Install voxl-docker
- Prerequisite: Install Docker CE
- Install the voxl-emulator Docker Image
- (OPTIONAL) Install the voxl-hexagon Docker Image
- Use of voxl-docker Script
The following instructions are for installing docker and the two aforementioned Docker Images in an Ubuntu Desktop Environment. These instructions are tested on Ubuntu 18.04 Bionic but should work on other Ubuntu version supported by Docker.
1) Official instructions are here:
https://docs.docker.com/install/linux/docker-ce/ubuntu/
However, they are summarized at time of writing as follows. we can’t gurantee these commands are current whereas the above link should be current.
# install instructions from https://docs.docker.com/install/linux/docker-ce/ubuntu/
sudo apt remove docker docker-engine docker.io containerd runc
sudo apt update
sudo apt install -y apt-transport-https ca-certificates curl gnupg-agent software-properties-common
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
sudo apt-key fingerprint 0EBFCD88
sudo add-apt-repository -y \
"deb [arch=amd64] https://download.docker.com/linux/ubuntu \
$(lsb_release -cs) \
stable"
sudo apt-get update
sudo apt install -y docker-ce docker-ce-cli containerd.io
2) Add current user to docker group to allow usage of docker commands without root privileges. You will need to restart your OS after running this command for the group permissions to be applied.
sudo usermod -a -G docker $USER
sudo reboot
4) Download archived docker image from ModalAI Developer portal (login required): * VOXL Emulator Docker Image (1.0.0)
5) Move archive into this directory alongside install-emulator-docker.sh and this README.md
6) Run configuration script to load docker image from archive and install the voxl-docker.sh script to /usr/local/bin so the docker image can be started from within other project directories.
./install-emulator-docker.sh
7) Test that the image was properly installed.
~/git/voxl-docker$ voxl-docker -l | grep "voxl"
voxl-emulator latest 0e15518b8f95 11 months ago 1.26GB
If you wish to build programs for the Hexagon SDSP, you will need the Hexagon SDK from Qualcomm. To make this easier we provide the voxl-hexagon docker image which uses Hexagon SDK V3.1
8) Download and place the following files into cross_toolchain/downloads
Hexagon SDK 3.1 install file: qualcomm_hexagon_sdk_3_1_eval.bin
- https://developer.qualcomm.com/download/hexagon/hexagon-sdk-v3-1-linux.bin
Linaro ARM compiler binaries: gcc-linaro-4.9-2014.11-x86_64_arm-linux-gnueabi.tar.xz
- https://releases.linaro.org/archive/14.11/components/toolchain/binaries/arm-linux-gnueabi
9) Run the install-hexagon-docker.sh script. This will also install voxl-docker.sh to usr/bin/ as did install-emulator-docker.sh in case the user wants the hexagon docker only.
./install-hexagon-docker.sh
10) Confirm the install worked
voxl-hexagon latest 6b7bb00b90d0 2 minutes ago 5.21GB
$ voxl-docker -h
Usage: voxl-docker [ARGUMENTS]
By default this runs the voxl-emulator image for compiling ARM apps-proc code
for VOXL. It can also run the voxl-hexagon docker image for cross-compiling
hexagon SDSP programs. Technically this can also launch any other installed
docker image with the -i argument but is only intended for the voxl-emulator
and voxl-hexagon images.
By default this mounts the current working directory as the home directory
inside the docker for easy compilation of whichever project you are currently
working in. The directory that gets mounted inside the docker can be manually
specified with the -d argument.
The voxl-hexagon image starts with the username "user" with UID and GID 1000
which should match the first user on your desktop to avoid permissions issues.
The voxl-emulator image start, by default, with the same username, UID, and GID
inside the docker as the user that launched it.
Since the voxl-emulator image is designed to emulate the userspace environment
that runs onboard the VOXL itself, you may wish to run as the root user inside
the voxl-emulator docker image to test certain behaviors as the root user.
This more closely mimics the on-target environment as the VOXL image runs as
root by default. Enter this mode with the -p option.
You can also specify the entrypoint for the docker image launch. By default this
is set to /bin/bash but can be user-configured with the -e option. This is most
likely used to pass the docker a command to execute before exiting automatically.
For example, to build the librc_math project in one command:
~/git/librc_math$ voxl-docker -e "/bin/bash build.sh"
ARGUMENTS:
-h: : Print this help message
-d <name>: The name of the directory to mount as ~/ inside the docker
-i <name>: Docker image to run, usually voxl-emulator or voxl-hexagon
-p : for voxl-emulator image ONLY, runs as root user inside docker
-l : list installed docker images
-e : set the entrypoint for the docker image launch
$ voxl-docker -l
REPOSITORY TAG IMAGE ID CREATED SIZE
voxl-hexagon latest 637d89d3a530 19 minutes ago 5.28GB
voxl-emulator latest 0e15518b8f95 1 months ago 1.26GB
