How to Run MAVROS on VOXL 2 with PX4
  1. Tutorial Video
  2. Overview
  3. Block Diagram
  4. Prerequisites
    1. Install ROS Melodic
    2. Install MAVROS Dependencies
    3. Configure voxl-vision-px4 localhost
    4. Configure voxl-mavlink-server
  5. mavros_test Project (simple-example)
    1. Checklist
    2. Overview
    3. Build
    4. Configure ROS ENV
    5. Launch the simple-example Demo
Tutorial Video
This tutorial demonstrates how to fly a VOXL2 / RB5 Flight based drone autonomously in a figure 8, using MAVROS.
For this setup, MAVROS is installed and runs on VOXL 2 / RB5 Flight. Additionally, the voxl-px4, voxl-vision-px4 and voxl-mavlink-server background services will be running. This provides the PX4 flight controller, Visual Inertial Odometry (VIO) for PX4, and manages the mavlink telemetry between the ground control station remotely and ROS locally.
WARNING: At the end of this tutorial, your drone will be flying autonomously. Please only run this in a safe location away from people and wear protective eyewear!!
Block Diagram
sw-mavros
Prerequisites
Install ROS Melodic
  • Install the following packages MAVROS packages:
apt-get install ros-melodic-mavros ros-melodic-mavros-extras ros-melodic-control-toolbox
  • Install GeographicLib dataset:
cd /opt/ros/melodic/lib/mavros
./install_geographiclib_datasets.sh
Use voxl-inspect-services to validate voxl-vision-px4 is enabled.
Edit the configuration file:
vi /etc/modalai/voxl-vision-px4.conf
We will check the following
  • qgc_ip - should be your host PCs IP address where the Ground Control Station is
  • en_localhost_mavlink_udp - set to true to allow UDP MAVLink comms on localhost
  • offboard_mode - set to “off” since we will not use VVPX4 for offboard mode, but use MAVROS instead
Validate your configuration file
  "qgc_ip":                     "X.X.X.X",
  "en_localhost_mavlink_udp":   true,
  "offboard_mode":              "off"
Use voxl-inspect-services to validate voxl-mavlink-server is enabled.
Checklist
  • Make sure your drone can arm
  • Have RC transmitter bound to vehicle with ‘offboard’ and ‘manual’ mode
  • This simple-example can be done on the bench WITHOUT PROPS
This simple-example branch demo project:
  • waits for offboard mode
  • arms the vehicle
  • disarms the vehicle
Build
On VOXL 2 / RB5 Flight, clone the simple-example branch of the mavros_test project. In this example, we’re cloning to /home:
cd /home
git clone -b simple-example https://gitlab.com/voxl-public/support/mavros_test.git
Build the project:
cd /home/mavros_test
./build.sh
Base path: /home/mavros_test/catkin_ws
Source space: /home/mavros_test/catkin_ws/src
Build space: /home/mavros_test/catkin_ws/build
Devel space: /home/mavros_test/catkin_ws/devel
Install space: /home/mavros_test/catkin_ws/install
Creating symlink "/home/mavros_test/catkin_ws/src/CMakeLists.txt" pointing to "/opt/ros/melodic/share/catkin/cmake/toplevel.cmake"
Configure ROS ENV
The ros_environment.sh file contains environment variables used by ROS.
Update the ROS_IP value to use your IP address on target (you can use ifconfig):
more /home/mavros_test/ros_environment.sh
#!/bin/bash
source catkin_ws/install/setup.bash
unset ROS_HOSTNAME
# configure ROS IPs here
export ROS_MASTER_IP=127.0.0.1
export ROS_IP=192.168.8.1
# mavros needs to know what PX4's system id is
export PX4_SYS_ID=1
You can do this on bench top if you’d like, but REMOVE THE PROPELLORS as this will arm the drone!
  • Open an adb shell
  • Run the following to launch the program
./run_mavros_test.sh
You should get an output that ends similar to this:
 INFO] [1663886683.264138601]: MAVROS started. MY ID 1.240, TARGET ID 1.1
[ INFO] [1663886683.264246359]: udp0: Remote address: 127.0.0.1:38711
[ INFO] [1663886683.264606406]: IMU: Attitude quaternion IMU detected!
[ INFO] [1663886683.265673318]: IMU: High resolution IMU detected!
[ WARN] [1663886683.267312670]: GP: No GPS fix
[ INFO] [1663886683.313571850]: CON: Got HEARTBEAT, connected. FCU: PX4 Autopilot
[ INFO] [1663886683.315295002]: IMU: High resolution IMU detected!
[ INFO] [1663886683.378609250]: IMU: Attitude quaternion IMU detected!
[ INFO] [1663886684.337418988]: GF: Using MISSION_ITEM_INT
[ INFO] [1663886684.337929605]: RP: Using MISSION_ITEM_INT
[ INFO] [1663886684.338302621]: WP: Using MISSION_ITEM_INT
[ INFO] [1663886684.338667459]: VER: 1.1: Capabilities         0x000000000000e4ef
[ INFO] [1663886684.339006205]: VER: 1.1: Flight software:     01041040 (33795a0a30000000)
[ INFO] [1663886684.339548645]: VER: 1.1: Middleware software: 01041040 (33795a0a30000000)
[ INFO] [1663886684.339894838]: VER: 1.1: OS software:         04137dff (e7701b9e792e3101)
[ INFO] [1663886684.340202177]: VER: 1.1: Board hardware:      00000001
[ INFO] [1663886684.340527172]: VER: 1.1: VID/PID:             0000:0000
[ INFO] [1663886684.340860813]: VER: 1.1: UID:                 3044494530303030
[ WARN] [1663886684.341231173]: CMD: Unexpected command 520, result 0
[ INFO] [1663886687.929310850]: waiting for offboard mode
[ INFO] [1663886693.315015302]: HP: requesting home position
[ INFO] [1663886696.836791903]: RC_CHANNELS message detected!
[ INFO] [1663886698.315995312]: RP: mission received
[ INFO] [1663886698.317024880]: GF: mission received
[ INFO] [1663886698.317390396]: WP: mission received
[ INFO] [1663886703.314904662]: HP: requesting home position
[ INFO] [1663886707.538530390]: VER: 1.1: Capabilities         0x000000000000e4ef
[ INFO] [1663886707.538779396]: VER: 1.1: Flight software:     01041040 (33795a0a30000000)
[ INFO] [1663886707.538893405]: VER: 1.1: Middleware software: 01041040 (33795a0a30000000)
[ INFO] [1663886707.539031580]: VER: 1.1: OS software:         04137dff (e7701b9e792e3101)
[ INFO] [1663886707.539153506]: VER: 1.1: Board hardware:      00000001
[ INFO] [1663886707.539264337]: VER: 1.1: VID/PID:             0000:0000
[ INFO] [1663886707.539952557]: VER: 1.1: UID:                 3044494530303030
[ WARN] [1663886707.540114325]: CMD: Unexpected command 512, result 0
[ INFO] [1663886707.708296390]: VER: 1.1: Capabilities         0x000000000000e4ef
[ INFO] [1663886707.708538834]: VER: 1.1: Flight software:     01041040 (33795a0a30000000)
[ INFO] [1663886707.708672791]: VER: 1.1: Middleware software: 01041040 (33795a0a30000000)
[ INFO] [1663886707.708817060]: VER: 1.1: OS software:         04137dff (e7701b9e792e3101)
[ INFO] [1663886707.708943881]: VER: 1.1: Board hardware:      00000001
[ INFO] [1663886707.709068618]: VER: 1.1: VID/PID:             0000:0000
[ INFO] [1663886707.709161221]: VER: 1.1: UID:                 3044494530303030
[ INFO] [1663886708.451312390]: WP: seems GCS requesting mission
[ INFO] [1663886708.452393312]: WP: scheduling pull after GCS is done
[ INFO] [1663886708.566541986]: GF: seems GCS requesting mission
[ INFO] [1663886708.566864534]: GF: scheduling pull after GCS is done
[ INFO] [1663886708.610489220]: RP: seems GCS requesting mission
[ INFO] [1663886708.611010150]: RP: scheduling pull after GCS is done
[ INFO] [1663886713.314919596]: HP: requesting home position
[ WARN] [1663886713.449405269]: GP: No GPS fix
[ INFO] [1663886713.456587822]: WP: mission received
[ INFO] [1663886713.568093669]: GF: mission received
[ INFO] [1663886713.612369544]: RP: mission received
[ INFO] [1663886723.314870316]: HP: requesting home position
[ INFO] [1663886726.379315832]: arming
[ INFO] [1663886726.427174936]: FCU: Armed by external command
[ INFO] [1663886726.428385127]: Vehicle armed
[ INFO] [1663886726.476409542]: FCU: [logger] /data/px4/log/sess005/log001.ulg
[ INFO] [1663886731.379187081]: disarming
[ INFO] [1663886731.395421067]: FCU: Disarmed by external command
[ INFO] [1663886731.396092620]: Vehicle disarmed
[ INFO] [1663886731.396233503]: done
[mavros_test_node-3] process has finished cleanly
log file: /home/root/.ros/log/25b80dbe-3ac8-11ed-b22c-00c0caafc7f0/mavros_test_node-3*.log
