Cable Datasheets
Datasheets for ModalAI's range of cables.
ModalAI has various cables used by its systems. Below captures the cables by part number and provides pinouts and other relevant information. The Cable User Guide page has information on finding the right cable for your system and how to make your own cables with specific examples.
Note when voltages are listed as “Source” that side is an Output voltage for use by a “Load” or device on the other side. Be sure to check that two sources are not shorted together without first verifying from ModalAI if they are from the same prime source. Weights provided in grams are subject to +/-0.25 gram tolerances.
Cable Catalog
Cable  (Click to jump to section)CategoryDescriptionPurchase
MCK-M0018-1Cable KitFlight Core Cable Kit ~ END OF LIFE ~EOL
MCK-M0087-2Cable KitFlight Core V2 Cable KitEOL
MCBL-00001PowerVOXL Flight and VOXL/VOXL 2 to Power Module CablePurchase
MCBL-00003PowerFlight Core to Power Module CablePurchase
MCBL-00004Signal-PWMPWM Output CablePurchase
MCBL-00005Signal-UART/RC+PWRRC Input Cable (Spektrum)Purchase
MCBL-00007Signal-UARTVOXL to Flight Core/VOXL ESC Serial CablePurchase
MCBL-00008Signal-UARTVOXL to Flight Controller TELEM portPurchase
MCBL-00009USB4-pin JST GH to USBA Female CablePurchase
MCBL-00010USB4-pin JST GH to micro USB Female CablePurchase
MCBL-00011PowerVOXL-PM-Y for Flight Deck R0/R1 CablePurchase
MCBL-00013Signal-UARTVOXL Flight to VOXL ESC Cable (cross over)
MCBL-00014Signal-UARTFlight Core to VOXL ESC Cable (cross over)Purchase
MCBL-00015Signal-Multi4pin-JST-GH-to-4pin-JST-GH cablePurchase
MCBL-00016Signal-Multi6pin-JST-GH-to-pigtail break out cablePurchase
MCBL-00017Power5V Stand Alone Dongle Cable, v1
MCBL-00018Signal-UART/RC+PWRRC Input Cable, Servo (S.Bus, FrSky)EOL
MCBL-00020Signal-MultiUSB Cable, 4-pin Molex Picoblade to 4-pin JST-GH, ArduCam
MCBL-00021Signal-UART/RC+PWRRC Input Cable, FrSky R-XSR to Flight Core / VOXL Flight
MCBL-00022USBUSB3 10-pin JST cableEOL
MCBL-00024PowerPower Module to Stand Alone Modem CablePurchase
MCBL-00025Signal-UARTLTE v2 to Flight Core Telemetry
MCBL-00028Signal-UART/GNSS+I2C+PWRSeeker GPS cable
MCBL-00029Signal-UARTVOXL 2 or QC Flight RB5 to ESC cable / VOXL 2 to ESCPurchase
MCBL-00031Signal-Multi6 pin-JST-GH-to 6-pin-JST-GH passthrough, BreakoutPurchase
MCBL-00041USB4-pin JST GH to USBA Female CablePurchase
MCBL-00048Signal-UART/GNSS+I2C+PWRFlight Core v2 DroneCode Compliant 6-pin JST to 6-pin SHR
MCBL-00061Signal-UART/RC+PWRVOXL 2 to VOXL 2 I/OPurchase
MCBL-00062PowerFlight Core v2 Power CablePurchase
MCBL-00063Signal-UARTFlight Core v2 UART ESC Cable
MCBL-00064Signal-UART/RC+PWRVOXL 2 IO RC Input Cable, Servo (S.Bus, FrSky)Purchase
MCBL-00065Signal-UART/RC+PWRVOXL 2 IO RC Input Cable, FrSky S.BUS R-XSR
MCBL-00066Signal-UARTVOXL 2 Add-on UART 6-pin JST to FlightCore 6-pin JST (cross over)Purchase
MCBL-00067Signal-UARTVOXL 2 Add-on UART 4-pin JST to FlightCore 6-pin JST (straight)Purchase
MCBL-00068USBVOXL 2 4-pin JST USB to Doodle Labs HelixEOL
MCBL-00069Signal-UARTVOXL 2 ESC 4-pin JST UART to Custom TMotor F55A ESCEOL
MCBL-00070Signal-MultiVOXL 2 12-Pin JST GH Breakout Cable
MCBL-00071Signal-Multi/USB4-Pin JST GH Breakout Cable
MCBL-00072USBVOXL 2 10-pin JST USB to Boson RHP-BOS-VPC3-IFPurchase
MCBL-00076Signal-UART/GNSS+RC+PWRStarling/Sentinel GPS + RC UART cablePurchase
MCBL-00078PowerXT30U-M to Pigtail 150mm
MCBL-00080USBVOXL 2 10-pin JST USB3 to 4-pin JST USB2Purchase
MCBL-00081Signal-UARTVOXL 2 Mini 12-pin JST to 6-pin DF13 ESC UART
MCBL-00082Signal-UARTVOXL 2 Mini 12-pin JST to 4-pin JST ESC UART
MCBL-00083Signal-MultiVOXL 2 8-Pin JST GH Breakout Cable
MCBL-00085USB+PWRVOXL 2 10-Pin JST USB to Doodle Labs RM-2025-62M3 CablePurchase
MCBL-00086Signal-UART/GNSS+RC+PWRSentinel Holybro (Pixhawk) GPS + RC UART Cable
MCBL-00088PowerXT60-M to Pigtail 150mm
MCBL-00089Signal-UART/GNSS+ESC+RCStinger (“Full VOXL 2 Mini Breakout”) GPS + ESC + RC CablePurchase
MCBL-00090USB-to-UARTModalAI USB to Serial UART JST-SH Cable (Console Debug)
MCBL-00091USB-to-UARTModalAI USB to Serial UART JST-GH Cable (ESC Tools/HWIL)
MCBL-00092PowerJST RCY Receptacle Cable Assy Red/Black
MCBL-00093PowerJST RCY Plug Cable Assy Red/Black
MCBL-00094USB10-Pin JST GH USB2 Breakout Cable/Pigtails
MCBL-00095PowerVOXL-PM-Y for Legacy ToF M0169Purchase
MCBL-00098Signal-Multi3-Pin JST GH Sub-Pop 1&3 Breakout Cable
MCBL-00099Signal-Multi4-Pin JST GH Sub-Pop 1&4 Breakout Cable
MCBL-00100Signal-Multi4-Pin JST GH Sub-Pop 2&3 Breakout Cable
MCBL-00103PowerXT60EW-M Bulkhead to Pigtail 80mm
MCBL-00104USBModalAI Boson USB Host Programming Cable
MCBL-00105Signal8-Pin JST SH to 8-Pin JST SH Extension
MCBL-00106PowerXT30U-F to Banana Plugs 300mm
MCBL-00107USBVOXL 2 4-pin JST USB to Boson RHP-BOS-VPC3-IF
MCBL-00109PowerXT30U-F Test Mode Power JumperPurchase
MCBL-00110PowerXT60-M to Pigtail 120mm
MCBL-00111Signal-Multi8pin-JST-GH-to-8pin-JST-GH cable
MCBL-00112Power-MultiMolex 4-Pin MicroOne to Pigtail, 100mm
MCBL-00113PowerMolex 4-Pin MicroOne to Pigtail, Sub-Pop 1&2, 100mm
MCBL-00114PowerJST SFHR-L to SFHR-L VBAT Extension Cable
MCBL-00115PowerJST SFHR-L to XT30U-M VBAT Extension Cable
MCBL-00116PowerJST SFHR-L to XT60-M VBAT Extension Cable
MCBL-00117Signal-UART/VTX-PWRVOXL 2 MINI UART + VBAT to HD-Zero VTX Cable, 100mm
MCBL-00118Signal-UART/VTX-PWRFC/OSD UART + VBAT to HD-Zero VTX Cable, 100mm
MCBL-00119Signal-PWM/PWRLED bar Cable PWM Pigtails SYR + SL, 100mm
MCBL-00120SignalVOXL 2 8-Pin JST GH SPI Adapter Cable to JST 6-Pin SH
MCBL-00121USB10-pin JST GH to USBA Female Cable
MCBL-00122Signal-Multi6-Pin JST GH Sub-Pop 2, 3, & 6 Breakout Cable
MCBL-00123Signal-Multi2-Pin Molex SL Receptacle Breakout Cable
MCBL-00124Signal-Multi2-Pin Molex SL Plug Breakout Cable
MCBL-00125PowerJST SFHR-T-K to SFHR-T-K 3.8V 1S VBAT Extension
MCBL-00126PowerJST SFHR-T-K breakout to Pigtail, 100mm
MCBL-00127PowerJST SFHR-L to Molex SL Plug VBAT Power Cable
MCBL-00128SignalSparrow 10-pin JST SH to Dual ToF Pill 5-pin SH
MCBL-00129Signal-UART/ESC+RCStinger (VOXL 2 Mini) ESC + RC Cable
MCBL-00130SignalVOXL 2 Dronecode 6-pin JST GH I2C to 3-Pin JST SH
MCBL-00131Signal3-Pin JST SH to 3-Pin JST SH Straight Through
MCBL-00132PowerMolex 4-Pin MicroOne to JST SFHR-T-K 3.8V 1S VBAT, 80mm
MCBL-00133Signal-Multi4pin-JST-GH-to-4pin-JST-GH Cross-Over cable, 50mm
MCBL-00137PowerJST SFHR-L VBAT Pigtail Cable, 100mm
MCBL-00138Signal-RC/PWM Type 2-BStinger: PWM Cable Type 2-B Receptacle
MCBL-00146PowerXT60-M to Dual JST SFHR-L VBAT Y-Cable, 50mm
MCBL-00151SignalVOXL 2 8-Pin JST GH UART to BraveF7 OSD Cable, 75mm
MCBL-00152USB4pin-JST GH to 4pin-JST SH cable, 50mm
MCBL-00159PowerMolex Mini-SPOX to 6-Pin JST GH for Doodle RM-2025-62M3
MCBL-00160SignalVOXL 2 Mini 8-pin JST GH UART to DroneCode 6-pin JST SH
MCBL-00162USBUSB2 Type-A Male Data Only Cable to JST GH 4-pin, 200mm
MCBL-00211PowerVOXL-PM-Y for FCv2 Flight Deck Cable
MCBL-00218Signal-UART/RC+PWRRC Input Cable, Servo (S.Bus, FrSky), Flight Core V2Purchase
MCBL-00221Signal-UART/RC+PWRRC Input Cable, FrSky R-XSR to Flight Corev2
AccessoriesDescription
MCCA-M0022)PWM Breakout PCB
MCK-M0018-1 END-OF-LIFE
MCK-M0018-1
Description:
  • Flight Core Cable Kit
Contains:
  • PWM Break Out Board (MCCA-M0022)
  • MCBL-00004 - PWM breakout cable
  • MCBL-00005 - RC Input Cable
  • MCBL-00010 - JST to microUSB female (MCBL-00006, not provided, shown in image)
  • MCBL-00007 - VOXL to Flight Core Serial Cable (provides MAVLink connection over UART between VOXL and Flight Core)
Buy:
  • Available on the ModalAI shop
MCK-M0087-2
Description:
  • Flight Core V2 Cable Kit, See Contents List Below:
Contains:
Buy:
MCBL-00001
MCBL-00001
Description:
  • VOXL Flight and VOXL to Power Module Cable
  • Note there are three variants, -1, -3, and -4.
    • “-1” is nominally for sale and part of our power module kits and larger drones, 125mm.
    • MCBL-00001-1: VOXL Flight and VOXL/VOXL 2 to Power Module Cable
    • “-3” and “-4” are shorter lengths (40mm and 70mm respectively) embedded in complete drone kits, but can be made available for purchase upon request
    • MCBL-00001-3: VOXL Flight and VOXL/VOXL 2 to Power Module Cable, 40mm
    • MCBL-00001-4: VOXL Flight and VOXL/VOXL 2 to Power Module Cable, 70mm
Where used:
Details:
ComponentDetails
Connector AMolex, 0050375043
Connector BMolex, 0050375043
Length125mm (-1 variant), 40mm (-3 variant), 70mm (-4 variant)
InsulatorSilicon
ColorBlack
Gauge20 AWG
Weight4.5 grams (-1 variant)
Pinout: Note this cable is symmetric and can be used in either direction where the power module is the voltage source and the VOXL/VOXLFlight/VOXL 2 are the loads for pin 1.
A B
15V DC15V DC
2GND2GND
3I2C3_SCL3PM_SCL
4I2C3_SDA4PM_SDA
Pinout, Part Number, & Additional Specs: See -1 Drawing Here, See -3 Drawing Here, and See -4 Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of these drawings.
MCBL-00003
MCBL-00003
Description:
  • Flight Core to Power Module Cable
Where Used:
Details:
ComponentDetails
Connector AJST, GHR-06V-S
Length120mm
InsulatorPVC (flexible)
ColorBlack
Gauge26 AWG
Pinout:
A B
15V DC (Load)15V DC (Source)
2--
3--
4EXP_I2C_SCL3PM_SCL
5EXP_I2C_SDA4PM_SDA
6GND2GND
Pinout, Part Number, & Additional Specs: See Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of these drawings.
MCBL-00004
MCBL-00004
Description:
  • PWM Output Cable
Where Used:
Details:
ComponentDetails
Connector AJST, GHR-10V-S
Connector BJST, GHR-10V-S
Length120mm
ColorBlack
Gauge26 AWG
Pinout: Note this cable is symmetric and can be used in either direction with the FlightCore side providing 5VDC voltage as the Source for reference/monitor circuits only (cannot power a servo/BLDC).
A B
15V DC15V DC
2PWM_CH02PWM_CH0
3PWM_CH13PWM_CH1
4PWM_CH24PWM_CH2
5PWM_CH35PWM_CH3
6PWM_CH46PWM_CH4
7PWM_CH57PWM_CH5
8PWM_CH68PWM_CH6
9PWM_CH79PWM_CH7
10GND10GND
MCBL-00005
MCBL-00005
Description:
  • RC Input Cable (Spektrum)
Where Used:
Details:
ComponentDetails
Connector AJST, GHR-04V-S
Connector BJST, ZHR-3
Length150mm
ColorBlack
Gauge26 AWG
Pinout:
A B
13.3VDC (Source)13.3VDC (Load)
2USART6_TX-NC
3SPEKTRUM RX (3.3V), SBus RX (3.3V), USART6_RX3SPEKTRUM TX (3.3V), SBus TX (3.3V)
4GND2GND
Back to top
MCBL-00007
MCBL-00007
Description:
  • VOXL to Flight Core Serial Cable (provides MAVLink connection over UART between VOXL and Flight Core)
  • VOXL to VOXL ESC Cable (straight through)
  • No Power Connection, Signals + GND connections only
Where Used:
Details:
ComponentDetails
Connector ADF13-6S-1.25C (Flight Core)
Connector BDF13-6S-1.25C (VOXL)
Length90mm
ColorBlack
Gauge26 AWG
Pinout:
A B
1-1
2FC RX2VOXL TX
3FC TX3VOXL RX
4-4-
5GND5GND
6-6-
MCBL-00008
MCBL-00008
Description:
  • VOXL to Flight Controller TELEM port (Dronecode Compliant)
Where Used:
Details:
ComponentDetails
Connector ADF13-6S-1.25C (VOXL)
Connector BJST, GHR-06V-S (Flight Core)
Length90mm
ColorBlack
Gauge26 AWG
Pinout:
A B
1--
2VOXL TX3FC RX
3VOXL RX2FC TX
4---
5GND6GND
6- -
MCBL-00009
MCBL-00009
Description:
  • 4-pin JST to USBA Female/Receptacle Cable
Where Used:
Details:
ComponentDetails
Connector AJST, GHR-04V-S)
Connector BUSB 2.0 Type A Female/Receptacle
Length~60mm
Pinout:
A B
1VBUS (Source side)1VBUS (Load side)
2DATA_M2D-
3DATA_P3D+
4GND4GND
MCBL-00010
MCBL-00010
Description:
  • 4-pin JST to micro USB Female/Receptacle Cable
    • Used for connecting USB Hosts such as a PC (Micro USB connector side) to ModalAI USB Peripherals (JST side).
      • Note: Micro USB side requires a standard Type-A to MicroUSB cable/adapter depending on your system setups
    • Flight Core (PX4) to micro USB cable to QGroundControl (MAVLink)
    • Microhard Standalone Modem to micro USB cable to host computer
Where Used:
Details:
ComponentDetails
Connector BMicro USB 2.0 Female
Length~60mm
Pinout:
A B
1VBUS (Load)1VBUS (Source)
2DATA_M2D-
3DATA_P3D+
- 4ID (unused)
4GND5GND
MCBL-00011-1
MCBL-00011-1
Description:
  • VOXL-PM-Y for Flight Deck R0/R1 Cable
  • Powers both VOXL and FlightCore from one Power Module, with the I2C bus for power monitoring going to FlightCore
Where Used:
Details:
ComponentDetails
Connector AJST, GHR-06V-S (Flight Core side, 4 wires)
Connector BMolex, 0050375043 (Power Module side, 4 wires)
Connector CMolex, 0050375043 (VOXL side, 2 wires)
Length120mm
ColorBlack
Gauge22AWG (B-to-C)/ 26AWG (B-to-A)
Pinout:
CVOXLBVOXL PMAFlight Core
15V DC (Load)15V DC (Source)15V DC (Load)
2GND2GND6GND
- 3SCL4EXP_I2C_SCL
- 4SDA5EXP_I2C_SDA
MCBL-00013
MCBL-00013
Description:
  • VOXL Flight to VOXL ESC V2/V3 Cable (cross over)
  • This is a UART RX/TX cross-over version of MCBL-00007 for Hirose DF13-6P
Where Used:
Details:
ComponentDetails
Connector ADF13-6S-1.25C (VOXL Flight)
Connector BDF13-6S-1.25C (ESC)
Length100mm
ColorBlack
Gauge26 AWG
Pinout:
AVOXL FlightBVOXL ESC V2/V3
1--
2RX3TX
3TX2RX
4---
5GND5GND
6---
MCBL-00014
MCBL-00014
Description:
  • Flight Core to VOXL ESC Cable (cross over)
  • This is just like MCBL-00013 but one of the 6-pin DF13’s is replaced by an 8-pin for FlightCore J4
Where Used:
  • Flight Core J4 to VOXL ESC (J2 on VOXL ESC V2/V3, M0027/M0049/M0117/M0134)
  • Connecting ESC’s’ to VOXL CAM Flight Core (on Seeker Drone, for example)
Details:
ComponentDetails
Connector ADF13-8S-1.25C (Flight Core)
Length100mm
ColorBlack
Gauge26 AWG
Pinout:
AFlight CoreBVOXL ESC V2/V3
1--
2RX3TX
3TX2RX
4---
5GND5GND
6---
7-
8-
Back to top
MCBL-00015
MCBL-00015
Description:
  • 4pin-JST-to-4pin-JST cable (straight through 1:1)
Where Used:
  • VOXL USB Add-On boards to Stand Alone Modem Boards, ESC UART from VOXL 2 to Mini-ESC (M0129)
  • Conforms to all ModalAI 4-pin JST USB2.0 formats, either Host (VBUS, Pin1, is a source) or Peripheral (VBUS, Pin1, is a load)
  • Great item to have for making your own cables!!
  • Note there are four variants, -1, -2, -3, and -4.
    • “-1” is nominally for sale, 100mm.
    • “-2” is a longer length, 150mm, embedded in complete drone kits, but can be made available for purchase upon request
    • “-3” is a shorter length, 50mm, embedded in Starling drone kits, but can be made available for purchase upon request
    • “-4” is the shortest length at 15mm and can be made available for purchase upon request.
      • Note the -4 variant has no label on it due to its size.
Details:
ComponentDetails
Connector BJST, GHR-04V-S
Length100mm (-1 variant), 150mm (-2 variant), 50mm (-3 variant), 15mm (-4 variant)
ColorBlack
Gauge26 AWG
Weight1.1 grams (-1 variant), 1.4 grams (-2 variant), 0.7 grams (-3 variant), 0.4 grams (-4 variant)
Pinout:
A B
1Pin11Pin1
2Pin22Pin2
3Pin33Pin3
4Pin44Pin4
Pinout, Part Number, & Additional Specs: See -1 Drawing Here, See -2 Drawing Here, See -3 Drawing Here, See -4 Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of these drawings.
MCBL-00016
MCBL-00016
Description:
  • 6pin-JST-to-pigtail break out cable
Where Used:
  • M0048 ICM42688 IMU Breakout Board
  • Any ModalAI 6-pin JST where soldering or custom harnesses are needed
  • Note: pigtail side is tinned for ~10mm making it easy to install JST SSHL-002T-P0.2 pins if needed
Details:
ComponentDetails
Connector AJST, GHR-06V-S)
Connector BNone
Length100mm
ColorBlack
Gauge26 AWG
Weight1.4 grams
Pinout:
A
1 1(pigtail)
2 2(pigtail)
3 3(pigtail)
4 4(pigtail)
5 5(pigtail)
6 6(pigtail)
MCBL-00017
MCBL-00017
Description:
  • Power Supply (not supplied) to Stand Alone Modem Dongle
  • Connector mates to the Red JST J8 on Microhard boards, or J3 on Sierra LTE V2 modem boards
  • Tinned leads on the other side allow soldering or converting to pins as needed by the customer.
  • NOTE: Cut the wire length to 150mm or less if anticipating needing the full 4A capable of these designs (high power radio modes + all USB connectors used). Refer to the Where Used links below for power consumption estimates.
Where Used:
Details:
ComponentDetails
Connector ASFHR-02V-R
Connector BNone/Tinned ~10mm
Length300 mm
ColorRed/Black
Gauge22 AWG
Pre-crimpedALEALEA22K102
Pinout:
AWireBModem
1RED (Source)1VDCIN_5V (Load)
2BLACK2GND
MCBL-00018
MCBL-00018
Description:
  • RC Input (S.Bus, FrSky)
  • Picks up Power on Red+Black, and Receive Signal on Orange from FlightCore or VOXLFlight to a R/C receiver 3-pin 0.1” hobby format
    • ModalAI conforms to the notion of Pin 1 = Signal, Pin 2 = 5V, & Pin 3 = GND for the 3-pin hobby format. Please notify us if you see anything here to the contrary.
  • Note: This is only intended for remote receivers and cannot power high current servos or BLDCs
Where Used:
ComponentDetails
Connector AJST GHR-03V-S, for +5V Power/GND
Connector BJST GHR-04V-S, for UART_RX signal, +3.3V levels
Connector CHarwin M20-1060300, CONN RCPT HSG 3POS 2.54mm (or similar)
Length150 mm
ColorRed/Black/Orange
Gauge26 AWG
Pinout:
APowerCRC ReceiverBSignal
1RED (5V, Source)25V DC (Load)
2 1S.Bus/DSMX (Orange)3S.Bus/DSMX (Orange)
3BLACK (GND)3GND
MCBL-00020
MCBL-00020
Description:
  • USB Cable, Arducam-4 pin Molex Picoblade to 4 -pin JST-GH
Where Used:
  • VOXL Add-ons with USB hub to ArduCam USB Camera
Details:
ComponentDetails
Connector A4POS 1.25mm PICOBLADE
Connector B4POS 1.25mm JST
Length100mm
InsulatorSilicon
ColorBlack
Gauge26 AWG
Pinout:
A B
1V_BUS1V_BUS
2DATA_M2DATA_M
3DATA_P3DATA_P
4GND4GND
See Schematic Here
Back to top
MCBL-00021
MCBL-00021-1
Description:
  • RC Input (FrSky R-XSR)
  • Picks up Power on Red+Black, and Receive Signal on Yellow from FlightCore or VOXLFlight to FrSky R-XSR format R/C receiver 5-pin Picoblade format
  • Note: This is just like MCBL-00018 but instead of the 3-pin hobby format receptacle, it is pinned for the FrSky R-XSR 5-position Picoblade
Where Used:
ComponentDetails
Connector CMolex 0510210500, 5-position Picoblade housing 1.25mm
Length140 mm
ColorRed/Black/Yellow
Gauge26 AWG
Pinout:
R-XSR-Pinout
1RED (5V, Source)45V DC (Load)
2 2S.Bus (Yellow)3S.Bus (Yellow)
3BLACK (GND)5GND
Pinout, Part Number, & Additional Specs: See Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of this drawing.
MCBL-00022
MCBL-00022
Description:
  • USB3 10-pin JST cable to USB3-Type A Receptacle
  • Note: This is not qualified for 10Gbps speeds. This is a proto-type design suitable for most application development. Customers are advised to source their own shielded and speed-qualified cable for high-volume needs.
  • Custom “AC” variant for VOXL 2 Mini Use Case, as described Here
    • Make sure the part number you order includes a “-ac” in the ModalAI part number. Due to the complexity, this is more costly than our standard cable. MCBL-00022-ac
Where Used:
  • Any ModalAI CCA USB downstream port (host only) with the 10-pin JST ModalAI USB3 format (examples are M0062, M0067, M0090, M0104, M0130).
  • VOXL 2 Mini must specifically use MCBL-00022-AC if USB3 speeds are required. If USB2 speeds are sufficient, the nominal MCBL-00022-2 is suggested for the lower cost.
Details:
ComponentDetails
Connector A10POS 1.25mm JST, GHR-10V-S
Connector BCONN RCPT USB3.0 TYPEA, CNC Tech 1003-006-01200
Length80mm
InsulatorSilicon
ColorBlack, White/Green TP
Gauge26AWG VBUS/GND, 28AWG Twisted Pair Signals (the MCBL-00022-AC inherently looses some of the Twists)
MCBL-00024
MCBL-00024
Description:
  • Power Module to Stand Alone Modem Cable
Where Used:
  • Used to power a standalone modem board (Sierra M0030-2/M0130-2, or Microhard M0048-2/M0059-2, or 5G M0090-2) directly from the ModalAI Power Module V3
Details:
ComponentDetails
Connector AMolex, 0050375043 (Power Module side, 2 wires)
Connector BSFHR-02V-R (Modem side, 2 wires)
Length100mm
ColorBlack/Red
Gauge26AWG
Pinout:
APOWER MODULEBModem Side
2GND2GND
3-
4-
See Drawing Here
MCBL-00025
MCBL-00025
Description:
  • LTE v2 to Flight Core (DroneCode Compliant) Telemetry
Where Used:
  • The M0030 Sierra 4G/LTE Modem has a spare UART port on J9 (matches the pinout of J2 as shown here)
  • This connector provides a 3.3V UART link directly to the Modem, which can be connected to FlightCore J5 (UART7) to create a 4G Telemetry or general purpose data link.
  • Note: Software support of this feature may still be in BETA form, please contact ModalAI for support
  • Flightcore side pinouts also match other DroneCode compliant connectors J6 (expansion UART4) and J10 (GNSS UART1) ports
  • The 4-pin side on the 4G LTE Modem also matches many other Serial Debug Ports on ModalAI HW and can be used as a general purpose UART converter from the 4-wire eSH format to 6-wire eGH format (DroneCode Compliant)
Details:
ComponentDetails
Connector AJST 1.25mm GHR-06V-S, FlightCore Side, +3.3V levels
Connector BJST 1.0mm SHR-06V-S, 4G Modem Side, +3.3V levels
Length100mm
InsulatorSilicon
Colorblack
Gauge26 AWG
Pinout:
A B
1-1-
2TX (FlightCore Output/Transmit)2RX (Modem Input/Receive)
3RX (FlightCore Input/Receive)3TX (Modem Output/Transmit)
4-4GND
5---
6GND--
See Drawing Here
Back to top
MCBL-00028
MCBL-00028-2
Description:
  • Seeker GPS Cable
Where Used:
  • Connects HolyBro GPS/Magnetometer unit to VOXL-CAM on Seeker drone using FlightCore J10 (6-pin)
  • This cable provides power + UART + I2C
Details:
ComponentDetails
Connector A10 POS 1.0mm JST, GNSS Side
Connector B6 POS 1.25mm JST, FlightCore J10 side
Length230mm
InsulatorSilicon
ColorBlack
Gauge26 AWG
Pinout:
A B
15VDC (Load)15VDC (Source)
2RX (GNSS Input)2TX (FlightCore Output)
3TX (GNSS Output)3RX (FlightCore Input)
4SCL4SCL (FlightCore Host Side)
5SDA5SDA (FlightCore Host Side)
6---
7---
8---
9---
10GND6GND
See Drawing Here
  • updated drawing coming soon!
MCBL-00029
MCBL-00029
Description:
  • RB5 Flight (M0052) or VOXL 2 (M0054) to VOXL ESC V2/V3 Cable
  • This is just like MCBL-00007 but one side is now the new 4-pin JST GH format for ESC instead of DF13 on VOXL
  • Note there are two variants, -1, and -2.
    • “-1” is nominally for sale and part of our larger drones at 200mm.
    • “-2” is shorter at 70mm and will be embedded into the new Starling drone kit, but can be made available for purchase upon request
Where Used:
  • Qualcomm Flight RB5 Mainboard ESC Port (J18) to VOXL ESC V2/V3 J2 (M0027/M0049/M0117/M0134)
  • VOXL 2 ESC Port (J18) to VOXL ESC V2/V3 J2 (M0027/M0049/M0117/M0134)
  • 200mm length for long wire M500 frame installations
  • 70mm for smaller drone installations
Details:
ComponentDetails
Connector ADF13-6S-1.25C (VOXL ESC), +3.3V levels
Connector BJST 1.25mm GHR-04V-S, RB5 Flight/VOXL 2 Side, +3.3V levels
Length200mm (-1 variant), 70mm (-2 variant)
InsulatorSilicon (flexible)
ColorBlack
Gauge26 AWG
Pinout:
AVOXL ESC V2/V3BRB5 Flight / VOXL 2
1-1
2ESC RX2VOXL 2/RB5-Flight TX
3ESC TX3VOXL 2/RB5-Flight RX
4---
5GND4GND
6---
Pinout, Part Number, & Additional Specs: See -1 Drawing Here, See -2 Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of these drawings.
MCBL-00030
MCBL-00030-3
Description:
  • End-Of-Life: Being Replaced by MCBL-00040-2 with 3.5mm bullet terminal system
  • 2mm Bullet Connector to tinned lead for ESC soldering and easy motor mating
  • RB5 Flight ESC to motor cables (legacy usage)
  • Note: We have various lengths for this cable
    • MCBL-00030-2 = 250mm (as per drawing link below, but Obsolete, use other lengths),
    • MCBL-00030-3 = 265mm
    • MCBL-00030-4 = 210mm
Details:
ComponentDetails
Connector AFemale Bullet Wire,2mm, 18-22AWG
Length250mm
InsulatorSilicon
Gauge20 AWG
See Drawing Here
MCBL-00031
MCBL-00031-1
Description:
  • 6 pin-JST-GH-to 6-pin-JST-GH passthrough (1:1/Straight-through wiring)
    • -1, 100mm, is nominally for sale and the -2 is a longer version at 150mm.
Where Used:
  • Connects Qualcomm Flight RB5 Flight Deck Modem and Chirp Sensors
  • Connects VOXL 2/VOXL 2 Mini and FlightCoreV2 Dronecode Compliant ports to Dronecode Compliant GNSS modules
  • Chirp Breakout to Debug or Modem Carrier Board
  • Any place where a 6-pin JST GH is used for debugging, external sensors, etc.
Details:
ComponentDetails
Connector A6POS 1.25mm JST
Connector B6POS 1.25mm JST
InsulatorPVC (flexible) (some old units may be silicone)
ColorBlack
Gauge26 AWG
Weight1.7 grams (-1 variant), 2.4 grams (-2 variant)
Pinout:
A B
1 1
2 2
3 3
4 4
5 5
6 6
Pinout, Part Number, & Additional Specs: See -1 Drawing Here, See -2 Drawing Here. Contact ModalAI on the Forum for .DXF or .DWG formats of these drawings.
MCBL-00041
MCBL-00041
Description:
  • 150mm (6”) version of MCBL-00009
Where Used:
Details:
ComponentDetails
Length~150mm
Weight10.9 grams
Pinout:
A B
2DATA_M2D-
3DATA_P3D+
4GND4GND
MCBL-00048
MCBL-00048-1
Description:
  • Connects Matek GPS/Magnetometer unit to ModalAI DroneCode compliant ports, such as J10 on FlightCore V2
Where Used:
  • ModalAI FlightCore (v1 or V2) J10 (or other Dronecode compliant ports) to COTS Matek GNSS module, or others, with 6-pin JST SHR format (be sure to check GNSS module vendor specs as they change often)
Details:
ComponentDetails
Connector AJST 1.25mm GHR-06V-S, FCv2 side, +3.3V signal levels
Connector BJST 1.0mm SHR-06V-S-B, Module side, +3.3V signal levels
Length150mm
ColorBlack
Gauge26 AWG
Weight2.2 grams
Pinout:
AFlightCore V2BGNSS Module
15V (Source)65V (Load)
2UART_TX4UART_RX
3UART_RX3UART_TX
4MAG_I2C_SCL1SCL
5MAG_I2C_SDA2SDA
6GND5GND
Back to top
MCBL-00061
MCBL-00061-1
Description:
  • Cable providing the primary connection used to connect VOXL 2 to VOXL 2 IO, which provides power and UART based communications
Where Used:
  • Connects VOXL 2 J19 to VOXL 2 I/O J4
Details:
ComponentDetails
Connector AGHR-12V-S
Connector BGHR-04V-S
Length150mm
InsulatorSilicone
ColorBlack
Gauge26AWG
Pinout:
A B
1NC
2NC
3NC
4NC
5NC
6NC
7NC
8NC
93P3V13P3V_IO
10VOXL 2 TX2VOXL 2IO RX
11VOXL 2 RX3VOXL 2IO TX
12GND4GND
MCBL-00062
MCBL-00062
Description:
  • Cable connecting the VOXL Power Module v3 to the Flight Core v2, providing power and I2C connections
  • This is basically an MCBL-00001 (or MCBL-0003) but the LOAD side is now a 4-pin JST GH with a 1:1 pinout
    • -1, 150mm, is nominally for sale and the -2 is a shorter version at 75mm included in some drones (for sale upon request)
Where Used:
MCBL-00062-1
  • Connects ModalAI Power Module V3 output connector to FlightCoreV2 J13
  • Note, J13 is intended to be RED to help indicate Power. Due to supply chain challenges, some boards might have the standard white color connector for J13.
Details:
ComponentDetails
Length150mm (-1 variant), 75mm (-2 variant)
InsulatorSilicone (flexible)
ColorBlack
Gauge26 AWG
Weight1.9 grams (-1), 1.3 grams (-2)
Pinout:
AFCv2 SideBPower Module V3 Side
2GND2GND
3I2C_SCL3PM_SCL
4I2C_SDA4PM_SDA
Pinout, Part Number, & Additional Specs: See -1 Drawing Here, See -2 Drawing Here. Contact ModalAI on the Forum for .DXF or .DWG formats of this drawing.
MCBL-00063
MCBL-00063
Description:
  • Cable providing the primary connection used to connect Flight Core v2 to the ModalAI UART ESC.
  • The cable is effectively a 6-pin JST version of the 4-pin JST used on MCBL-00029 (instead of a VOXL 2, use a FCv2 with Dronecode format).
  • Note there are two variants, -1 and -2 with the only difference in length. -1 = 200mm, -2 = 90mm
Where Used:
  • ModalAI ESC (M0049/M0117/M0134) J2 to FlightCoreV2 J5 (starting 1.13.2-0.1.2)
MCBL-00063-1
Details:
ComponentDetails
Connector BJST 1.25mm GHR-06V-S, FCv2 side, +3.3V levels
Length(-1 variant) 200mm, (-2 variant) 90mm
ColorBlack
Gauge26 AWG
Weight(-1 variant) 1.4 grams, (-2 variant) 0.9 grams
Pinout:
AVOXL ESC V2/V3BFlightCore V2
1-1
2ESC RX2FCv2 TX
3ESC TX3FCv2 RX
4---
5GND6GND
6---
Pinout, Part Number, & Additional Specs: See -1 Drawing Here & See -2 Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of this drawing.
MCBL-00064
MCBL-00064
Description:
  • Picks up Power on Red+Black, and Receive Signal on Orange from VOXL 2 I/O Board (M0065) to a R/C receiver 3-pin 0.1” hobby format
  • Note: This is only intended for S.BUS (or +5V) remote receivers and cannot power high current servos or BLDCs
  • Note: For Spektrum Receivers with +3.3V power supply needs, please see MCBL-00005
  • This is just like MCBL-00018 but instead of needing two JST GH connectors, it has been consolidated into one 4-pin
Where Used:
MCBL-00064-1
  • 4-pin JST (connector B): VOXL 2 I/O (M0065) J3 (should be black in color, supply chain permitting) to 3-pin Harwin M20 Receptacle (connector A) to RC Receiver (e.g. S.BUS/FrSky)
ComponentDetails
Connector BJST GHR-04V-S, +5V Power/GND, UART_RX signal, +3.3V levels
Connector AHarwin M20-1060300, CONN RCPT HSG 3POS 2.54mm (or similar)
Length150 mm
ColorRed/Black/Orange (might be all black)
Gauge26 AWG
Weight1.5 grams
Pinout:
ARC ReceiverBVOXL 2 IO (M0065)
1Orange, S.Bus Signal (Output)3S.Bus signal (Input)
2Red, +5V DC (Load)1+5V DC (Source)
3BLACK, GND4GND
See Drawing Here
MCBL-00065
MCBL-00065-1
Description:
  • Picks up Power on Red+Black, and Receive Signal on Orange from VOXL 2 I/O Board (M0065) to an FrSky R-XSR receiver 5-pin Molex Picoblade format
  • This is just like MCBL-00021-1 but for VOXL 2 IO instead of FlightCore and therefore consolidated into one 4-pin JST
Where Used:
  • 4-pin JST (connector B): VOXL 2 I/O (M0065) J3 (should be black in color, supply chain permitting) to 5-pin molex Picoblade on FrSky R-SSR RC Receiver
ComponentDetails
Connector AMolex 0510210500, 5-position Picoblade housing 1.25mm
Length150 mm
Gauge26 AWG
Pinout:
R-XSR-Pinout
MCBL-00021-1 shown but the same Picoblade pinout is used on MCBL-00065 as shown
2Orange, S.Bus Signal (Output)3S.Bus signal (Input)
4Red, +5V DC (Load)1+5V DC (Source)
5BLACK, GND4GND
See Drawing Here
MCBL-00066
MCBL-00066
Description:
  • Cable providing the primary connection used to connect Flight Core (V1 or v2) to the ModalAI 5G Modem (M0090)
  • Compatible with other plug-in boards with the 6-pin JST format as listed here.
  • The cable is effectively a 6-pin JST version of the 4-pin JST used on MCBL-00067.
Where Used:
  • ModalAI VOXL 2 5G Plug In Board (M0090) J9 to FlightCore V1/V2 J5 (or other DroneCode compliant UART ports on the designs, Software dependant)
  • This can also be used on other ModalAI DroneCode compliant UART ports (6-pin JST GH), but Software mapping would require changes by the user.
Details:
ComponentDetails
Connector AJST 1.25mm GHR-06V-S, VOXL 2 side, +3.3V levels
Length250mm
ColorBlack
Gauge26 AWG
Weight1.9 grams
Pinout:
AVOXL 2 J9BFlightCore V2 J5
1-1
2UART TX (Output)3FCv2 UART RX (Input)
3UART RX (Input)2FCv2 UART TX (Output)
4---
5--
6GND6GND
See Drawing Here
Back to top
MCBL-00067
MCBL-00067-1
Description:
  • Cable providing the primary connection used to connect Flight Core (V1 or v2) to the ModalAI USB and UART Breakout Board (M0125)
  • The cable is effectively a 4-pin JST version of the 6-pin JST used on MCBL-00066.
Where Used:
  • ModalAI VOXL 2 USB and UART Breakout Board (M0125) J3 to FlightCore V1/V2 J5 (or other DroneCode compliant UART ports on the designs, Software dependant)
  • Note: M0125 4-Pin JST UART port has RX on pin 2 and TX on pin 3, this is not common across our other HW designs (it was done intentionally, so be careful)
Details:
ComponentDetails
Connector AJST 1.25mm GHR-04V-S, VOXL 2 side, +3.3V levels
Length250mm
ColorBlack
Gauge26 AWG
Weight1.9 grams
Pinout:
AM0125 UART Breakout J3BFlightCore V2 J5
1-1
2UART RX (Input)2FCv2 UART TX (Output)
3UART TX (Output)3FCv2 UART RX (Input)
4GND6GND
See Drawing Here
MCBL-00068
MCBL-00068-1
Description:
  • Cable providing a 4-pin JST USB connection from a VOXL 2 Plug-in Board (M0090, M0130, etc) to a Doodle Labs Helix Smart Radio Primary connector
  • Compatible with any ModalAI 4-pin JST USB connectors on various designs
  • Note: Standalone versions of our USB boards require a stable high-power source that can deliver 5W to the Helix
  • Note: Doodle Labs Pinout notations in their documents has an incorrect pin1-pin15 callout. They are aware of it and will eventually fix it. We show an image below to help users understand this as our drawings use the proper JST based notations for pin 1
Where Used:
  • VOXL 2 + M0090 (5G modem)
  • VOXL 2 + M0130 (4G Modem, coming soon!!)
  • VOXL 2 + M0078 USB Debug Board
Details:
ComponentDetails
Connector BJST 1.25mm GHR-15V-S, Doodle Labs Helix side
Length150mm
ColorBlack
Gauge26AWG (Power/GND), 28AWG USB Data
Weight2.6 grams
Pinout:
AVOXL 2 SideBDoodle Labs Helix 15-pin Side
1VBUS (Source)1 & 2VCC/VBUS (Load), 2-way splice
2USB_D-14D-
3USB_D+15D+
4GND3 & 4 & 13GND, 3-way splice
MCBL-00068-pinout
MCBL-00069
MCBL-00069-1
Description:
  • Cable providing the VOXL 2 ESC UART 4-pin JST to a TMotor F55A ESC
  • Note: The TMotor F55A ESC has custom ModalAI firmware and hardware mods on it, thus allowing operation as noted here for the UART lines and the 4 MCUs. If you did not buy the TMotor ESC through ModalAI, this will not work
Where Used:
  • VOXL 2 + TMotor F55A ESC
Details:
ComponentDetails
Connector AJST 1.25mm GHR-04V-S, VOXL 2 side, +3.3V signal levels
Connector BJST 1.0mm SHR-10V-S-B, F55A ESC, +3.3V signal levels
Length200mm
ColorBlack
Gauge28 AWG
Weight1.1 grams
Pinout:
AVOXL 2 SideBTMotor Connector Side
1--
2UART_TX (Output of V2)1ESC UART RX (Input to ESC)
3UART_RX (Input to V2)3ESC UART TX (Output of ESC)
4GND10GND
This image shows the standard pinout for reference, but we use the signals as follows due to custom mods: MCBL-00069-pinout
  • TELEM Data output set as ESC UART Input
  • ESC[1:4] set as ESC UART Outputs
MCBL-00070
MCBL-00070-1
Description:
  • Cable providing a full JST GH 12-pin breakout
Where Used:
  • VOXL 2 J19, M0130 4G Modem J8
  • Any ModalAI 12-pin JST where soldering or custom harnesses are needed
Details:
ComponentDetails
Connector AJST 1.25mm GHR-12V-S
Connector BNone: Pigtails
Length100mm
InsulatorPVC
ColorBlack
Gauge26 AWG
Weight3.0 grams
Pinout:
A
1 1(pigtail)
2 2(pigtail)
3 3(pigtail)
4 4(pigtail)
5 5(pigtail)
6 6(pigtail)
7 7(pigtail)
8 8(pigtail)
9 9(pigtail)
10 10(pigtail)
11 11(pigtail)
12 12(pigtail)
Back to top
MCBL-00071
MCBL-00071-1
Description:
  • Cable providing a full JST GH 4-pin breakout, but with Pins 2&3 as twisted pair, suited for all of ModalAI’s USB2 ports
Where Used:
  • VOXL or VOXL 2 Plug-In boards
  • Microhard Plug-ins (M0048), Sierra 4G Plug-ins (M0030, M0130), 5G Plug-ins (M0090)
  • Any ModalAI 4-pin JST where soldering or custom harnesses are needed
Details:
ComponentDetails
Length150mm
InsulatorPVC
Gauge26 AWG, 28AWG Twisted Pair (Pins 2&3)
Weight1.3 grams
Pinout:
A
1 1(pigtail)
2 2(pigtail, TP)
3 3(pigtail, TP)
4 4(pigtail)
MCBL-00072
MCBL-00072-1
Description:
  • VOXL 2 10-pin JST USB to Boson RHP-BOS-VPC3-IF 6-JST
  • Cable providing a direct connection from ModalAI’s USB3 ports (M0090, M0130) to a FLIR Boson that uses the RHP-BOS-VPC3-IF “backpack”
  • Note: Only picks up the USB2 bus and not the SuperSpeed signals, so bandwidth would be limited to the 480Mbps USB2 standard
  • For the 4-pin USB2 connector version instead of the 10-pin, see MCBL-00107
Where Used:
  • VOXL 2 Modem or USB3 expansion boards
  • Sierra 4G Plug-ins (M0130), 5G Plug-ins (M0090)
Details:
ComponentDetails
Connector A10 POS 1.25mm JST, GHR-10V-S, VOXL 2 USB3 10-pin
Connector B6 POS 1.00mm JST, SHR-06V-S-B, Backpack side
Length70mm
InsulatorPVC
ColorBlack (VBUS/GND), White/Green Twisted Pair USB_D+/D-
GaugeBlack 26 AWG, White/Green TP 28AWG
Weight0.9 grams
Pinout:
A B
1VBUS (Source)15VDC (Load)
2USB_D-6Boson D-
3USB_D+5Boson D+
4GND2GND
5---
6---
7---
8---
9---
10---
MCBL-00076
MCBL-00076-1
Description:
  • Connects VOXL 2/VOXL 2-Mini J19 in the Starling or Sentinel Drone Platform to Matek GPS/Magnetometer M10 unit (DroneCode compliant) and pigtails for soldering to a R/C unit UART+PWR
  • This cable provides power (GNSS+RC) + UART (GNSS) + I2C (MAG) + UART (R/C)
  • Note there are two variants, -1, and -3.
    • “-1” is included in the Starling platform for shorter cable length installations.
    • “-3” is longer intended for the Sentinel platform installations.
Where Used:
  • ModalAI Starling Drone, with either VOXL 2 or VOXL 2-Mini
  • ModalAI Sentinel Drone, with either VOXL 2 or VOXL 2-Mini
Details:
ComponentDetails
Connector AJST 1.25mm GHR-12V-S, VOXL 2 side, +3.3V signal levels
Connector BJST 1.25mm GHR-06V-S, Module side, +3.3V signal levels
Connector CPigtails for soldering to R/C unit, +3.3V signal levels
Length100mm (CONA-CONB), 45mm pigtails (-1)
 250mm (CONA-CONB), 155mm pigtails (-3)
InsulatorSilicone
ColorBlack, Red, White, Yellow
Gauge28 AWG
Weight1.7 grams (-1), 3.4 grams (-3)
Pinout:
AVOXL 2/ VOXL 2-MiniBGNSS ModuleCPigtails
15V (Source)15V (Load)PG1R/C 5V (Red, Load)
2UART_TX2UART_RX
3UART_RX3UART_TX
4MAG_I2C_SCL4SCL
5MAG_I2C_SDA5SDA
6GND6GND
10UART_TX  PG2R/C_RX (White)
11UART_RX  PG3R/C_TX (Yellow
12GND  PG4R/C GND (Black)
Pinout, Part Number, & Additional Specs: See -1 Drawing Here and See -3 Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of this drawing.
MCBL-00078
MCBL-00078
Description:
  • Multi-Purpose XT30 Male to Pigtail Leads, 150mm
  • Easily identifiable RED (+) and GREEN (-) cables
  • Robust adhesive lined heatshrink for long-lasting protection of pin solder joints
Where used:
  • Included in Starling ESC for system power from battery
  • Useful for ESC side or target side electronics when using an XT30-F based battery
Details:
ComponentDetails
Connector AAMASS, XT30U-M
Connector BPigtails, stripped and tinned 3.5mm
InsulatorSilicon
ColorRed (+) and Green (-)
Gauge18 AWG
Weight5.4 grams (-1 variant)
A B
+++RED
---GREEN
Pinout, Part Number, & Additional Specs: See Drawing Here. Contact ModalAI on the Forum for .DXF or .DWG formats of these drawings.
MCBL-00080
MCBL-00080
Description:
  • USB3 10-pin JST cable to USB2 4-Pin JST GH plug
  • There are two variants currently: -1 at the nominal 100mm and a -2 at a shorter 50mm length.
Where Used:
  • Ideal for connecting standalone modules (Microhard, LTE) to the VOXL 2 Mini platform (standalone dongles still require independent power from MCBL-00017-1)
Details:
ComponentDetails
Connector B4POS 1.25mm JST, GHR-04V-S
Length100mm (-1 variant), 50mm (-2 variant)
InsulatorPVC
Weight1.2 grams (-1 variant), 0.8 grams (-2 variant)
Pinout:
A B
1VBUS (Source)1VBUS (Load)
2USB_D-2D-
3USB_D+3D+
4GND4GND
5NC
6NC
7NC
8NC
9NC
10NC
Pinout, Part Number, & Additional Specs: See -1 Drawing Here, See -2 Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of this drawing.
MCBL-00081
MCBL-00081-1
Description:
  • Cable providing the ESC UART connection between VOXL 2 Mini and ModalAI ESC V2 (M0049, M0117, M0134).
Where Used:
  • Connects VOXL 2 Mini J19 to ModalAI ESC V2 J2
Details:
ComponentDetails
Length90mm
ColorBlack
Gauge26AWG
Weight0.9 grams
Pinout:
A B
1NC
2NC
3NC
4NC
5NC
6NC
7UART_TX2ESC_RX
8UART_RX3ESC_TX
9NC
10NC
11NC
12GND5GND
MCBL-00082
MCBL-00082-1
Description:
  • Cable providing the ESC UART connection between VOXL 2 Mini and ModalAI Mini ESC (M0129).
Where Used:
  • Connects VOXL 2 Mini J19 to ModalAI Mini ESC J1
Details:
ComponentDetails
Length90mm
ColorBlack
Gauge26AWG
Weight0.9 grams
Pinout:
A B
1NC
2NC
3NC
4NC
5NC
6NC
7UART_TX2ESC_RX
8UART_RX3ESC_TX
9NC
10NC
11NC
12GND4GND
Back to top
MCBL-00083
MCBL-00083-1
Description:
  • Cable providing a full JST GH 8-pin breakout
Where Used:
  • VOXL 2 & VOXL 2 Mini J10
  • Any ModalAI 8-pin JST where soldering or custom harnesses are needed
Details:
ComponentDetails
Connector AJST 1.25mm GHR-08V-S
Length100mm + 10mm pigtails
InsulatorPVC
ColorBlack
Gauge26 AWG
Weight2.1 grams
Pinout:
A
1 1(pigtail)
2 2(pigtail)
3 3(pigtail)
4 4(pigtail)
5 5(pigtail)
6 6(pigtail)
7 7(pigtail)
8 8(pigtail)
MCBL-00084
MCBL-00084-1
Description:
Where Used:
  • VOXL 2 with M0173 Starling Front-end
Details:
ComponentDetails
Connector A
Connector B
Length
Insulator
Color
Gauge
Weight
Pinout:
A
MCBL-00085
MCBL-00085-1
Description:
  • Cable providing a 10-pin JST USB + Power connection from a VOXL 2 Plug-in Board (Sierra 4G Modem, M0130) to a Doodle Labs Mesh Rider Mini RM-2025-62M3 Smart Radio Port 1 (Data) and Port 4 (Power) connectors
  • Compatible with any ModalAI 10-pin JST USB connectors on various designs,
  • Note: Only M0130 (4G Sierra Modem for VOXL 2) at this time can supply the 2A needed on VBUS for the 10W max power use case reported in the device spec by Doodle Labs. Other 10-pin format designs (M0062, M0090, M0144) will work but range may be limited.
Where Used:
  • VOXL 2 + M0090 (5G modem, <10W capable VBUS)
  • VOXL 2 + M0130 (4G Modem, 10W capable VBUS)
  • VOXL 2 + M0078 USB Debug Board (configurable VBUS)
Details:
ComponentDetails
Connector AJST 1.25mm GHR-10V-S, VOXL 2 Plug-In Board side
Connector BJST 1.25mm GHR-06V-S, Doodle Labs Helix side, Port 4, Power
Connector cJST 1.25mm GHR-04V-S, Doodle Labs Helix side, Port 1, USB Data
Length150mm
InsulatorPVC
ColorBlack (Power + GND), White/Green TP (USB)
Weight3.7 grams
Pinout:
AVOXL 2 Host (M0130, Source)BMesh Rider Mini Port4 (Power, Load)CMesh Rider Mini Port1 (USB Data)
15V VBUS (Source)1,2,35V DC (Load)--
2D---2D-
3D+--3D+
4GND4GND4GND
7GND5GND--
10GND6GND--
Image Courtesy of Doodle Labs minioem-v0323.pdf (miniOEM Mesh Rider Radio – Connector Descriptions (2023 Update)) MCBL-00085-pinout
MCBL-00086
MCBL-00086
Description:
  • Connects VOXL 2 J19 in the Sentinel Drone Platform to Holybro GPS/Magnetometer unit (Not DroneCode compliant) and pigtails for soldering to a R/C unit UART+PWR
  • The case lid is opened, supplied cable is removed, and this cable CON-B plugs in directly to the CCA inside and the case lid is re-installed.
Where Used:
  • ModalAI Sentinel Drone, with VOXL 2 and Holybro (Pixhawk) GNSS Module
Details:
ComponentDetails
Connector BJST 1.0mm SHR-10V-S-B, Module side, +3.3V signal levels
Length250mm (CONA-CONB), 150mm pigtails
InsulatorSilicone
Gauge28 AWG
Weight3.3 grams
Pinout:
2UART_TX2UART_RX
3UART_RX3UART_TX
4MAG_I2C_SCL4SCL
5MAG_I2C_SDA5SDA
6GND10GND
MCBL-00088
MCBL-00088
Description:
  • Multi-Purpose XT60 Male to Pigtail Leads, 150mm
Where used:
  • Included in Stinger ESC for system power from battery
  • Useful for ESC side or target side electronics when using an XT60 based battery
Details:
ComponentDetails
Connector AAMASS, XT60-M
InsulatorSilicon
Gauge18 AWG
Weight7.3 grams (-1 variant)
A B
+++RED
---GREEN
MCBL-00089
MCBL-00089
Description:
  • Connects VOXL 2 Mini J19 to DroneCode Compliant GPS/Magnetometer unit + ModalAI Mini ESC (M0129) UART + an R/C unit 2W UART
  • This cable provides power to the GNSS module and the R/C module at 5V (Mini ESC is powered from a battery)
    • This cable excludes the 3.3V R/C voltage on J19 pin 9
  • The 4-pin R/C port is pinned for a half-duplex UART (2 wire, TX & RX), but can alternatively be re-pinned into a 3-wire format H20 connector easily if needed. Follow the drawing .pdf link provided below to see the pinout details
    • Note the R/C port power and GND cables are spliced in the opposite direction to allow the R/C connector to fold/flow leftward of the view shown in the image/cable drawings
Where Used:
  • ModalAI Stinger Drone, with VOXL 2 Mini
  • Any fully-featured VOXL 2 Mini drone that requires the full use of J19, i.e.: a “Full Breakout of J19”
Details:
ComponentDetails
Connector AJST 1.25mm GHR-12V-S, VOXL 2 Mini side, +3.3V signal levels
Connector BJST 1.25mm GHR-06V-S, GNSS Module side, +3.3V signal levels
Connector CJST 1.25mm GHR-04V-S, to Mini ESC (M0129), +3.3V signal levels
Connector DHarwin 2.54mm M20-1060400 (Hobby format), R/C module, +3.3V signal levels
Length100mm (CONA-CONB), 80mm (CONA-CONC,COND)
InsulatorSilicone
Gauge28 AWG
Weight2.8 grams
Pinout:
AVOXL 2 MiniBGNSS ModuleCM0129 ESCDR/C Module
15V (Source)15V (Load)  3R/C 5V (Red, Load)
2UART_TX2UART_RX
3UART_RX3UART_TX
4MAG_I2C_SCL4SCL
5MAG_I2C_SDA5SDA
6GND6GND  4GND (Black)
7ESC_UART_TX  2R/C_RX
8ESC_UART_RX  3R/C_TX
10RC_UART_TX    1R/C_RX (White)
11RC_UART_RX    2R/C_TX (Yellow)
12GND  4ESC GND
Back to top
MCBL-00090
MCBL-00090
Description:
  • Voxl Ecosystem Format Serial Debug Console Cable to Host PC USB Port
  • This cable converts ModalAI “standard” 4-pin JST SRSS Debug UART port to USB using embedded FTDI adapter
Where Used:
  • All over ModalAI’s Ecosystem of Debug boards and plug-in boards, such as:
    • M0144 B-Quad (J6), M0130 New 4G Modem (J6, DNI’d), M0104 VOXL 2 MINI (J4), M0048 Microhard Modem (J2), M0030 4G Modem V2 (J2)
  • Serial Debug Port Settings at Host (115200 “8N1”):
    • 115,200 Baud
    • 8 bits
    • No Parity/Flow Control
    • 1 stop bit
Details:
ComponentDetails
Connector AUSB STD-A Plug
Connector BJST 1.0mm SHR-04V-S, +3.3V signal levels
Length1 Meter
InsulatorPVC
ColorBlack
Gauge28 AWG
Weight27.4 grams
Pinout:
APC/USBBTarget Board with Serial Debug Port
1VBUS1Not Connected
2D-2UART_RX, 3.3V Signal Levels (Green Wire = FTDI TX)
3D+3UART_TX, 3.3V Signal Levels (White Wire = FTDI RX)
4DGND4DGND
MCBL-00091
MCBL-00091
Description:
  • VOXL 2 ESC UART (4-Pin JST-GH format) Serial Port Cable to Host PC USB Port (FTDI)
  • ModalAI 3.3V Signal Level UART Port to USB using embedded FTDI adapter
Where Used:
  • All over ModalAI’s VOXL 2 Ecosystem UARTs and expansion boards and plug-in boards
  • Specifically pinned for ESC Tools Support with direct plug into M0129 ESC and future ESCs (no adapter required)
  • With ModalAI’s M0163 JST Flexi-Adapter (INSTRUCTIONS/Images AND MORE INFO COMING SOON!!!), easy re-configuration for:
    • Hardware In the Loop (HWIL/HIL) ESC UART to M0054/M0154 (VOXL 2)
    • Any Dronecode Compliant UART port (6-pin JST GH) to USB serial (Not just ModalAI hardware)
    • Any UART port (4-pin JST GH) to USB serial
Details:
ComponentDetails
Connector BJST 1.25mm GHR-04V-S, +3.3V signal levels
Length1 Meter
InsulatorPVC
ColorBlack
Gauge28 AWG
Weight26.4 grams
Pinout:
1VBUS1Not Connected
4DGND4DGND
MCBL-00092
MCBL-00092
Description:
  • JST RCY Receptacle Cable Assembly RED/BLACK, 150mm, Pigtails
Where Used:
  • General Purpose Use for Power Delivery using popular JST RCY Family Connector Series
Details:
ComponentDetails
Connector AJST RCY Receptacle, SYR-02T
Connector BPigtails, Stripped and Tinned
Length150 mm
InsulatorSilicone
ColorRed/Black
Gauge22 AWG
Weight2.1 grams
Pinout:
A B
1--BLACK
2++RED
MCBL-00093
MCBL-00093
Description:
  • JST RCY Plug Cable Assembly RED/BLACK, 150mm, Pigtails
Where Used:
Details:
ComponentDetails
Connector AJST RCY Plug, SYP-02T
Length150 mm
InsulatorSilicone
ColorRed/Black
Gauge22 AWG
Weight1.9 grams
Pinout:
A B
1--BLACK
2++RED
MCBL-00094
MCBL-00094
Description:
  • USB3 10-pin JST cable to USB2 Pigtails
Where Used:
  • Any USB2 downstream port that needs to connect to ModalAI’s 10-pin USB3 Format
  • Ideal for connecting custom hardware to the VOXL 2 Mini platform or M0090 5G Modem designs
Details:
ComponentDetails
Connector BPigtails
Length150mm
InsulatorPVC
Weight1.3 grams
Pinout:
A BPigtails
2USB_D-2D-
3USB_D+3D+
4GND4GND
5NC
6NC
7NC
8NC
9NC
10NC
MCBL-00095
MCBL-00095-1
Description:
  • VOXL-PM-Y for Legacy ToF M0169 Adapter CCA from one Power Module, with the I2C bus for power monitoring going to VOXL 2
Where Used:
Details:
ComponentDetails
Connector AMolex, 0050375043 (Power Module side, 4 wires)
Connector BMolex, 0050375043 (VOXL side, 4 wires)
Connector CJST, SFHR-02V-R (connects to M0169 CCA, 2 wires)
Length125mm (A - B), 190mm (A - C)
ColorBlack and Red
Gauge20AWG (A-to-B)/ 24AWG (A-to-C)
Weight5.9 grams
Pinout:
AVOXL 2 PMBVOXL 2CM0169 Legacy ToF CCA
15V DC (Source)15V DC (Load)15V DC (Load)
2GND2GND2GND
3SCL3PM_I2C3_SCL_5V--
4SDA4PM_I2C3_SDA_5V--
Back to top
MCBL-00098
MCBL-00098-1
Description:
  • Cable providing a partial (sub-populated) JST GH 3-pin breakout, with just pins 1 & 3.
Where Used:
  • Great for FCv1 connections with a 3-pin JST GH connector for Power and GND tap-offs
Details:
ComponentDetails
Connector AJST 1.25mm GHR-03V-S
Length150mm (10mm pigtails)
ColorBlack
Gauge26 AWG
Weight0.8 grams
Pinout:
A
1 1(pigtail)
2 -
3 3(pigtail)
MCBL-00099
MCBL-00099-1
Description:
  • Cable providing a partial (sub-populated) JST GH 4-pin breakout, with just pins 1 & 4.
Where Used:
  • Great for FCv1/FCv2 connections with a 4-pin JST GH connector for Power and GND tap-offs
Details:
ComponentDetails
ColorBlack
Gauge26 AWG
Weight0.8 grams
Pinout:
A
1 1(pigtail)
2 -
3 -
4 4(pigtail)
MCBL-00100
MCBL-00100-1
Description:
  • Cable providing a partial (sub-populated) JST GH 4-pin breakout, with just pins 2 & 3.
Where Used:
  • Great for FCv1/FCv2 connections with a 4-pin JST GH connector for UART only tap-offs
Details:
ComponentDetails
ColorBlack
Gauge26 AWG
Weight0.8 grams
Pinout:
A
1 -
2 2(pigtail)
3 3(pigtail)
4 -
MCBL-00103
MCBL-00103
Description:
  • Multi-Purpose XT60 Bulkhead Male to Pigtail Leads, 80mm
Where used:
Details:
ComponentDetails
Connector AAMASS, XT60EW-M
Length80mm (-1 variant)
InsulatorSilicon
Gauge18 AWG
Weight5.9 grams (-1 variant)
A B
+++RED
---GREEN
MCBL-00104
MCBL-00104-1
Description:
  • 6-pin JST SH to USB Type A
Where Used:
  • USB Host for configuring a Boson Sensor
Details:
ComponentDetails
Connector AUSB, Type A Male
Connector BJST, SHR-06V-S-B, 1.0mm Housing (with Protrusions), 6-POS
Length500mm
InsulatorPVC
ColorBlack, White/Green TP, Red
Weight16.8 grams
Pinout:
ASignalBSignal
2D-6D-
3D+5D+
4GND2GND
Back to top
MCBL-00105
MCBL-00105
Description:
  • 8pin-JST-to-8pin-JST cable (straight through 1:1)
Where Used:
    • “-1” 150mm.
    • “-2” is a shorter length, 100mm, used on Starling 2 drones
Details:
ComponentDetails
Connector AJST, SHR-08V-S-B, 1.00mm Housing (with Protrusions), 8-POS
Connector BJST, SHR-08V-S-B, 1.00mm Housing (with Protrusions), 8-POS
Length150mm (-1 variant), 100mm (-2 variant)
InsulatorPVC
ColorBlack
Gauge26 AWG
Weight2.9 grams (-1 variant), 2.0 grams (-2 variant)
Pinout:
A B
1Pin11Pin1
2Pin22Pin2
3Pin33Pin3
4Pin44Pin4
5Pin55Pin5
6Pin66Pin6
7Pin77Pin7
8Pin88Pin8
MCBL-00106
MCBL-00106
Description:
  • Multi-Purpose XT30U-F to Banana Jacks, 300mm
  • Easily identifiable RED (+) and BLACK (-) cables
  • Easily removable set-screw based Banana Plugs to expose stripped/tinned cable for other uses
Where used:
  • Useful for VOXL 2 Development within a Pre-Built Drone without needing a battery by using a power supply
  • CAUTION: NEVER ARM THE DRONE USING A POWER SUPPLY. THE ELECTRONICS WILL BE DAMAGED AND VOID ALL WARRANTIES
Details:
ComponentDetails
Connector AAMASS, XT30U-F
Connector BBanana Plugs, 4mm, Gold Plated, set-screw secured^
Length300mm
InsulatorSilicon
ColorRed (+) and Black (-)
Gauge14 AWG
Weight25 grams
A B
+++RED
---BLACK
^ Note: If desired, the set-screw in the side of the banana plug can be loosened to expose the bare stripped and tinned cable inside for soldering to your own format as desired. Because of this however, it may be possible for the screw to come loose over time. If intermittent power issues are suspected during normal operations, be sure to tighten this screw firmly before use. Here is an example of the cables inside the set-screw plugs:
mcbl-00106-set-screw
MCBL-00107
MCBL-00107-1
Description:
  • VOXL 2 4-pin JST USB to Boson RHP-BOS-VPC3-IF 6-JST Cable providing a direct connection from ModalAI’s USB2 ports (M0090, M0130) to a FLIR Boson that uses the RHP-BOS-VPC3-IF “backpack”
  • Note: Only picks up the USB2 bus, For the 10-pin version, see MCBL-00072 Where Used:
VOXL 2 Modem or USB expansion boards Sierra 4G Plug-ins (M0130), 5G Plug-ins (M0090)
Details:
ComponentDetails
Connector A4 POS 1.25mm JST, GHR-04V-S
Length70mm
InsulatorPVC
ColorBlack (VBUS/GND), White/Green Twisted Pair D+/D-
Weight0.9 grams
Pinout:
A B
2USB_D-6Boson D-
3USB_D+5Boson D+
4GND2GND
MCBL-00109
MCBL-00109
Description:
  • XT30U-F Power Jumper, 80mm
Where used:
  • Useful for Starling 2 Max to bypass the second battery when using MCBL-00106 with a power supply
Details:
ComponentDetails
Length80mm
InsulatorSilicon
ColorRed (+) and (-)
Gauge16 AWG
Weight2.7 grams
A A
++-- (RED)
MCBL-00110
MCBL-00110
Description:
  • Multi-Purpose XT60 Male to Pigtail Leads, 120mm
Where used:
Details:
ComponentDetails
Connector BPigtails, stripped and tinned 4mm
Length120mm
InsulatorSilicon
Gauge12 AWG
Weight12.9 grams
A B
+++RED
---BLACK
MCBL-00111
MCBL-00111
Description:
  • 8pin-JST-to-8pin-JST cable (straight through 1:1) Short Jumper Cable
Where Used:
  • VOXL Add-On boards to stacked boards where the 8-pin SPI port (or other) is desired to connect very close to VOXL 2 or Mini
    • Note this has no label on it due to its size.
Details:
ComponentDetails
Connector AJST, GHR-08V-S
Connector BJST, GHR-08V-S
Length15mm
ColorBlack
Gauge26 AWG
Weight0.8 grams
Pinout:
A B
1Pin11Pin1
2Pin22Pin2
3Pin33Pin3
4Pin44Pin4
5Pin55Pin5
6Pin66Pin6
7Pin77Pin7
8Pin88Pin8
MCBL-00112
MCBL-00112-1
Description:
  • Cable providing a full 4-pin breakout of the 4-pin MicroOne connector used on VOXL 2 Mini
Where Used:
  • Built into MDK-M0041-4-00 power module assemblies
  • Great for custom power module or ESC power pad soldering to VOXL 2 Mini systems
  • Pigtail side is tinned for ~5mm making it easy to install on solder pads
Details:
ComponentDetails
Connector AMolex 2.0mm MicroOne 2059792041
Length100mm (5mm pigtails)
InsulatorSilcon
ColorBlack
Gauge22 AWG
Weight2.8 grams
Pinout:
A B
1 1(pigtail)
2 2(pigtail)
3 3(pigtail)
4 4(pigtail)
MCBL-00113
MCBL-00113-1
Description:
  • Cable providing a sub-pop (partial) 2-pin breakout of the 4-pin MicroOne connector used on VOXL 2 Mini
  • Power Leads Only (1&2), no I2C bus cables (3&4)
Where Used:
  • Built into ESC assemblies for VOXL 2 Mini
Details:
ComponentDetails
InsulatorSilcon
ColorBlack
Gauge22 AWG
Weight1.6 grams
Pinout:
A B
1 1(pigtail)
2 2(pigtail)
3 3-
4 4-
Back to top
MCBL-00114
MCBL-00114-1
Description:
  • ModalAI Yellow 2S-6S VBAT Format End-to-End Extension Cable
Where Used:
  • Embedded within ESC and VTX/VRX Assemblies
  • Useful for general purpose JST eSFH connector hookups, with the yellow format
  • Note: Red version are ModalAI’s 5V format and Black/Grey are ModalAI’s 1S VBAT (3.8V) format
Details:
ComponentDetails
Connector A & BJST, SFHR-02V-L, 1.8mm Housing, 2-POS
Length80mm
InsulatorSilicone
ColorRed/Black
Gauge22 AWG
Weight1.0 gram
Pinout:
ASignalBSignal
1+ (Red)1+
2- (Black)2-
MCBL-00115
MCBL-00115-1
Description:
  • ModalAI Yellow 2S-6S VBAT Format to XT30 Male Adapter/Extension Cable
Where Used:
  • Useful for general purpose JST eSFH connector hookups from a 2S-6S XT30 battery, with the yellow format
  • Note: JST eSFH Red versions are ModalAI’s 5V format and Black/Grey are ModalAI’s 1S VBAT (3.8V) format
Details:
ComponentDetails
Connector AJST, SFHR-02V-L, 1.8 mm Housing, 2-POS
Connector BAMASS, XT30U-M, Male plug, 2-POS
Length100mm
InsulatorSilicone
ColorRed(+), Black (-)
Gauge22 AWG
Weight2.2 grams
Pinout:
ASignalBSignal
1+ (Red)++
2- (Black)--
MCBL-00116
MCBL-00116-1
Description:
  • ModalAI Yellow 2S-6S VBAT Format to XT60 Male Adapter/Extension Cable
Where Used:
  • Useful for general purpose JST eSFH connector hookups from a 2S-6S XT60 battery, with the yellow format
Details:
ComponentDetails
Connector AJST, SFHR-02V-L, 1.88 mm Housing, 2-POS
Connector BAMASS, XT60U-M, Male plug, 2-POS
Length100mm
InsulatorSilicone
Gauge22 AWG
Weight4.9 grams
Pinout:
ASignalBSignal
1+ (Red)++
2- (Black)--
MCBL-00117
MCBL-00117
Description:
  • Connects VOXL 2 Mini J10 SPI Port (in UART Mode) to HD Zero OSD/UART Port + Power Feed from VBAT using Pigtails
  • This cable provides power to the HD Zero from a direct VBAT solder from an ESC or other capable source
  • Note: HD Zero can pull over 13W in some power modes, be sure your VBAT power source can handle the correct HD Zero Voltage and 26AWG is suitable for the rated current
Where Used:
  • VOXL 2 Mini to add OSD to the HD Zero VTX Unit with a DroneCode Compliant UART Port
  • Stinger HD Zero Configurations
Details:
ComponentDetails
Connector AJST 1.25mm GHR-08V-S, VOXL 2 Mini UART, +3.3V signal levels
Connector BJST 1.25mm GHR-05V-S, HD Zero Side, +3.3V signal levels
Pigtails100mm Red and Black, 5mm striped and tined. 26AWG
Length100mm (CONA-CONB), 100mm (pigtails)
InsulatorFlexible PVC
ColorBlack, Red
Gauge26 AWG
Weight1.3 grams
Pinout:
AV2 MINI SideBHD ZeroPGVTX Power Source
4UART TX2UART RX
5UART RX3UART TX
8FC GND4GND1GND
 -5V+ (Load)2RED (Source)
MCBL-00118
MCBL-00118
Description:
  • Connects VOXL 2 or FCv2 Drone Code Compliant UART Port to HD Zero OSD/UART Port + Power Feed from VBAT using new VTX Format Connector
  • This cable provides power to the HD Zero from a direct VBAT tap-off using MCBL-00123 on the ESC
Where Used:
  • Any Flight Controller that needs to add OSD to the HD Zero VTX Unit with a DroneCode Compliant UART Port
Details:
ComponentDetails
Connector AJST 1.25mm GHR-06V-S, Flight Controller Side, +3.3V signal levels
Connector CMolex SL-Series Housing 701070001, VBAT
Length100mm (CONA-CONB), 65mm (CONB-CONC)
ColorBlack, Red
Gauge26 AWG
Weight3.2 grams
Pinout:
AFC SideBHD ZeroCVTX Power Source
2UART TX2UART RX
3UART RX3UART TX
6FC GND4GND2GND
 -5V+ (Load)1RED (Source)
Back to top
MCBL-00119
MCBL-00119
Description:
  • Molex SL Based PWM Device Power and PWM Feeds
  • LED Bar format, with JST SYR as power IN and Molex SL as device load
  • PWM signals as pigtails to solder onto various RC receivers with extra PWM control outputs
Where Used:
  • ModalAI Drones or for Standalone modules where a PWM type of device is needed with VBAT power from a JST SYR
  • Follows common Hobby formats for pinouts
    • Note the SYR is the ONLY ModalAI connector format with Pin 1 = GND, Pin 2 = VBAT to match hobbyist conventions
    • Note the Molex 3-pin is the ONLY ModalAI connector format with Pin 1 = Signal, Pin 2 = VBAT, and Pin 3 = GND to match hobbyist conventions
Details:
ComponentDetails
Connector AJST Red SYR 2-Pos Receptacle Housing, SYR-02T
Connector BMolex 3-Position SL Plug in PWM Format, 070107-0002
Length100mm
InsulatorSilicone
Gauge22 AWG (Power Red/Black), 28AWG (PWM signal white/black)
Weight3.1 grams
Pinout:
AVBAT SourceBPWM Device
1GND3GND, with Pigtail Splice from PWM source
2VBAT 2-6S (6.4-25.2V)2VBAT (Load)
  1Pigtail for PWM Input
MCBL-00120
MCBL-00120-1
Description:
  • 8-Pin VOXL 2 SPI JST GH to JST SH Jumper Cable
  • Plugs into VOXL 2 J10 to bring the SPI port @ 3.3V to an external peripheral in 6-pin JST SH format without extra chip selects
Where Used:
  • Sparrow for additional M0188-1 (not M0188-2) SPI Port
  • General purpose conversion of 8-Pin JST GH to 6-Pin JST SH
Details:
ComponentDetails
Connector AJST, GHR-08V-S, 1.25 mm Housing, 8-POS
Connector BJST, SHR-06V-S-B, 1.0 mm Housing (with Protrusions), 6-POS
Length75mm
ColorBlack
Gauge28 AWG
Weight1.0 grams
Pinout:
SIGNALCON A CON B
3P3V_VREG_LOCALPin11Pin1
SPI_MOSI_3P3VPin22Pin2
SPI_MOSI_3P3VPin33Pin3
SPI_SCLK_3P3VPin44Pin4
SPI_CS0_3P3VPin55Pin5
DGNDPin86Pin6
MCBL-00121
MCBL-00121
Description:
  • 10-pin JST to USBA Female/Receptacle Cable
  • 10-pin version of MCBL-00041
  • Note there are two versions of this cable
    • (-1) is nominally as shown here
    • (-2) is the same exact functional cable, but the outer insulation around the cable conductors has been trimmed back to 1/2 the overall cable length to allow for tighter installations.
Where Used:
Details:
ComponentDetails
Length~150 mm
InsulatorPVC
ColorBlack, Red, White/Green TP
Weight12.9 grams (-1), 12.3 grams (-2)
Pinout:
AVOXL 2 HOST SIDEBUSB Peripheral Side
2DATA_M2D-
3DATA_P3D+
4GND4GND
MCBL-00122
MCBL-00122-1
Description:
  • Cable providing a partial (sub-populated) JST GH 6-pin breakout, with just pins 2 & 3 & 6.
Where Used:
  • Great for FCv2 or VOXL 2 Add-in board connections with a 6-pin JST GH connector for UART only tap-offs, with a Ground wire (pin 6)
Details:
ComponentDetails
ColorBlack
Gauge26 AWG
Weight1.2 grams
Pinout:
A
1 -
2 2(pigtail)
3 3(pigtail)
4 -
5 -
6 6(pigtail)
MCBL-00123
MCBL-00123
Description:
  • 2-pin Molex SL-Series Keyed Receptacle to Pigtails
  • Red (Pin 1) and Black (Pin 2) cables for easy pin 1 identification
  • Multiple pigtail lengths to start from (60mm, 100mm, & 150mm)
Where Used:
  • ModalAI Drones with the need to a deliver low current signals (like RPM/PWM) or VBATT/GND
  • General purpose use where the need for a simple 2-Pin with keying and retention latches are needed
  • See the Mating product MCBL-00124 for a complete solution
Details:
ComponentDetails
Connector AMolex, SL-Series Receptacle, 50579402
Connector BPigtails, stripped and tinned 5mm
Length100mm (-1 variant), 150mm (-2 variant), 60mm (-3 variant)
InsulatorSiicone
ColorBlack, Red
Gauge28AWG
Weight0.6g (-1 variant), 0.8g (-2 variant), 0.5g (-3 variant)
Pinout:
A B
1Pin 1 (Red)1(Pigtail)
2Pin 2 (Black)2(Pigtail)
Pinout, Part Number, & Additional Specs: See -1 Drawing Here, See -2 Drawing Here,See -3 Drawing Here. Contact ModalAI on the Forum for .DXF or .DWG formats of this drawing.
MCBL-00124
MCBL-00124
Description:
  • 2-pin Molex SL-Series Keyed Plug to Pigtails
  • Multiple pigtail lengths to start from (100mm & 150mm)
Where Used:
  • See the Mating product MCBL-00123 for a complete solution
Details:
ComponentDetails
Connector AMolex, SL-Series Plug, 50579402
InsulatorSilcione
ColorBlack, Red
Gauge28AWG
Pinout:
A B
Back to top
MCBL-00125
MCBL-00125-1
Description:
  • ModalAI Black 3.8V 1S VBAT Format End-to-End Extension Cable
  • This new black JST SFHR format is being used as a substitute to the larger Molex MicroOne solution on some VOXL 2 Mini based designs in process
  • Note we have several variants for length as described in the table below
Where Used:
  • Useful for general purpose JST eSFH connector hookups, with the black format
  • Note: Red version are ModalAI’s 5V format and Yellow are ModalAI’s 2S-6S VBAT format
Details:
ComponentDetails
Connector A & BJST, SFHR-02V-T-K, 1.8mm Housing, 2-POS
Length75mm (-1 variant), 125mm (-2 variant), 45mm (-3 variant)
InsulatorSilicone
ColorRed/Black
Gauge22 AWG
Weight1 gram (-1 variant), 1.5 grams (-2 variant), 0.7 grams (-3 variant)
Pinout:
ASignalBSignal
1+ (Red)1+
2- (Black)2-
Pinout, Part Number, & Additional Specs: See -1 Drawing Here, See -2 Drawing Here, See -3 Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of this drawing.
MCBL-00126
MCBL-00126-1
Description:
  • ModalAI Black 3.8V 1S VBAT Format End-to-End Breakout to Pigtail Cable
  • This new black JST SFHR format is being used as a substitute to the larger Molex MicroOne solution on VOXL 2 Mini
  • Useful for soldering onto 3.8V power module pads to provide VOXL 2 Mini 1S VBAT
Where Used:
Details:
ComponentDetails
Connector AJST, SFHR-02V-T-K, 1.8mm Housing, 2-POS
Length100mm
InsulatorSilicone
ColorRed/Black
Gauge22 AWG
Weight1.1 grams
Pinout:
ASignalBPigtail
1+ (Red)1+
2- (Black)2-
Pinout, Part Number, & Additional Specs: See Drawing Here, Contact ModalAI on the Forum for .DXF or .DWG formats of this drawing.
MCBL-00127
MCBL-00127
Description:
  • New ModalAI Yellow VBAT Format to New VTX Power Format
  • Converts Yellow VBAT (2-6S) JST Payload Connectors to VTX Molex SL Plug Format
Where Used:
  • VTX Assemblies integrated into ModalAI Drones or for Standalone modules
Details:
ComponentDetails
Connector AMolex SL Series Housing 701070001 with Pin contact 16020077
Connector BJST 1.8mm SFHR-02V-L
Length65mm
InsulatorSilicone
ColorBlack, Red
Gauge24 AWG
Weight1.4 grams
Pinout:
AVBAT Payload/VTXBESC/Battery/Source
1VBAT (Load)1VBAT (Source) 2-6S (6.4-25.2V)
2GND2GND
MCBL-00128
MCBL-00128
Description:
  • Connects M0188/M0195 Sparrow/Stinger Imager Front End to Two ToF “Pill” Modules, M0189
Where Used:
  • Sparrow/Stinger Drones with Single Point ToF modules
Details:
ComponentDetails
Connector AJST 1.0mm SHR-10V-S-B, Imager Front End Side
Connector BJST 1.0mm SHR-05V-S-B, ToF Pill (M0189) Side
Connector CJST 1.0mm SHR-05V-S-B, ToF Pill (M0189) Side
Length75mm
InsulatorSilicone
ColorBlack
Gauge28 AWG
Weight1.4 grams
Pinout:
SignalCON ACON BCON C
111
222
333
444
555
66 1
77 2
88 3
99 4
1010 5
MCBL-00129
MCBL-00129
Description:
  • Connects VOXL 2 Mini J19 to ModalAI Mini ESC (M0129) UART + an R/C unit 2W (TX/RX) UART via pigtails
  • This cable provides power to the R/C module at 5V (Mini ESC is powered from a battery)
  • All pigtails are stripped and tinned for 5mm
Where Used:
  • Any fully-featured VOXL 2 Mini drone that requires J19 for ESC and R/C UARTs
Details:
ComponentDetails
Connector BJST 1.25mm GHR-04V-S, ESC side, +3.3V signal levels
InsulatorSilicone
Gauge28 AWG
Weight1.3 grams
Pinout:
AVOXL 2 MiniBM0129 ESCPigtails
15V (Source)  Red
2-
3-
4-
5-
6GND  Black
7ESC_UART_TX2UART_RX
8ESC_UART_RX3UART_TX
9-
10RC_UART_TX  White
11RC_UART_RX  Yellow
12GND4
Back to top
MCBL-00130
MCBL-00130-1
Description:
  • ModalAI 6-pin JST GGH DroneCode Compliant UART+I2C port to 3-pin JST SH for I2C
  • New 3-pin I2C format for accesory sensors (ADC, Temp, etc)
  • I2C + GND only, no power pickup
Where Used:
  • VTX assemblies with M0154 + M0130/M0090 where a sensor board exists
  • Useful for general purpose lab use to access I2C from our JST GH Dronecode formats
Details:
ComponentDetails
Connector AJST, GHR-06V-S, VOXL 2 Side
Connector BJST, SHR-03V-S-B, Sensor Board Side
Length100mm
ColorBlack
Gauge28 AWG
Weight0.6 grams
*Please note our first batch of cables did not include a label and only a temporary one is shown in the image here. Product received may or may not include a label.
Pinout:
ASignal (Host Side)BSignal (Target Side)
4SDA2SDA
5SCL1SCL
6GND3GND
MCBL-00131
MCBL-00131-1
Description:
  • New 3-pin I2C format for accesory sensors (ADC, Temp, etc) direct to 3-pin I2C
  • I2C + GND only (as intended, but can be used as 3 general purpose conductors)
  • Two variants exist:
    • (-1) is nominally 75mm in length and (-2) at 40mm in length
Where Used:
  • VTX assemblies with M0104/M0204 + M0194 where a sensor board exists
  • Useful for general purpose lab use for 3-pin JST SH
Details:
ComponentDetails
Connector AJST, SHR-03V-S-B, VOXL 2 Mini Adapter Side
Length75mm (-1), 40mm (-2)
ColorBlack
Gauge28 AWG
Weight0.5 grams (-1), 0.3 grams (-2)
Pinout:
ASignalBSignal
1111
2222
3333
Back to top
MCBL-00132
MCBL-00132-1
*Please note our first batch of (-1) variant cables did not include a label and only a temporary one is shown in the image here. Product received may or may not include a label.
Description:
  • ModalAI 4-pin MicroOne connector used on VOXL 2 Mini to Black JST (1S 3.8V format)
  • Note there are 2 variants, (-1) nominally at 80mm, and (-2) shorter length for 20mm
Where Used:
  • Embedded within VTX assemblies with M0204
  • Useful for general purpose JST eSFH connector hookups, with the black format, for VOXL 2 Mini
Details:
ComponentDetails
Connector BJST, SFHR-02V-T-K, 1.8mm Housing, 2-POS
Length80mm (-1), 20mm (-2)
InsulatorSilicone
ColorRed/Black
Gauge22 AWG
Weight1.5 grams (-1), 0.9 grams (-2)
Pinout:
ASignalBSignal
1+ (Red)1+
2- (Black)2-
Pinout, Part Number, & Additional Specs: See -1 Drawing Here, See -2 Drawing Here, Contact ModalAI on the Forum for .DXF or .DWG formats of this drawing.
MCBL-00133
MCBL-00133
Description:
  • 4pin-JST-to-4pin-JST cable (cross-over 1:1, 2:3, 3:2, 4:4)
  • Exactly like MCBL-00015-3 but with pins 2&3 swapped for Cross-over UART
Where Used:
  • JST 4-pin Applications with TX/RX to TX/RX on same pin 2&3 at each board
Details:
ComponentDetails
Length50mm
ColorBlack
Gauge26 AWG
Weight1.1 grams
Pinout:
A B
1Pin11Pin1
2Pin22Pin3
3Pin33Pin2
4Pin44Pin4
Back to top
MCBL-00137
MCBL-00137-1
Description:
  • ModalAI Yellow VBAT Format (2S-6S) Pigtail Cable, 100mm
  • This new yellow JST SFHR format is being used in places of larger XT-30 or XT-60 connectors as a micro board connector option
Where Used:
  • Useful for soldering onto power module or ESC pads to provide 2S-6S VBAT power to ModalAI products
Details:
ComponentDetails
Connector AJST, SFHR-02V-L, 1.8mm Housing, 2-POS Yellow
Length100mm
InsulatorSilicone
ColorRed/Black
Gauge22 AWG
Weight1.1 grams
Pinout:
ASignalBPigtail
1+ (Red)1+
2- (Black)2-
MCBL-00138
MCBL-00138-1
Description:
  • ModalAI PWM Type 2-B (3-pin Molex Picoblade) Cable
  • Receptacle Housing side meant for RC Receivers with 2 PWM signal outs + shared GND ref
Where Used:
  • Stinger Drone
  • Multi-length variant tuned specifically for TBS
Details:
ComponentDetails
Connector AMolex, 0510210300, 3-POS PicoBlade Receptacle Housing
Length25mm/30mm/35mm (black/purple/orange)
ColorBlack/Purple/Orange
Gauge28 AWG
Weight0.2 grams
Pinout:
ASignalBPigtails
1PWM1 (Purple) -
2GND (Black) -
3PWM2 (Orange) -
Back to top
MCBL-00146
MCBL-00146-1
Description:
  • Dual ModalAI Yellow 2S-6S VBAT Format to XT60 Male Cable
  • Just like MCBL-00116-1, but a Y-splitter
Where Used:
  • Useful for general purpose JST eSFH connector hookups from a 2S-6S XT60 battery, when there are two boards with the yellow format
Details:
ComponentDetails
Connector AAMASS, XT60U-M, Male plug, 2-POS
Connector B/CJST, SFHR-02V-L, 1.88 mm Housing, 2-POS
Length50mm (each split)
InsulatorSilicone
Gauge22 AWG
Weight5.1 grams
Pinout:
ASignal (Source)BSignalCSignal
++ (Red)1+1+
-- (Black)2-2-
MCBL-00151
MCBL-00151-1
Description:
  • 8-Pin VOXL 2 UART JST GH to JST SH Jumper Cable for Rotor Riot Brave F7
  • Plugs into VOXL 2 J10 to connect directly to the Brave F7 Flight Conteoller OSD UART Port @ 3.3V
  • RX, TX, and GND Only
    • (-1) at 75mm, and (-2) at 100mm for slightly larger frames
Where Used:
  • Customers that wish to use V2 Mini for VTX, yet BraveF7 for FC
  • ModalAI Shikra DIY Drone
Details:
ComponentDetails
Length75mm (-1), 100mm (-2)
ColorBlack
Gauge28 AWG
Weight0.6 grams (-1), 0.8 grams (-2)
Pinout:
SIGNALCON A (V2 Mini side) CON B (BraveF7 side)
UART_TXOPin44OSD_RXI
UART_RXIPin53OSD_TXO
DGNDPin86GND
MCBL-00152
MCBL-00152
Description:
  • 4pin-JST GH to 4pin-JST SH cable (straight thru: 1:1)
  • Designed for USB2 Conversion from GH ModalAI Format to SH
Where Used:
  • Any ModalAI JST 4-pin USB2 port that is required to slim down to a JST SH
Details:
ComponentDetails
Connector BJST, SHR-04V-S-B
Length50mm
InsulatorPVC
Weight0.6 grams
Pinout:
A B
1VBUS1VBUS
2D-2D-
3D+3D+
4GND4GND
MCBL-00159
MCBL-00159
Description:
  • Molex Mini-SPOX 4-Pin Power Module Format Power Cable to Doodle Labs 6-pin JST GH Format
  • Designed for powering the Doodle Labs RM-2025-62M3 when also using a data-only USB2 cable such as MCBL-00162-1
Where Used:
  • Useful for Doodle Labs or other JST 6-Pin High Current modes with 3 conductors for 5V from ModalAI’s power module, M0041.
Details:
ComponentDetails
Length100mm
InsulatorPVC
ColorBlack
Gauge20AWG to 26AWG
Weight2.1 grams
Pinout:
A B
1VDC (Source)1, 2, 35V DC (Load)
2GND4, 5, 6GND
3---
4---
Pinout, Part Number, & Additional Specs: See Drawing Here Contact ModalAI on the Forum for .DXF or .DWG formats of these drawings.
MCBL-00160
MCBL-00160
Description:
  • VOXL 2 Mini 8-Pin JST GH to DroneCode Compliant UART Port, 6-pin JST GH
  • TX/RX/GND Only
Where Used:
  • Any VOXL 2 Mini based system where a DroneCode compliant UART device is needed from J10 when in UART mode (not SPI mode)
Details:
ComponentDetails
Length100mm
ColorBlack
Gauge28AWG
Weight0.8 grams
Pinout:
AVOXL 2 MINIBDevice
1---
2---
3---
4UART_TX_OUT3UART_RX_IN
5UART_RX_IN2UART_TX_OUT
6---
7---
8GND6GND
MCBL-00162
MCBL-00162
Description:
  • USB2 Type-A Plug to 4-pin JST GH Peripheral Data Only Cable
  • Designed for a data-only USB2 solution such as a Doodle Labs RM-2025-62M3 when a Type-A Female is present on the host
  • NO VBUS, Data +/- and GND Only. This solution expects the USB peripheral is powered independantly from USB, such as with MCBL-00024-1, MCBL-00159-1, or the like.
Where Used:
  • Useful for a variety of USB peripherals that are self powered and need a host connection with a USB-A port
  • Do not confuse this with MCBL-00104 for Boson which picks up VBUS for configuration purposes, this is just DATA ONLY in a 4-pin GH format
Details:
ComponentDetails
Length200mm
InsulatorPVC
Gauge26AWG GND, 28AWG Twisted Pair Signals
Weight11.7 grams
Pinout:
A B
1VBUS1-
2D-2D-
3D+3D+
4GND4GND
Back to top
MCBL-00211
MCBL-00211-1
Description:
  • VOXL-PM-Y for FCv2 Flight Deck
  • Powers both VOXL and FlightCoreV2 from one Power Module, with the I2C bus for power monitoring going to FlightCoreV2
Where Used:
Details:
ComponentDetails
Connector BMolex, 0050375043 (VOXL side, 2 wires)
Connector CJST, GHR-04V-S (Flight Core side, 4 wires)
Length120mm
ColorBlack
Gauge20AWG (A-to-B)/ 26AWG (A-to-C)
Weight4.0 grams
Pinout:
AVOXL PMBVOXLCFlight Core V2
2GND2GND2GND
3SCL--3APM_I2C3_SCL_5V
4SDA--4APM_I2C3_SDA_5V
Back to top
MCBL-00218
MCBL-00218
Description:
  • Picks up Power on Red+Black, and Receive Signal on Orange from FlightCoreV2 to a R/C receiver 3-pin 0.1” hobby format
  • Note: This is only intended for R/C receivers and cannot power high current servos or BLDCs
Where Used:
  • Power 4-pin JST (connector B): Flight Core V2 J8 and R/C signal 4-pin JST (connector C): Flight Core J12 to 3-pin Harwin M20 Receptacle (connector A) to RC Receiver (e.g. S.Bus/FrSky)
  • Note: This is not for Spektrum, which requires +3.3V. For Spektrum, please see MCBL-00005
ComponentDetails
Connector BJST GHR-04V-S, for +5V Power/GND
Connector CJST GHR-04V-S, for UART_RX signal, +3.3V levels
Length150 mm
Gauge26 AWG
Weight1.7 grams
Pinout:
ARC ReceiverBPowerCR/C Signal
1S.Bus/DSMX (Orange)  3S.Bus/DSMX (Orange)
25V DC (Load)1RED (5V, Source)
3BLACK (GND)4GND
MCBL-00221
MCBL-00221-1
Description:
  • Picks up Power on Red+Black (from CANBUS port), and Receive Signal on Yellow (R/C Port) from FlightCoreV2 to FrSky R-XSR format R/C receiver 5-pin Picoblade format
  • Note: This is just like MCBL-00021 but for FlightCoreV2 instead of FCv1
Where Used:
  • 4-pin JST (connector B, yellow cable): Flight Core V2 J12 and 4-pin JST (connector A, Red+Black cables): Flight Core V2 J8 to 5-pin Molex Picoblade (connector C) to FrSky R-XSR Receiver
  • Note if CONA and CONB are installed in the wrong/swapped ports on FCv2, damage should not occur due to the FrSKy receiving 3.3V instead of 5V, but the UART TX of the FrSky might be over-driven by the CANBUS transceiver damaging your receiver. Please install connectors carefully.
ComponentDetails
Connector AJST GHR-04V-S, for +5V Power/GND
Length140 mm
InsulatorSilicone
Gauge26 AWG
Weight1.3 grams
Pinout:
R-XSR-Pinout
4BLACK (GND)5GND
