VOXL 2 IO Legacy Guide
To help with searching in our docs, the VOXL 2 IO board will be called legacy PX4IO based board
VOXL SDK Requirements
This is not valid for VOXL SDK 1.1.1 or newer. See here for newer guide.
This is accurate for SDK 0.9.5, and there were some breaking changes in SDK 1.0 when the PX4IO driver dropped from mainline PX4.
- SDK 1.1.0 - no change
- SDK 1.0.1 - PX4 1.14, no PWM support, SBUS RC input support only
- SDK 0.9.5 - PX4 1.12, basic 4 channel support, see following documentation
The legacy PX4IO based board requires a host running PX4 running the px4io module, such as VOXL 2. The IO board provides PWM outputs (8) and expands the native Spektrum RC support by adding S.BUS support (and provides passthrough Spektrum as well).
The IO board is powered from and communicates via VOXL 2’s RC port. The VOXL 2 communicates to the legacy PX4IO based board using a UART connection.
Limitations
Supported Mixers and Airframe Setup
Airframe selection via QGroundControl is not supported.
This has validated against quad_x and hex_x airframes only. In the current release, configuring the mixer is done manually by editing the /usr/lib/rfsa/adsp/quad_x_io.main.mix file.
Quad:
R: 4x 10000 10000 10000 0
Hex:
R: 6x 10000 10000 10000 0
UART ESC Compatibility
This has not been validated to be used in parallel to the ModalAI UART ESC yet to expose additional PWM channels while also using the ModalAI UART ESC.
PX4 Parameters
The defaults set by voxl-px4-set-default-parameters.config. Ensure you vehicle is configured correctly.
CBRK_IO_SAFETY 22027
PWM_MAIN_MAX 2000
PWM_MAIN_MIN 1060
PWM_MAIN_RATE 400
PWM_MAIN_DISARM 900
Spektrum RC Binding
The Spektrum bind feature invoked via QGroundControl does not work and needs to be ran manually from VOXL2. To enable Spektrum bind:
Connect to VOXL 2’s shell:
adb shell
Run the following commands to put Spektrum RC in bind mode.
px4-qshell px4io safety_on
px4-qshell px4io bind dsmx8
PWM ESC Calibration
NOTE: the following feature is still in beta.
For this process to work, you need to have physical access to J1 (PWM output port).
Use with caution, as this will be setting PWM outputs which could spin motors inadvertently.
REMOVE ALL PROPS. REPEAT: REMOVE ALL PROPS
Using the Sentinel drone with PWM based ESCs as an example:
- Power off the drone
- Remove the PWM cable from legacy PX4IO based connector J1
- Power on the drone
- adb or ssh onto the drone
- get prepared to re-attach the cable (but not yet)
After you do the next step, you have 10 seconds to connect the PWM cable back to J1.
- from the terminal, run
px4-qshell pwm cal_backdoor
Note: you will see an timeout error message, this is OK, for example:
voxl2:/$ px4-qshell pwm cal_backdoor
INFO [qshell] Send cmd: 'pwm cal_backdoor'
ERROR [qshell] command timed out
ERROR [qshell] Command failed
- re-attach the cable, ESCs will make a short power on jingle
- in 10 seconds, a set of beeps being lasting several seconds
- after the jingles are done, you are done
Here’s the waveform generated over time:
And the same in video, for fun ;)
VOXL 2 Firmware Update
The Firmware Update feature from host to legacy PX4IO based board is currently not supported.
Wiring Guides
Host Connection
VOXL 2 as Host (M0054)
From VOXL2, connect J19 pins 9-12 to VOXL2 IO J4 pins 1-4 as shown here:
| VOXL 2 | legacy PX4IO based board |
| J19 Pin 9 - 3P3V | J4 Pin 1 - 3P3V_IO |
| J19 Pin 10 - Host TX | J4 Pin 2 - IO RX |
| J19 Pin 11 - Host RX | J4 Pin 3 - IO TX |
| J19 Pin 12 - GND | J4 Pin 4 - GND |
RB5-Flight as Host (M0052)
| RB5-Flight | legacy PX4IO based board |
| J12 Pin 1 - 3P3V | J4 Pin 1 - 3P3V_IO |
| J12 Pin 2 - Host TX | J4 Pin 2 - IO RX |
| J12 Pin 3 - Host RX | J4 Pin 3 - IO TX |
| J12 Pin 4 - GND | J4 Pin 4 - GND |
RC Connections
Using S.BUS (FrSky R-XSR)
In the following example, the FrSky R-XSR receiver is being used with MCBL-00065-1:
Using S.BUS (Graupner GR-16)
In the following example, the Graupner GR-16 receiver is being used has had it’s channel 8 setup as SBUS with MCBL-00064-1:
Using Spektrum (DSMX)
In the following example, the Spektrum SMX-SPM9745 receiver is being used with MCBL-00005-1:
PWM Connection
In the following example, the PWM Breakout Board (MCCA-M0022) and cable (MCBL-00004-1) are used to expose PWM based actuation:
Modes and LED Patterns
The legacy PX4IO based board can be in the following modes accompanied with a unique LED pattern.
- Bootloader Mode
- Application Running in Waiting Mode
- Application Running in Standard Mode
- Firmware update mode
- Communication error mode
Bootloader Mode
For the first 200ms after power on, the legacy PX4IO based board is in bootloader mode. The serial firmware update could be performed during this time.
Note: this mode is very short lived an almost not perceptible to the eye.
| legacy PX4IO based board LED | State | Meaning |
| Green | Solid | Power Good |
| Blue | Off | Application not running |
| Orange | Fast Blink (10Hz) | In bootloader mode |
When the system is running and communications with VOXL 2 have not started and it is waiting, the following LED pattern can be seen.
| Blue | Blink Slow (2Hz) | Application running OK |
| Orange | Solid | Warning, waiting for VOXL 2 |
When the system is running, the following LED pattern can be seen.
| Orange | Off | No error or warning |
Firmware Update Mode
When the system is in firmware update mode, the following LED pattern can be seen.
| Blue | Fast Blink (10Hz) | Firmware update in progress |
Communication Error Mode
When communication errors occur, the following LED pattern can be seen.
Note: early RB5 based releases showed this mode when acting as an RC passthrough.
| Blue | Blink Slow (2Hz) | Communication with VOXL 2 OK |
| Orange | Mediaum Blink (4Hz) | Warning, not getting actuation messages |
Developer Guide
This is not valid for VOXL SDK 1.1.1 or newer. See (here)[/voxl2-io-user-guide/] for newer guide.
This is valid for VOXL SDK 0.9.5 - 1.1.0.
Hardware
- A battery powers VOXL2 (
M0054) through a Power Module (M0041), and the battery also powers the ESCs/Motors - VOXL2 J19 connects to VOXL2 IO J4 to provide both power and communications using a UART
- VOXL2 IO connects to an RC receiver (either J2 or J3, depending on user’s receiver type)
- VOXL2 IO J1 connects to a PWM breakboard board (
M0022) and ‘communicates’ to the ESCs using PWM, which in turn spin the motors
Software
High Level Idea
VOXL2 runs PX4 and VOXL2 IO runs PX4IO. They share a register map and keep it synchronized. The VOXL2 IO has a control loop that includes mixing, and reacts to updates that are from VOXL2s px4io driver which populates the register map based updates to subscriptions.
Running on VOXL2
- On VOXL2 (
M0054), thepx4iodriver runs on the sDSP/SLPI proc - The
px4iodriver creates a bit of a hybrid device which has a few similarities aspwm_outputdevice - The
voxl-px4.configscript starts the detection and configuration process, including loading a mixer, which actually runs on VOXL2 IO (M0065) - The
px4iodriver subscribes to various topics and updates the ‘registers’ on the VOXL2 IO board by sending commands over UART following a simple protocol
Running on VOXL2 IO
- Upon bootup, VOXL2 (
M0054) detects the VOXL2 IO (M0065) board, and configures the VOXL2 IO board including loading of a mixer - A control loop takes place, which involves checking various flags, updating status based upon updates from VOXL2, checking for inputs, handling outputs, etc
PX4IO Based Firmware
Note: this is no longer maintained. See here for newer information.
Bootloader
Build
| Component | Notes |
| Build Docker | https://gitlab.com/voxl-public/flight-core-px4/px4-bootloader-build-docker |
| Source Code | https://github.com/PX4/PX4-Bootloader.git |
To build:
git clone https://gitlab.com/voxl-public/flight-core-px4/px4-bootloader-build-docker
cd px4-bootloader-build-docker
./docker-build-image.sh
cd ..
git clone -b https://github.com/PX4/PX4-Bootloader.git --recursive
cd px4-bootloader
cp ../px4-bootloader-build-docker/docker-run-image.sh .
./docker-run-image.sh
make modalai_voxl2_io_bl -j4
Output at build/modalai_voxl2_io_bl/modalai_voxl2_io_bl.bin
Flash
Write the 4kb bootloader to 0x08000000
Application
Build
| Component | Notes |
| Build Docker | https://gitlab.com/voxl-public/flight-core-px4/px4-stm32-build-docker.git |
| Source Code | https://github.com/modalai/px4-firmware/tree/voxl2-io |
To build:
cd px4-stm32-build-docker
cd ..
git clone -b voxl2-io-1.11 https://github.com/modalai/px4-firmware --recursive
cd px4-firmware
cp ../px4-stm32-build-docker/docker-run-image.sh .
make modalai_voxl2-io
Output at build/modalai_voxl2-io/modalai_voxl2_io.bin
Flash
Write the 60kb application to 0x08001000
