM as shown below.
VOXL-CAM-Power
When doing desktop development, place in the Caddy:
VOXL-CAM-In-Caddy
Attach to VOXL Power Module to a wall outlet using included power supply with XT60 connector.
Power On
Attach the VOXL Power Module to the power cable as shown below. The fan should turn on automatically
VOXL-CAM-Powered
By default, the VOXL-CAM boots up as a WiFi access point named VOXL-XX:XX:XX:XX:XX (where XX… is the MAC address). Connect to it using password 1234567890.
SSH into VOXL
The VOXL-CAMs default IP address is 192.168.8.1. SSH into VOXL-CAM using the root user with password oelinux123.
voxl-ssh.png.
Note: you can connect VOXL-CAM to your wireless network using the voxl-wifi station <SSID> <Password> command to have allow your host computer to have internet while also connected to VOXL-CAM. You will need to locate the IP address, which is easily done with adb and the USB connection.
The Visual Intertial Odometry (VIO) feature uses the tracking image sensor with fisheye lens and an onboard IMU to provide localization data. At a high level, this provides you a realtime “X, Y, Z” in space.
To use this feature, simply run the following command:
voxl-inspect-qvio
The output displayed updates as you move the VOXL-CAM around in space:
VOXL-CAM-QVIO
You can move VOXL-CAM around and see the data update.
Hit CTRL+c to stop the program
In order to best visualize the point cloud, we will use ROS and rviz to visualize the ToF sensor data.
Configuration
Please ensure you’ve setup ROS on PC
The unit’s software is shipped already configured and ready to use.
Note: If needed, you can follow the Software Setup section below to fully reconfigure the VOXL-CAM.
SSH into VOXL-CAM
If not already done, SSH into VOXL-CAM and change the shell to bash:
ssh root@192.168.8.1
~# bash
yocto:~#
Setup the environment (this assumes VOXL-CAM is in SoftAP with IP Address of 192.168.8.1 which is the default):
yocto:~# source /opt/ros/indigo/setup.bash
yocto:~# source ~/my_ros_env.sh
Run the following command to run the MPA ROS Node:
yocto:~# roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
The exepected output is shown:
... logging to /home/root/.ros/log/790d372a-a45e-11eb-ade8-ec5c68cd1ad7/roslaunch-apq8096-4239.log
Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
started roslaunch server http://192.168.1.188:36869/
SUMMARY
PARAMETERS
 * /mpa/voxl_mpa_to_ros_node/image0_pipe: tracking
 * /mpa/voxl_mpa_to_ros_node/image0_publish: True
 * /mpa/voxl_mpa_to_ros_node/image1_pipe: hires_preview
 * /mpa/voxl_mpa_to_ros_node/image1_publish: True
 * /mpa/voxl_mpa_to_ros_node/image2_pipe: qvio_overlay
 * /mpa/voxl_mpa_to_ros_node/image2_publish: True
 * /mpa/voxl_mpa_to_ros_node/image3_pipe:
 * /mpa/voxl_mpa_to_ros_node/image3_publish: False
 * /mpa/voxl_mpa_to_ros_node/image4_pipe:
 * /mpa/voxl_mpa_to_ros_node/image4_publish: False
 * /mpa/voxl_mpa_to_ros_node/image5_pipe:
 * /mpa/voxl_mpa_to_ros_node/image5_publish: False
 * /mpa/voxl_mpa_to_ros_node/imu0_pipe: imu0
 * /mpa/voxl_mpa_to_ros_node/imu0_publish: True
 * /mpa/voxl_mpa_to_ros_node/imu1_pipe: imu1
 * /mpa/voxl_mpa_to_ros_node/imu1_publish: True
 * /mpa/voxl_mpa_to_ros_node/stereo_pipe: stereo
 * /mpa/voxl_mpa_to_ros_node/stereo_publish: True
 * /mpa/voxl_mpa_to_ros_node/tof_cutoff: 100
 * /mpa/voxl_mpa_to_ros_node/tof_pipe: tof
 * /mpa/voxl_mpa_to_ros_node/tof_publish: True
 * /mpa/voxl_mpa_to_ros_node/vio0_pipe: qvio
 * /mpa/voxl_mpa_to_ros_node/vio0_publish: True
 * /mpa/voxl_mpa_to_ros_node/vio1_pipe:
 * /mpa/voxl_mpa_to_ros_node/vio1_publish: False
 * /rosdistro: indigo
 * /rosversion: 1.11.21
NODES
  /mpa/
ROS_MASTER_URI=http://192.168.1.188:11311/
core service [/rosout] found
process[mpa/voxl_mpa_to_ros_node-1]: started with pid [4257]
Param: "image3_publish" set to false, not publishing associated interface
Param: "image4_publish" set to false, not publishing associated interface
Param: "image5_publish" set to false, not publishing associated interface
Param: "vio1_publish" set to false, not publishing associated interface
MPA to ROS app is now running
Starting Manager Thread with 8 interfaces
Found pipe for interface: tracking, now advertising
Did not find pipe for interface: hires_preview,
    interface will be idle until its pipe appears
Did not find pipe for interface: qvio_overlay,
Found pipe for interface: stereo, now advertising
Found pipe for interface: tof, now advertising
Found pipe for interface: imu0, now advertising
Found pipe for interface: imu1, now advertising
Found pipe for interface: qvio, now advertising
On the host computer, run RVIZ
rviz
To view the Point Cloud from ToF sensor:
  1. On the leftmost column click on the “Add” button
  2. In the pop-up options click on “PointCloud2”
  3. Change Display Name to “tof”
  4. In the left column under “tof” tab select type in Image Topic as /tof/point_cloud
  5. If needed, set the “Global Options” “Fixed Frame” to “map”
  6. If needed, Under the “tof” node, set Style to “Points”
To View the Tracking image sensors:
  2. In the pop-up options click on “Image”
  3. Change Display Name to “tracking” and click “OK”
  4. In the left column, expand the “tracking” node and select type in Image Topic as /tracking/image_raw
To View the Stereo image sensors:
  3. Change Display Name to “stereo_left”
  4. In the left column under “stereo_left” tab select type in Image Topic as /stereo/left/image_raw
  5. On the leftmost column click on the “Add” button
  6. In the pop-up options click on “Image”
  7. Change Display Name to “stereo_right”
  8. In the left column under “stereo_right” tab select type in Image Topic as /stereo/right/image_raw
voxl cam RVIZ
Out of the box, the VOXL-CAM will already be pre-configured to be able to visualize and publish via ROS. In the situation where the device needs to be configured manually, the steps below demonstrate how to do so.
Setup ADB
On the host computer install the Android debug Bridge (ABD):
Make sure the VOXL-CAM is connected via Micro-USB to the host PC. If ADB is set up properly you can check ADB detects your device using adb devices. If a device shows up then you have configured it properly.
me@mylaptop:~$ adb devices
List of devices attached
73a05d48	device
The latest VOXL Platform Release 3.2.0-0.3.4-b or newer is all that is needed, and can be downloaded from here.
This is already installed on units shipped, but if needed, you can follow instructions here to reflash.
Begin by entering the VOXL-CAM’s bash shell from the host computer using adb shell and starting bash.
me@mylaptop:~$ adb shell
/ # bash
yocto:/#
Configure Cameras
yocto:~# voxl-configure-cameras
This should allow you to select different camera configurations. After running the command the following prompt will appear, you’ll select option 7.
Which camera configuration are you using?
0 None
1 Tracking + Stereo
2 Tracking Only
3 Hires + Stereo + Tracking (default)
4 Hires + Tracking
5 TOF + Tracking
6 Hires + TOF + Tracking
7 TOF + Stereo + Tracking
8 Hires Only
9 TOF Only
Again, we have camera configuration 7. Enter 7 into the command line and press enter.
Update the environment for ROS usage:
yocto:~# exec bash
Enable the required services:
yocto:~# systemctl enable voxl-camera-server
yocto:~# systemctl enable voxl-qvio-server
yocto:~# systemctl enable voxl-imu-server
Start the required services:
yocto:~# systemctl start voxl-camera-server
yocto:~# systemctl start voxl-qvio-server
yocto:~# systemctl start voxl-imu-server
Note: You can use voxl-inspect-services from the mpa-tools library to see a list of available services.
You can run any of these servers in an ssh or adb window by typing their executable name, e.g.:
yocto:~# voxl-camera-server
Manually running these will require an open shell window, but will often have the ability to more easily see logged data from the servers.
