VOXL 2 Connectors
  1. Video Overview of Connectors
  2. Connector Callouts
    1. Add-on Board to Board Design Package
  3. Buttons
    1. SW1 - Force Fastboot Button
    2. SW2 - EDL Switch
  4. Pinouts
    1. J2 - 5VDC Fan Control
    2. J3 - Legacy Board to Board Connector (B2B)
      1. J3 Pin-out
    3. J4 - Power Connector / I2C Battery Monitoring
      1. Input Power Requirements
    4. J5 - High Speed Board to Board Connector (HSB2B)
      1. J5 Pin-out
    5. Camera Group J6, J7, and J8 Pin-outs
      1. General Pin-out
      2. J6 - Camera Group 0 Specific Pinout
        1. J6 Pin-out
      3. J7 - Camera Group 1 Specific Pinout
        1. J7 Pin-out
      4. J8 - Camera Group 2 Specific Pinout
        1. J8 Pin-out
    6. J10 - External SPI
      1. Overview
      2. J10 Pin-out, SPI Mode (Fixed), M0054
      3. J10 Pin-out, SPI Mode (GPIO_67 = HIGH), M0154
      4. J10 Pin-out, UART Mode (GPIO_67 = LOW), M0154
    7. J18 UART (ESC)
      1. J18 ESC UART
      2. SW Summary
    8. J19 - External Sensors (2x UART/ 2x I2C)
      1. J19 Pin-out
      2. SW Summary
    9. I2C Important Note:
    10. Power Input/Output Important Note:
Connector Callouts
Hover a connector to identify it — click to jump to its pinout.
VOXL 2 connector callouts, top and bottom views
All single ended signals on B2B connectors J3, J5, J6, J7, and J8 are 1.8V CMOS unless explicitly noted. All single ended signals on cable-to-board connectors J10, J18, & J19 are 3.3V CMOS unless explicitly noted.
ConnectorDescriptionMPN (Board Side)Mating MPN (Board/Cable Side)TypeSignal Feature Summary
J2FanSM02B-SRSS-TB(LF)(SN)SHR-02V-SCable Header, 2-pin R/A5V DC for FAN + PWM Controlled FAN-Return (GND)
J3Legacy B2BQSH-030-01-L-D-K-TRQTH-030-01-L-D-A-K-TRB2B Receptacle, 60-pin5V/3.8V/3.3V/1.8V power for plug-in boards, JTAG and Debug Signals, QUP expansion, GPIOs, USB3.1 Gen 2 (USB1)
J4Prime Power In220570450050375043Cable Connector, 4-pin R/A+5V main DC power in + GND, I2C@5V for power monitors
J5High Speed B2BADF6-30-03.5-L-4-2-A-TRADM6-30-01.5-L-4-2-A-TRB2B Socket, 120-pinMore 3.8V/3.3V/1.8V power for plug-in boards, 5V power in for “SOM Mode”, QUP expansion, GPIOs, SDCC (SD Card V3.0), UFS1 (secondary UFS Flash), 2L PCIe Gen 3, AMUX and SPMI PMIC signals
J6Camera Group 0DF40C-60DP-0.4V(51)DF40C-60DS-0.4VB2B Plug, 60-pinQty-2 4L MIPI CSI ports, CCI and camera control signals, 8 power rails (from 1.05V up to 5V) for cameras and other sensors, dedicated SPI (QUP) port
J7Camera Group 1DF40C-60DP-0.4V(51)DF40C-60DS-0.4VB2B Plug, 60-pinQty-2 4L MIPI CSI ports, CCI and camera control signals, 8 power rails (from 1.05V up to 5V) for cameras and other sensors, dedicated SPI (QUP) port
J8Camera Group 2DF40C-60DP-0.4V(51)DF40C-60DS-0.4VB2B Plug, 60-pinQty-2 4L MIPI CSI ports, CCI and camera control signals, 8 power rails (from 1.05V up to 5V) for cameras and other sensors, dedicated SPI (QUP) port
J9USB-C (ADB)UJ31-CH-3-SMT-TRUSB Type-CCable Receptacle, 24-pin R/AADB USB-C with re-driver and display port alternate mode (USB0)
J10SPI ExpansionSM08B-GHS-TB(LF)(SN)GHR-08V-SCable Header, 8-pin R/ASPI@3.3V with 2 CS_N pins, 32kHz CLK_OUT@3.3V
J18ESC (SLPI Access)SM04B-GHS-TB(LF)(SN)GHR-04V-SCable Header, 4-pin R/AESC UART@3.3V, 3.3V reference voltage
J19GNSS/MAG/RC/I2C (SLPI Access)SM12B-GHS-TB(LF)(SN)GHR-12V-SCable Header, 12-pin R/AGNSS UART@3.3V, Magnetometer I2C@3.3V, 5V, RC UART, Spare I2C
Reference add-on board Altium schematic package can be downloaded here
Buttons
Force Fastboot momentary button.
To force device into fastboot mode:
  • power off device, remove USB cable to completely power down
  • press and hold SW1 button down
  • power on device, attach USB cable
  • release SW1 button
  • from host computer, run fastboot devices and verify the device shows up. If not, restart this procedure
To reboot device to fastboot:
  • device is powered on
  • press and hold SW1 for 30 seconds until the device reboots into fastboot mode
SW2 - EDL Switch
Emergency Download switch, used for factory flashing. Should be left OFF. See user guide for QDL if interested in more information.
Pinouts
Pin #Signal NameNotes
1VDC_5V_LOCAL5V protected power output *
2FAN RETURN (GND)Return limited to ~400mA
Currently Supported Legacy Add-Ons:
  • M0017 USB Debug Add-On
  • M0030 LTE Modem Add-On
  • M0048 Microhard Modem Add-On
The Legacy Board to Board connector is designed to host VOXL Add-ons such as the LTE Add-on v2 and the Microhard Add-on.
ConnectorMPN
Board ConnectorQSH-030-01-L-D-K-TR
Mating ConnectorQTH-030-01-L-D-A-K-TR
J3 Pin-out
Odd Pin #Signal/VoltageEven Pin #Signal/Voltage
1DGND2VDC_5V_LOCAL
3GPIO_23_UART7_RXD, /dev/ttyHS14VDC_5V_LOCAL
5GPIO_22_UART7_TXD, /dev/ttyHS16VDC_5V_LOCAL
7GPIO_52_SPI17_MISO8USB1_HS_ID_LEGACY (Normally N.C.)
9GPIO_53_SPI17_MOSI10DGND
11DGND12USB1_HS_DM
13GPIO_126_I2C9_SCL14USB1_HS_DP
15GPIO_125_I2C9_SDA16VDC_5V_LOCAL_USB1
17GPIO_55_SPI17_CS18DGND
19GPIO_54_SPI17_SCLK20USB1_SS_TX_M
21DGND22USB1_SS_TX_P
23GPIO_130_I2C10_SCL, /dev/i2c-124GPIO_20
25GPIO_129_I2C10_SDA, /dev/i2c-126GPIO_21
27GPIO_35_DBG_UART12_RX28GPIO_32_QUP12_L0
29GPIO_34_DBG_UART12_TX30GPIO_33_QUP12_L1
31DGND32USB1_SS_RX_M
33JTAG_SRST_N34USB1_SS_RX_P
35JTAG_TCK36DGND
37JTAG_TDI38GPIO_131_USB_HUB_RESET
39JTAG_TDO40GPIO_124
41JTAG_TMS42GPIO_145
43JTAG_TRST_N44DGND
45JTAG_PS_HOLD46GPIO_90_FAST_BOOT_3
47VREG_S4A_1P848GPIO_76_FAST_BOOT_2
49PM_RESIN_N50GPIO_47_SPI14_CS2_FAST_BOOT_1
51SDM_RESOUT_N52GPIO_27_FAST_BOOT_0
53VREG_3P3V_LOCAL54GPIO_128_WDOG_DIS
55KPD_PWR_N56SDM_FORCE_USB_BOOT
57VPH_PWR58DGND
59DGND60CLK_PMK_PMIC
For use with VOXL Power Module
Pin#SignalNotes/Usage
1VDCIN_5VDC from Power Module, “unprotected”
2GNDPower Module Return
3I2C_CLKslpi_proc, SSC_QUP_1, 5V signal levels, Pullups on Power Module
4I2C_SDAslpi_proc, SSC_QUP_1, 5V signal levels, Pullups on Power Module
The VOXL Power Module provides the needed voltage and current demands of both VOXL (5V), VOXL 2 (5V), and VOXL 2 Mini (3.8V). It is a well tested and proven design.
For VOXL 2, we5V +/- 5% is expected to keep the eFuse happy. The VOXL Power Module is set for 5.08V at no-load to help compensate for any cable drops. 6A of in-rush support is required during power-on. The steady-state current requirement depends on your application and if a plug-in board (5G modem, Microhard, etc) is connected.
If you design with a 3A DC/DC, you will likely not be able to boot the system due to power on in-rush. Please use a 6A device for success with at least 188uF of bulk capacitance (qty-4 47uF for example) to match the VOXL Power Module performance.
If one needs to design their own power module, please submit a PCB review on our forum here
Currently Supported Add-Ons:
  • M0062 - Debug/PCIe Add-On
  • M0067 - 5G Add-On
  • M0090 - 5G Add-On
ConnectorMPN
Board ConnectorADF6-30-03.5-L-4-2-A-TR
Mating ConnectorADM6-30-01.5-L-4-2-A-TR
J5 Pin-out
PinSignal/VoltagePinSignal/VoltagePinSignal/VoltagePinSignal/Voltage
A1 (1)VDCIN_5VB1 (31)VDCIN_5VC1 (61)VDCIN_5VD1 (91)VDCIN_5V
A2VDCIN_5VB2VDCIN_5VC2VDCIN_5VD2VDCIN_5V
A3GNDB3GNDC3GNDD3GND
A4GNDB4GNDC4GNDD4GND
A5VREG_3P3V_LOCALB5GNDC5GPIO_119_SPI3_MISOD5GPIO_36_UART13_CTS
A6VREG_3P3V_LOCALB6GNDC6GPIO_120_SPI3_MOSID6GPIO_37_UART13_RTS
A7GNDB7GPIO_16_QUP6_L0C7GPIO_121_SPI3_SCLKD7GPIO_38_UART13_TXD
A8GPIO_115_I2C2_SDAB8GPIO_17_QUP6_L1C8GPIO_122_SPI3_CSD8GPIO_39_UART13_RXD
A9GPIO_116_I2C2_SCLB9GPIO_18_QUP6_L2C9GPIO_24_I2C8_SDAD9GPIO_8_I2C4_SDA
A10GPIO_117_QUP2_L2B10GPIO_19_QUP6_L3C10GPIO_25_I2C8_SCLD10GPIO_9_I2C4_SCL
A11GPIO_118_QUP2_L3B11GPIO_155C11GNDD11PM8250_AMUX1
A12SD_UFS_CARD_DET_NB12GPIO_154C12GPIO_145 (intentional duplicate to Legacy B2B pin 42)D12GND
A13GNDB13GPIO_153C13GPIO_144D13PCIE2_REFCLK_M
A14SDC2_CLKB14GPIO_152C14GPIO_143D14PCIE2_REFCLK_P
A15GNDB15GNDC15GPIO_142D15GND
A16VREG_L9C_2P96B16GPIO_0_QUP19_L0C16GPIO_137D16PCIE2_RX0_M
A17SDC2_CMDB17GPIO_1_QUP19_L1C17GNDD17PCIE2_RX0_P
A18SDC2_DATA_0B18GPIO_2_QUP19_L2, /dev/ttyHS2C18GPIO_88D18GND
A19SDC2_DATA_1B19GPIO_3_QUP19_L3, /dev/ttyHS2C19GPIO_89D19PCIE2_RX1_M
A20SDC2_DATA_2B20GPIO_56_I2C18_SDAC20GPIO_87_PCIE2_WAKE_ND20PCIE2_RX1_P
A21SDC2_DATA_3B21GPIO_57_I2C18_SCLC21GPIO_86D21GND
A22GNDB22GNDC22GPIO_85D22PCIE2_TX0_M
A23UFS1_REFCLKB23GPIO_60_QUP11_L0C23GNDD23PCIE2_TX0_P
A24GNDB24GPIO_61_QUP11_L1C24PMIC_8150L_AMUX1D24GND
A25UFS1_TX0_MB25GPIO_62_QUP11_L2C25GNDD25PCIE2_TX1_M
A26UFS1_TX0_PB26GPIO_63_QUP11_L3C26GNDD26PCIE2_TX1_P
A27GNDB27GNDC27GNDD27GND
A28UFS1_RX0_MB28SPMI_CLKC28VPH_PWR_3P8VD28GND
A29UFS1_RX0_PB29SPMI_DATAC29VPH_PWR_3P8VD29VREG_S4A_1P8
A30 (30)GNDB30 (60)GNDC30 (90)VPH_PWR_3P8VD30 (120)VREG_S4A_1P8
General Pin-out
Generic camera group pinout, please work with ModalAI for any mating designs to gauranteee proper operation
Pin#Signal
1GND
2GND
3Lower CCI_I2C_SDA
4DVDD 1.2V
5Lower CCI_I2C_SCL
6DOVDD 1.8V
7GND
8DVDD 1.05V
9Lower CSI_CLK_P
10Lower RST_N
11Lower CSI_CLK_M
12Lower MCLK
13Lower CSI_DAT0_P
14GND
15Lower CSI_DAT0_M
16Lower CCI Timer
17GND
18Upper CCI Timer
19Lower CSI_DATA1_P
20Upper MCLK
21Lower CSI_DATA1_M
22AVDD 2.8V
23Lower CSI_DATA2_P
24GND
25Lower CSI_DATA2_M
26Upper RST_N, Shared
27GND
28Upper CCI_I2C_SDA
29Lower CSI_DATA3_P
30Upper CCI_I2C_SCL
31Lower CSI_DATA3_M
32Spare MCLK/GPIO
33GND
34Group SPI MISO (groups 0/1)
35Upper CSI_CLK_P
36Group SPI MOSI (groups 0/1)
37Upper CSI_CLK_M
38Group SPI SCLK (groups 0/1)
39Upper CSI_DATA0_P
40Group SPI CS_N (groups 0/1)
41Upper CSI_DATA0_M
42VREG_S4A_1P8
43GND
44GND
45Upper CSI_DATA1_P
46VPH_PWR 3.8V
47Upper CSI_DATA1_M
48VPH_PWR 3.8V
49Upper CSI_DATA2_P
50GND
51Upper CSI_DATA2_M
523.3V
53GND
54GND
55Upper CSI_DATA3_P
565V
57Upper CSI_DATA3_M
585V
59GND
60GND
Configured for the following hardware:
                                                 +--> M0010
- M0054 J6 <--> M0076-1 interposer <--> M0010 <--|
                                                 +--> M0010
More camera information here
Connector: DF40C-60DP-0.4V(51)
Device Tree:
  • qcom,cam-sensor0
  • qcom,cam-sensor1
J6 Pin-out
Pin #Signal NameUsage / Notes
1GND
2GND
3CCI_I2C0_SDACAM0_CCI0_SDA, gpio101
4VREG_PM8009_L2_1P2DVDD 1.2V
5CCI_I2C0_SCLCAM0_CCI0_SCL, gpio102
6VREG_PM8009_L7_1P8CAM0_VIO_1P8, CAM0_VIO_1P8
7GND
8VREG_PM8009_L1_1P05CAM0_VDD_1P05, NOTE: current this is ~1.13VDC
9CSI0_CLK_CON_P
10GPIO_93_CAM0_RST_NCAM0_RST_N, gpio93
11CSI0_CLK_CON_N
12GPIO_94_CAM_MCLK0_CONCAM_MCLK0_CON, gpio94
13CSI0_LANE0_CON_PLEFT
14GND
15CSI0_LANE0_CON_NLEFT
16GPIO_110_CCI_TIMER1(unused in version 0)
17GND
18GPIO_113_CCI_TIMER4CAM_FSYNC_1_OUT, CAM_FSYNC0_IN
19CSI0_LANE1_CON_PRIGHT
20CAM_MCLK1_CONCAM_MCLK1_CON, gpio95
21CSI0_LANE1_CON_NRIGHT
22VREG_PM8009_L5_2P8CAM0_AVDD_2P8, CAM1_AVDD_2P8
23CSI0_LANE2_CON_P
24GND
25CSI0_LANE2_CON_N
26GPIO_109_CAM3_RST_N(shared, CAM3_RST_N)
27GND
28CCI_I2C1_SDACAM1_CCI1_SDA, CAM4_CCI1_SDA
29CSI0_LANE3_CON_P
30CCI_I2C1_SCLCAM1_CCI1_SCL, CAM4_CCI1_SCL
31CSI0_LANE3_CON_N
32MCLK6_G0_CON(shared) CAM1_RST_N, gpio100,
33GND
34GPIO_28_CAM0_SPI0_MISO/dev/spidev0.0
35CSI1_CLK_CON_P
36GPIO_29_CAM0_SPI0_MOSI/dev/spidev0.0
37CSI1_CLK_CON_N
38GPIO_30_CAM0_SPI0_CLK/dev/spidev0.0
39CSI1_LANE0_CON_P
40GPIO_31_CAM0_SPI0_CS/dev/spidev0.0
41CSI1_LANE0_CON_N
42VREG_S4A_1P8
43GND
44GND
45CSI1_LANE1_CON_P
46VPH_PWR
47CSI1_LANE1_CON_N
48VPH_PWR
49CSI1_LANE2_CON_P
50GND
51CSI1_LANE2_CON_N
52VREG_3P3V_LOCAL
53GND
54GND
55CSI1_LANE3_CON_P
56VDC_5V_LOCAL
57CSI1_LANE3_CON_N
58VDC_5V_LOCAL
59GND
60GND
                                +--> M0014   (M0084-JL - lower)
- M0054 J7 <--> M0084 flex <----|
                                +--> M0025-2 (M0084-JU - upper)
Device Tree:
  • qcom,cam-sensor2
  • qcom,cam-sensor3
J7 Pin-out
1GND
2GND
3CCI_I2C2_SDACAM2_CCI2_SDA, gpio105
4VREG_PM8009_L2_1P2(M0084, R1 not stuffed, not routed)
5CCI_I2C2_SCLCAM2_CCI2_SCL, gpio106
6VREG_PM8009_L7_1P8CAM2_DOVDD_1P8, CAM3_DOVDD_1P8
7GND
8VREG_PM8009_L1_1P05(M0084, R2 stuffed) CAM2_VDD_1P05,CAM3_VDD_1P05 (NOTE: current this is ~1.13VDC)
9CSI2_CLK_CON_P
10GPIO_92_CAM1_RST_NRST_LOWER_N, gpio92
11CSI2_CLK_CON_N
12GPIO_96_CAM_MCLK2MCLK_LOW, gpio96
13CSI2_LANE0_CON_P
14GND
15CSI2_LANE0_CON_N
16GPIO_111_CCI_TIMER2CCI_TIMER_LOWER
17GND
18GPIO_114_CCI_ASYNC_INCCI_TIMER_UPPER (Do Not Use on M0054 Voxl2, there is a HW limitation impacting this pin. It will be fixed on future HW. Voxl2 Mini is not impacted by this issue.)
19CSI2_LANE1_CON_P
20GPIO97_CAM_MCLK3_CONMCLK_UPPER, gpio97
21CSI2_LANE1_CON_N
22VREG_PM8009_L6_2P8AVDD_2P8, CAM2_DOVDD_2P8, CAM3_DOVDD_2P8
23CSI2_LANE2_CON_P
24GND
25CSI2_LANE2_CON_N
26GPIO_109_CAM3_RST_N(shared, RST_UPPER_SHARED_N)
27GND
28CCI_I2C3_SDACAM3_CCI3_SDA, CAM5_CCI3_SDA, gpio107
29CSI2_LANE3_CON_P
30CCI_I2C3_SCLCAM3_CCI3_SCL, CAM5_CCI3_SCL, gpio108
31CSI2_LANE3_CON_N
32MCLK6_G1_CON(shared) GPIO_MCLK6_SHARED, gpio100
33GND
34GPIO_4_CAM1_SPI1_MISOGPIO_4, /dev/spidev1.0 can be enabled in DT, see this commit to see how to re-enable if needed.
35CSI3_CLK_CON_P
36GPIO_5_CAM1_SPI1_MOSIGPIO_5, /dev/spidev1.0 can be enabled in DT see this commit to see how to re-enable if needed.
37CSI3_CLK_CON_N
38GPIO_6_CAM1_SPI1_CLKGPIO_6, /dev/spidev1.0 can be enabled in DT see this commit to see how to re-enable if needed.
39CSI3_LANE0_CON_P
40GPIO_7_CAM1_SPI1_CSGPIO_7, /dev/spidev1.0 can be enabled in DT see this commit to see how to re-enable if needed.
41CSI3_LANE0_CON_N
42VREG_S4A_1P8
43GND
44GND
45CSI3_LANE1_CON_P
46VPH_PWR
47CSI3_LANE1_CON_N
48VPH_PWR
49CSI3_LANE2_CON_P
50GND
51CSI3_LANE2_CON_N
52VREG_3P3V_LOCAL
53GND
54GND
55CSI3_LANE3_CON_P
56VDC_5V_LOCAL
57CSI3_LANE3_CON_N
58VDC_5V_LOCAL
59GND
60GND
                                                 +--> M0010
- M0054 J8 <--> M0076-1 interposer <--> M0010 <--|
                                                 +--> M0010
Device Tree:
  • qcom,cam-sensor4
  • qcom,cam-sensor5
J8 Pin-out
1GND
2GND
3CCI_I2C1_SDACAM1_CCI1_SDA, CAM4_CCI1_SDA, gpio103
5CCI_I2C1_SCLCAM1_CCI1_SCL, CAM4_CCI1_SCL gpio104
7GND
9CSI4_CLK_CON_P
10GPIO_78_CAM4_RST_NCAM4_RST_N, gpio78
11CSI4_CLK_CON_N
12GPIO_98_CAM_MCLK4CAM_MCLK4_CON, gpio98
13CSI4_LANE0_CON_PLEFT
14GND
15CSI4_LANE0_CON_NLEFT
16GPIO_112_CCI_TIMER3(unused in version 0)
17GND
18GPIO_111_CCI_TIMER2CAM_FSYNC_5_OUT, CAM_FSYNC4_IN
19CSI4_LANE1_CON_PRIGHT
20CAM_MCLK5_CONCAM_MCLK5_CON, gpio99
21CSI4_LANE1_CON_NRIGHT
22VREG_PM8009_L6_2P8CAM4_AVDD_2P8, CAM5_AVDD_2P8
23CSI4_LANE2_CON_P
24GND
25CSI4_LANE2_CON_N
27GND
28CCI_I2C3_SDACAM5_CCI3_SDA, CAM3_CCI3_SDA, gpio107
29CSI4_LANE3_CON_P
30CCI_I2C3_SCLCAM5_CCI3_SCL, CAM3_CCI3_SCL, gpio108
31CSI4_LANE3_CON_N
32MCLK6_G2_CON(shared) GPIO_MCLK6_SHARED, gpio100
33GND
34GPIO_12_CAM2Not used as RTS, not available as GPIO
35CSI5_CLK_CON_P
36GPIO_13_CAM2Not used as CTS, not available as GPIO
37CSI5_CLK_CON_N
38GPIO_14_CAM2_UART5_TX/dev/ttyHS0
39CSI5_LANE0_CON_P
40GPIO_15_CAM2_UART5_RX/dev/ttyHS0
41CSI5_LANE0_CON_N
42VREG_S4A_1P8
43GND
44GND
45CSI5_LANE1_CON_P
46VPH_PWR
47CSI5_LANE1_CON_N
48VPH_PWR
49CSI5_LANE2_CON_P
50GND
51CSI5_LANE2_CON_N
52VREG_3P3V_LOCAL
53GND
54GND
55CSI5_LANE3_CON_P
56VDC_5V_LOCAL
57CSI5_LANE3_CON_N
58VDC_5V_LOCAL
59GND
60GND
J10 - External SPI
Available from apps proc as /dev/spidev14.0. J10 Achieved feature parity with VOXL 2 Mini when the design was updated from M0054 -> M0154. It is capable of either UART or SPI based on GPIO_67 control, but fixed in the Kernel for that build (not dynamic)
1VREG_3P3V_LOCAL3.3V Power Output *
2MISO (Input)APPS_QUP_14, 3.3V signal levels
3MOSI (Output)APPS_QUP_14, 3.3V signal levels
4SCLK (Output)APPS_QUP_14, 3.3V signal levels
5CS0_N (Output)APPS_QUP_14, 3.3V signal levels
6CS1_N/GPIO_46 (Output)Second SPI CS_N or GPIO
732K_CLK_OUT (Output)32kHz PMIC Sleep CLK, 3.3V signal levels
8GNDGND
6CS1_N/GPIO_46 (Output)Second SPI CS_N or GPO
7GPIO_64_INT (Input)GPIO_64 as input for INT, 3.3V signal levels
8GNDGND
2GPIO_40 (Input)GPIO_40 Input, 3.3V signal levels
3GPIO_41 (Output)GPIO_41 Output, 3.3V signal levels
4UART_14_TX (Output)APPS_QUP_14, 3.3V signal levels
5UART_14_RX (Input)APPS_QUP_14, 3.3V signal levels
6GPIO_46 (Input)GPIO_46 as input, 3.3V signal levels
8GNDGND
J18 UART (ESC)
J18 ESC UART
2ESC_UART_TX (Output)slpi_proc, SSC_QUP_2, 3.3V signal levels.
3ESC_UART_RX (Input)slpi_proc, SSC_QUP_2, 3.3V signal levels.
4GNDGND
SW Summary
Available from DSP as QUP2. In the factory configuration, PX4 communicates to the VOXL ESC through this UART.
J19 Pin-out
1VDC_5V_LOCALGNSS/Mag power *
2GNSS TX 3P3Vslpi_proc, SSC_QUP6
3GNSS RX 3P3Vslpi_proc, SSC_QUP6
4MAG SCL 3P3Vslpi_proc, SSC_QUP0
5MAG SDA 3P3Vslpi_proc, SSC_QUP0
6GND
7I2C3 SDA 3P3Vslpi_proc, SSC_QUP3
8I2C3 SCL 3P3Vslpi_proc, SSC_QUP3
9VREG_3P3V_RCRC power *, controllable via GPIO 159
10RC_UART_TX (Output)slpi_proc, SSC_QUP7, 3.3V signal levels
11RC_UART_RX (Input)slpi_proc, SSC_QUP7, 3.3V signal levels
12GND
SW Summary
All connected to the DSP, and in the factory configuration are used as follows:
  • QUP0 - I2C for external magnetomter
  • QUP3 - future use
  • QUP6 - UART for external GNSS (GPS)
  • QUP7 - UART for external RC input
I2C Important Note:
  • All I2C ports on the JST Board-to-Cable connectors (J19 on VOXL 2 and VOXL 2 Mini plus ModalAI Plug-in Boards such as M00130 & M0090) use a TCA9517 to translate and buffer the I2C from the Snapdragon SOC 1.8V to 3.3V logic levels.
  • The expectation is that these ports go directly to an accesory target device without further translation back down to lower voltages. For example; a micro-controller running at 3.3V native I/O levels. The TCA9517 cannot operate “B-port to B-port” and therefore if your system requires translating back down to lower voltages, such as 1.8V or 2.5V, a special un-buffered I2C translater will be required such as the PCA9306 or PCA9509.
  • All power outputs on cable connectors are rated for 1A, however, the system cannot provide 1A simultaneously on all connectors. Contact ModalAI for design assistance.
  • The difference between VDCIN_5V and VDC_5V_LOCAL is very important. The power module provides VDCIN_5V (raw voltage input) to the platform. On-board is an eFuse that protects the system from accidental wrong-voltage application, droops/brown-outs, or down-stream shorts or overloads. The output of the eFuse is VDC_5V_LOCAL (i.e.: protected output).
  • Refer to the Expansion Hardware Design Guide for more detailed explanations.
