VOXL 2 QUPs
Together, the Qualcomm Universal Peripheral v3 and the TrustZone provide access to various protocols on various hardware interfaces. Trustzone is a necessary component that requires updates to in order to change protocol/interfaces.
Trusztone images are flashed during the system image installation (devcfg.mbn). The toolchain and source code to build the Trustzone image are unfortunately not open source.
devcfg
changing TZ configuration can brick the hardware.
this is available in System Image 1.7+ for M0104 and will ship in SDK 1.1 and is available as preview here. To use with SDK 1.0, please contact devops @ modalai .com .
- v0104.0, VOXL 2 Mini(md5sum: ccb6dedc4731aec6d80b4ef6db52fbd6)
- convert SE14 from SPI to UART for VOXL 2 Mini
| QUP | Protocol | QRB5165 GPIO | Connector/Routing | Device | Notes |
| QUP0 0x980000 | SPI | 28-31 | J6 - 34,36,38,40 | /dev/spidev0.0 | sys image 1.7+, Camera Group 0 SPI |
| QUP1 0x984000 | I2C | 4-5 | J7 - 34,36 | /dev/i2c-0 | sys image 1.7+ Camera Group 1 I2C |
| QUP2 0x988000 | I2C | 115-116 | No J3 (B2B connector) | ||
| QUP3 0x98c000 | SPI | 119-122 | U7, | /dev/spidev3.0 | sys image 1.7+, Onboard IMU1, 42688p |
| QUP4 0x990000 | |||||
| QUP5 0x994000 | UART | 12-15 | No J8 (Camera Group 2) | ||
| QUP6 0x998000 | HS UART | ||||
| QUP7 0x99c000 | HS UART | 22-23 | No J3 (B2B connector) | ||
| QUP8 0xa80000 | NA | ||||
| QUP9 0xa84000 | I2C | 125-126 | No J3 (B2B connector) | ||
| QUP10 0xa88000 | I2C | 129-130 | No J3 (B2B connector) | ||
| QUP11 0xa8c000 | SPI | 60-63 | No J5 (B2B connector) | ||
| QUP12 0xa90000 | debug | 34-35 | Not in perf build | sys image 1.7+, Debug Console (2W UART, 115200 baud) | |
| QUP13 0xa94000 | UART | No J5 (B2B connector) | |||
| QUP14 0x880000 | SPI | 40-43 | J10, apps proc | /dev/ttyHS0 | sys image 1.3+, External SPI J10 |
| QUP15 0x884000 | I2C | 44-45 | |||
| QUP16 0x888000 | NA | ||||
| QUP17 0x88c000 | NA | ||||
| QUP18 0x890000 | NA | ||||
| QUP19 0x894000 | HS UART | 2-3 | No J5 (B2B connector) |
Current Version (0008)
this version works with M0104 SDK 1.0
- M0054 v0008, VOXL 2(md5sum: ccb6dedc4731aec6d80b4ef6db52fbd6)
- used in VOXL2 system image 1.5+
- convert qup1 from SPI to I2C to expose apps_proc I2C on camera group
| QUP0 0x980000 | SPI | 28-31 | J6 - 34,36,38,40 | /dev/spidev0.0 | sys image 1.3+, Camera Group 0 SPI |
| QUP1 0x984000 | I2C | 4-5 | J7 - 34,36 | /dev/i2c-4 | sys image 1.5+ Camera Group 1 I2C |
| QUP2 0x988000 | I2C | 115-116 | J5 - 8,9 | /dev/i2c-0 | HS B2B I2C2 |
| QUP3 0x98c000 | SPI | 119-122 | U7, J5 | /dev/spidev3.0 | sys image 1.3+, Onboard IMU1, 42688p. Shared with the IMU, see note below |
| QUP4 0x990000 | I2C | 8-9 | J5 - 98,99 | /dev/i2c-5 | sys image 1.7+, HS B2B I2C |
| QUP5 0x994000 | UART | 12-15 | J8 - 34,36,38,40 | /dev/ttyHS0 | sys image 1.4+, Camera Group 2 UART |
| QUP7 0x99c000 | HS UART | 22-23 | J3 - 3,5 | /dev/ttyHS1 | sys image 1.3+, B2B 2W UART |
| QUP9 0xa84000 | I2C | 125-126 | J3 - 13,15 | /dev/i2c-1 | sys image 1.3+, B2B I2C9 |
| QUP10 0xa88000 | I2C | 129-130 | J3 - 23,25 | /dev/i2c-2 | sys image 1.3+, B2B I2C10 |
| QUP11 0xa8c000 | SPI | 60-63 | J5 - 53,56 | /dev/spidev11.0 | sys image 1.5+, HS B2B SPI |
| QUP12 0xa90000 | debug | 34-35 | J3 - 27,29 | Not in perf build | sys image 1.3+, Debug Console (2W UART, 115200 baud) |
| QUP13 0xa94000 | UART | 38-39 | J5 - 97-98 | /dev/ttyHS3 | sys image 1.5+, HS B2B UART |
| QUP14 0x880000 | SPI | 40-43 | J10, apps proc, | /dev/spidev14.0 | sys image 1.3+, External SPI J10 |
| QUP15 0x884000 | I2C | 44-45 | /dev/i2c-3 | (internal use) | |
| QUP19 0x894000 | HS UART | 2-3 | J5 - 48,49 | /dev/ttyHS2 | sys image 1.3+, HS B2B 2W UART |
SPI3 (QUP3) is shared with the onboard ICM-42688 IMU. The bus is routed both to the IMU and to J5 (GPIO_119 to GPIO_122). The controller exposes a single native chip select, wired to the IMU, and asserts it on every transfer, so any transfer to a second device on SPI3 also selects the IMU. The
SPI_NO_CSmode flag is rejected by the kernel on this platform, so the native chip select cannot be suppressed from user space. Do not plan on sharing SPI3 with a second SPI device. Use a different bus instead; enabling SPI11 (QUP11) on J5 is the recommended option. Contact ModalAI on the forum before committing to a design that depends on SPI3.
Version 0007
- M0054 VOXL2 - md5sum: 77366973052c03ce3eab57c1e92b490a
- used in system image 1.5+
- enable qup2: I2C, for HS B2B J5 pins 8/9, support for M0130 add-on I2C on J8
- enable qup11: SPI, for HS B2B J5 pins 53/56, support for M0130 add-on SPI on J8
- enable qup13: UART, for HS B2B J5 pins 36-39
Version 0006
- version 6, M0054-VOXL2 - md5sum: 3698389194c899953c4e337a7b48cb97
- used in system image 1.3+
- enable qup7: 2W UART, for B2B J3 pins 3/5, support for M0125 add-on UART
- M0052-RB5-FLIGHT md5sum: cf613de37db6e7d2bb245f4d17cab79e
Deltas from M0054 version 6 above:
| QUP | Protocol | QRB5165 GPIO | Notes | Connector/Routing | Device |
| QUP5 0x994000 | UART | 12-15 | Camera Group 2 UART | J8 - 34,36,38,40 | /dev/ttyHS3 |
| QUP6 0x998000 | HS UART | SOM WiFi | internal | /dev/ttyHS0 | |
| QUP7 0x99c000 | HS UART | 22-23 | B2B 2W UART | J3 - 3,5 | /dev/ttyHS4 |
| QUP13 0xa94000 | UART | 38-39 | PX4 RC input | apps_proc, M0052-J12 | /dev/ttyHS1 |
| QUP18 0x890000 | UART | 58-59 | PX4 GNSS | apps_proc, M0052-J10 | /dev/ttyHS2 |
| QUP19 0x894000 | HS UART | 2-3 | HS B2B 2W UART | J5 - 48,49 | /dev/ttyHS5 |
