LTE Modem and USB Add-On Board
  1. Overview
  2. Requirements
    1. Hardware
    2. Software
  3. SIM Cards and Supported Networks
  4. Hardware Setup
  5. Software Setup
  6. Connecting to a Ground Control Station
    1. OpenVPN client on VOXL
  7. FCC Restriction on Band 5
  8. Example VOXL OpenVPN client configuration file
The VOXL system provides the ability to easily and quickly add an LTE connection. The following guide provides you the necessary details on doing so.
Requirements
Hardware
In order to connect the VOXL to an LTE network, the VOXL-ACC-LTE accessory kit is required. These can be purchased through here are are available in two options:
Part Number Description
VOXL-ACC-LTEH-DOD Add-on board for VOXL which enables DOD spectrum LTE as well as adds a USB hub to integrate more peripherals
VOXL-ACC-LTEH-NA Add-on board for VOXL which enables North American carrier LTE as well as adds a USB hub to integrate more peripherals CAT4 LTE Bands 2,4,5,12
Modems
Each kit conveniently comes with two LTE antennas (which are also available here)
Software
The following are required which should already be pre-installed:
The modems cards require a Nano SIM.
AT&T, Verizon and T-Mobile are supported. For Band 3 support, the VOXL-ACC-LTEH-DOD modem is required and Band 3 SIM cards need to be requested through ModalAI.
Hardware Setup
  • Remove power and USB from the VOXL main board
  • Insert SIM card into LTE card
  • Connect antennas to the LTE card (note that it takes a little force to attach the U.FL connectors…)
  • Attach LTE card to the VOXL’s J13 connector. 3/8” #2-56 nylon screws and #2-56 nylon nuts can be used with a 5mm nylon spacer between the boards.
    • Note: The switch near the antenna connectors should be in the ‘off’ position. When ‘on’, it will force the main board to into USB boot mode
  • Connect the USB cable to the VOXL main board
  • Connect the power supply, you should see green LEDs like
Modem-1
Software Setup
The VOXL ships with utilities on board to setting up the modem. First, initialize the modem:
voxl-modem --feather_configure
note: on some early shipments you may need to use the following instead:
modalai_modemutil.py --feather_configure
Next, we need to configure the APN. The following shows some sample APNs and how to implement them.
For IoT devices on the AT&T network:
echo "AT+CGDCONT=1,\"IP\",\"m2m.com.attz\",\"0.0.0.0\",0,0,0,0" > /dev/ttyACM0
For laptops and tablets on the AT&T network:
echo "AT+CGDCONT=1,\"IP\",\"broadband\",\"0.0.0.0\",0,0,0,0" > /dev/ttyACM0
For Smartphones on the AT&T network:
echo "AT+CGDCONT=1,\"IP\",\"phone\",\"0.0.0.0\",0,0,0,0" > /dev/ttyACM0
For LTE devices on the T-Mobile network:
echo "AT+CGDCONT=1,\"IP\",\"fast.t-mobile.com\",\"0.0.0.0\",0,0,0,0" > /dev/ttyACM0
NOTE: Use only one APN depending on your carrier and plan.
After issuing the last command, you can check for an OK response using the following:
cat /dev/ttyACM0
(CTRL+C)
Reboot the device to finish configuration.
shutdown -r now
After rebooting, connect via ADB again and then connect to the network using the following command:
voxl-modem --connect_to_network
modalai_modemutil.py --connect_to_network
If successful, you should see the WWAN status LED illuminate. This indicates that the modem has successfully registered with the network. You will also see a new network interface rmnet_usb0:
/ # ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:48 errors:0 dropped:0 overruns:0 frame:0
          TX packets:48 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:3504 (3.4 KiB)  TX bytes:3504 (3.4 KiB)
rmnet_usb0 Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:10.39.193.86  Mask:255.255.255.252
          UP RUNNING  MTU:2000  Metric:1
          RX packets:2 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:612 (612.0 B)  TX bytes:1112 (1.0 KiB)
wlan0     Link encap:Ethernet  HWaddr 48:5F:99:9D:55:DF
          inet addr:192.168.8.1  Bcast:192.168.8.255  Mask:255.255.255.0
          inet6 addr: fe80::4a5f:99ff:fe9d:55df/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3000
          RX bytes:0 (0.0 B)  TX bytes:858 (858.0 B)
Modem-3
A typical use case of an LTE connection is to connect the drone with a Ground Control Station (GCS) such as QGroundControl. Typically the GCS is also connected to an LTE network. In this case both the drone and the GCS have been assigned IP addresses on the LTE network that are private to the carrier network. This prevents the drone from directly connecting to the GCS since their IP addresses are not visible to each other over the Internet. There are a variety of ways of solving this issue. ModalAI uses a VPN as the preferred solution.
LTE data flow
This diagram shows how the VPN solution works. In this example a server is allocated with static IP address 35.236.55.229. You can easily set your own server up with Google Cloud Platform, Amazon Web Services, Microsoft Azure, etc. Ubuntu is a nice choice of OS for your server. Our VPN is setup using the OpenVPN software package which is nicely documented.
In the example, once the drone has connected to the AT&T network it obtains address 10.47.x.y and the GCS, once connected, obtains the address 10.47.x.z. With the OpenVPN server software running on the cloud server, OpenVPN client software on both the drone and the GCS computer can now connect and get a VPN IP address assignment. In this diagram the drone is assigned 10.8.0.6 and the GCS computer is assigned 10.8.0.8. The drone can now communicate directly to the GCS computer using the 10.8.0.8 address.
It is desirable for the drone and the GCS to always get the same IP address when connecting to the VPN. This is possible by assigning each separate network endpoint a unique security certificate. When each endpoint connects using it’s certificate it can be configured to receive the same address every time. This is explained in more detail in the OpenVPN documentation.
The base VOXL software image already has OpenVPN installed. To use it you need to supply a configuration file and the certificates / keys for your VPN. These files can be placed in the directory /etc/openvpn. Here is a example of running OpenVPN as a daemon:
cd /etc/openvpn
openvpn --daemon --script-security 2 --config target-client.conf
Note that the connection will fail unless the date and time have been correctly set. This is required due to the dates embedded in the certificates.
The default version of OpenVPN on VOXL is 2.1.3. Newer versions are available and compile nicely on target. Here is an example of setting up version 2.4.6:
git clone https://github.com/OpenVPN/openvpn
cd openvpn
git checkout tags/v2.4.6
autoreconf -i -v -f
./configure --disable-lzo --disable-plugin-auth-pam --prefix=/usr/local
make -j4
make install
An example client configuration file is attached to the end of this user manual.
When using cellular communications on any flying platform the use of band 5 is strictly prohibited by the FCC. In order to abide by this restriction the modem must be configured to use LTE only and then configured to use all available LTE bands supported by the hardware except for band 5. ModalAI provides an application called “configband” to configure this properly. The configband application takes a bitmask as one of its arguments. The bitmask represents the allowable LTE bands. For the WNC North American modem, which supports bands 2, 4, 5, and 12, the bitmask would be 0x80a (100000001010b) to only enable bands 2, 4, and 12. Here is an example of setting up the modem to disable band 5 and then connecting to the network:
uqmi -P -d /dev/qcqmi0 --set-network-preference lte
configband write /dev/ttyUSB0 0x80a
# Sample client-side OpenVPN 2.0 config file #
# for connecting to multi-client server.     #
# This configuration can be used by multiple #
# clients, however each client should have   #
# its own cert and key files.                #
# On Windows, you might want to rename this  #
# file so it has a .ovpn extension           #
# Specify that we are a client and that we
# will be pulling certain config file directives
# from the server.
client
# Use the same setting as you are using on
# the server.
# On most systems, the VPN will not function
# unless you partially or fully disable
# the firewall for the TUN/TAP interface.
;dev tap
dev tun
# Windows needs the TAP-Win32 adapter name
# from the Network Connections panel
# if you have more than one.  On XP SP2,
# you may need to disable the firewall
# for the TAP adapter.
;dev-node MyTap
# Are we connecting to a TCP or
# UDP server?  Use the same setting as
# on the server.
;proto tcp
proto udp
# The hostname/IP and port of the server.
# You can have multiple remote entries
# to load balance between the servers.
remote <Your server name or IP here> 1194
;remote my-server-2 1194
# Choose a random host from the remote
# list for load-balancing.  Otherwise
# try hosts in the order specified.
;remote-random
# Keep trying indefinitely to resolve the
# host name of the OpenVPN server.  Very useful
# on machines which are not permanently connected
# to the internet such as laptops.
resolv-retry infinite
# Most clients don't need to bind to
# a specific local port number.
nobind
# Downgrade privileges after initialization (non-Windows only)
user nobody
group nobody
# Try to preserve some state across restarts.
persist-key
persist-tun
# If you are connecting through an
# HTTP proxy to reach the actual OpenVPN
# server, put the proxy server/IP and
# port number here.  See the man page
# if your proxy server requires
# authentication.
;http-proxy-retry # retry on connection failures
;http-proxy [proxy server] [proxy port #]
# Wireless networks often produce a lot
# of duplicate packets.  Set this flag
# to silence duplicate packet warnings.
;mute-replay-warnings
# SSL/TLS parms.
# See the server config file for more
# description.  It's best to use
# a separate .crt/.key file pair
# for each client.  A single ca
# file can be used for all clients.
ca ca.crt
cert example.crt
key example.key
# Verify server certificate by checking that the
# certicate has the correct key usage set.
# This is an important precaution to protect against
# a potential attack discussed here:
#  http://openvpn.net/howto.html#mitm
# To use this feature, you will need to generate
# your server certificates with the keyUsage set to
#   digitalSignature, keyEncipherment
# and the extendedKeyUsage to
#   serverAuth
# EasyRSA can do this for you.
remote-cert-tls server
# If a tls-auth key is used on the server
# then every client must also have the key.
;tls-auth ta.key 1
# Select a cryptographic cipher.
# If the cipher option is used on the server
# then you must also specify it here.
# Note that v2.4 client/server will automatically
# negotiate AES-256-GCM in TLS mode.
# See also the ncp-cipher option in the manpage
;cipher AES-256-CBC
# Enable compression on the VPN link.
# Don't enable this unless it is also
# enabled in the server config file.
#comp-lzo
# Set log file verbosity.
verb 3
# Silence repeating messages
;mute 20
keepalive 10 120
tun-mtu 1300
mssfix 1260
writepid /run/tun.pid
askpass passphrase.txt
