Setup ROS on VOXL
ModalAI Top Tip: ROS is not required to use or develop with VOXL! If you don’t like ROS or don’t want to use ROS, then you are done with the VOXL quickstarts! You can look through the more in-depth Developing with VOXL and Flying with VOXL guides.
Set up Envrionment Variables
VOXL ships with ROS Indigo and the voxl-utils package pre-installed. voxl-utils installs the script my_ros_env.sh to /home/root/ which sources the normal /opt/ros/indigo/setup.bash script to configure the ROS environment variables. It also sets the IP address environment variables. Since everyone’s VOXL will be on a different IP address, you will need to edit this script to match the network configuration for your desired ROS master/slave configuration which will be different depending on your use case.
We recommend having the ROS Master be on VOXL. The Master IP is already set up to 192.168.8.1 to match the Soft Access Point use case. If you have your VOXL on a WiFi network you will need to change this address to match your configuration.
# On VOXL, begin by switching to the bash shell (by default, ADB puts you in the sh shell)
/# bash
yocto:/# vi ~/my_ros_env.sh
# IP Environment variables must be set after setup scripts
# Set ROS_IP & ROS_MASTER_URI appropriately for your configuration
# 192.168.8.1 is default for the robot in soft access point mode
export ROS_MASTER_URI=http://localhost:11311/
export ROS_IP=192.168.8.1
unset ROS_HOSTNAME
You can refresh your environment variables after updating this script by running:
yocto:/# exec bash
And then check that they have been updated by using the voxl-env tool or just grep’ing the bash environment variables.
yocto:/# voxl-env show
ROS_IP=192.168.1.150
CAM_CONFIG_ID=1
HIRES_CAM_ID=-1
TRACKING_CAM_ID=0
STEREO_CAM_ID=1
TOF_CAM_ID=-1
yocto:/# env | grep "ROS"
ROS_ROOT=/opt/ros/indigo/share/ros
ROS_PACKAGE_PATH=/home/root/catkin_ws/install/share:/home/root/catkin_ws/install/stacks:/opt/ros/indigo/share:/opt/ros/indigo/stacks
ROSLISP_PACKAGE_DIRECTORIES=
ROS_DISTRO=indigo
ROS_IP=192.168.8.1
ROS_ETC_DIR=/opt/ros/indigo/etc/ros
Both of these methods require you to run inside a bash shell, NOT sh. If you logged in over ADB you are put in an sh shell by default and need to start bash manually.
Testing ROS Configuration
To test that your ROS configuration is working, start roscore on VOXL. Double check you are in a bash prompt and not sh before doing so.
ModalAI Top Tip: Currently an issue can be seen when attempting to use ROS using the native Ubuntu terminal. As a work around XTerm can be used.
# ON VOXL
yocto:/# echo $SHELL
/bin/bash
yocto:/# roscore
process[rosout-1]: started with pid [5706]
Now on your host PC use rostopic to see if it can communicate with VOXL.
# ON HOST PC
me@mylaptop:~$  rostopic list
/rosout
/rosout_agg
Known Issue Running ROS Through SSH
Next Steps
Now explore the ROS Nodes provided in the VOXL Nodes package.
That’s it for the VOXL quick start guides! Next, you can look through the more in-depth Developing with VOXL and Flying with VOXL guides.
