VOXL ToF Sensor User Guide
- Requirements
- Hardware
- Connect to VOXL
- Configure Cameras on VOXL
- Viewing the Data with voxl-portal
- Viewing the Data with ROS
Requirements
- VOXL or VOXL-Flight with VOXL System Image 3.2.0 or newer
- VOXL ToF Sensor (available here)
- If trying to visualize with ROS:
- Linux with Rviz
- Setup ROS on Host PC
- Setup ROS on VOXL
Hardware
- Ensure VOXL/VOXL-Flight is powered off
- Connect to VOXL/VOXL-Flight connector
J3
as shown (orJ2
if using concurrently with stereo cameras)
Connect to VOXL
Over ADB
adb shell
Over Wifi
- Setup and connect VOXL/VOXL-Flight
- SSH onto the target:
- VOXL IP will be 192.168.8.1 if in softap mode
- If in station mode, you will have to run
ifconfig
on voxl to see what IP your network has assigned the voxl
ssh root@IP-ADDR-OF-VOXL
oelinux123
On VOXL:
- Ensure the voxl is set up by running the following commands on voxl:
voxl-configure-cameras
Select the option that best fits your setup
Restart the camera server
systemctl restart voxl-camera-server
Ensure that voxl-camera-server and voxl-portal are running with:
voxl-inspect-services
If either are not, start them with
systemctl start voxl-camera-server
or
systemctl start voxl-portal
Once they’re both running, open a web browser on a device connected to the same network as the drone, type in the drone’s IP, click on the camera dropdown, and select one of the tof images to be shown a page like this:
voxl-portal does not currently support viewing the 3d pointcloud, but this is in the works and should be available in the coming weeks!
Configure ROS on voxl
On VOXL:
# view network information
ifconfig
- This will give you the IP address of the VOXL, configure ROS by modifying the
/home/root/my_ros_env.sh
file:
vi /home/root/my_ros_env.sh
exec bash
Configure ROS On Desktop
On Linux desktop:
- Find IP address
ifconfig
- Configure ROS environment variables, where the ROS_MASTER_URI is what you saw on the VOXL
export ROS_IP=IP-ADDR-OF-PC
export ROS_MASTER_URI=http://AAA.BBB.CCC.DDD:XYZUV/
- source variables, where xxxxxx is the ROS version you have installed
source /opt/ros/xxxxx/setup.bash
Launch Node on VOXL
roslaunch /opt/ros/indigo/share/voxl_mpa_to_ros/launch/voxl_mpa_to_ros.launch
Launch RViz on Desktop
- On the host computer, run RViz
rviz
- On the leftmost column click on the “Add” button
- In the pop-up options click on “Image”
- Change Display Name to “IR-Image”
- In the left column under “IR-Image” tab select type in Image Topic as the TOF IR Image
- Click on the “Add” button again
- Change Display Name to “Depth-Image”
- In the left column under “Depth-Image” tab select type in Image Topic as the TOF Depth Image
- “Add” PointCloud2 with TOF pointcloud topic
