VOXL 2 Mini - D0013 Architecture (Stinger)
Hardware
VOXL2 Mini
The Stinger D0013-6-C33-M26-X8 configuration consists of:
D0013-6- Stinger Family (VOXL2 Mini Compute)M0129-3VOXL ESC Mini with built in power managementM0187FLIR Lepton 3.5 thermal sensor using M0188
Cxx- Camera ConfigTx- Recevier ConfigT8- ELRS
XxX8- Lepton for Tracking
Block Diagram
Below describes the compute HW block diagram for the D0013-6-C33-M26-X8 configuration.
Software
- Supported VOXL SDK: 1.4+
- Supported Kernels (config 2):
m0104-1-var00.2-kernel.img
Platform Features
MSP_DP OSD Support for Non-ModalAI VTX (HD-zero or Walksnail)
- MSP Display Port OSD support for HDZero (PX4 driver)
- PX4 OSD Params for FrSky Skyvision (here)
VOXL2 Driven Image Sensor Synchronization
In the D0013 architecture using the M0188 breakout, the following occurs for the tracking sensors:
- The voxl-fysnc-mod ships in SDK 1.3+ and defaults to use GPIO 109, 30Hz, and disabled.
- When a C22 image sensor configurations is setup using
voxl-configure-cameras, the config file at/etc/modalai/voxl-camera-server.confis setup with:
"fsync_en": true,
"fsync_gpio": 109,
- When camera server runs, it will use the
voxl-fsync-modparams exposed to the file system at/sys/module/voxl_fsync_mod/parameters, for exampleenabled,gpio_num, and enable the sync pulse at the default 30Hz. - When a C22 image sensor configurations is setup using
voxl-configure-cameras, theAR0144drivers are copied into/usr/lib/camerathat are setup for slave mode and will capture sychronized frames at the rate defined (note: the FPS should also be configured in/etc/modalai/voxl-camera-server.confaccordinly to ensure proper register settings are loaded)
Note: the following shows M0173 which has similar architecture as M0188.
FLIR Lepton
In the D0013 architecture using the M0188 breakout:
(NOTE: in SDK 1.4.0, only one can be used at a time)
- VL53L1CX Range Finder is accesible over
/dev/i2c-0, see/etc/modalai/voxl-rangefinder-server.confandvoxl-rangefinder - FLIR Lepton is accesible over
/dev/i2c-0and/dev/spidev0.0, see/etc/modalai/voxl-lepton-server.confandvoxl-lepton-server- note see (M0188) docs for details as I2C channel selector is also in use here
New Kernel Configuration for M0188
The D0013 drone family uses the new kernel config 2 (as opposed to config 0). See /sys/module/voxl_platform_mod/parameters/config to verify proper kernel config.
