Deep Learning on VOXL 2’s GPU and NPU
  1. Configuration
  2. Output
  3. Benchmarks
  4. Custom Models
    1. 1. Convert your model to LiteRT
    2. 2. Deploy — no code changes
    3. 3. Only for genuinely new output layouts — extend the server
  5. Running Multiple Models
  6. Current Limitations
  7. Troubleshooting
  8. Demo
  9. Source
  10. Frequently Asked Questions (FAQ)
VOXL 2 delivers state-of-the-art machine learning performance through both GPU and NPU acceleration on the QRB5165. This is best illustrated through voxl-tflite-server, our service for on-device inference of LiteRT (formerly TensorFlow Lite) models. Current releases build against LiteRT/tflite 2.17.1 and target QRB5165-based platforms (VOXL 2 and VOXL 2 Mini); the original VOXL 1 is no longer supported by new releases.
voxl-tflite-yolo
Configuration
voxl-tflite-server reads its configuration from /etc/modalai/voxl-tflite-server.conf, generated and edited by the voxl-configure-tflite tool. Run it with no arguments to get an interactive wizard with presets for every bundled model (plus a “Custom” option that prompts for every parameter), or pass flags to script it:
voxl-configure-tflite                      # interactive wizard
voxl-configure-tflite --model-path /usr/bin/dnn/yolov11n_float16.tflite \
    --model-arch YOLOV11 --norm-type HARD_DIVISION \
    --label-path /usr/bin/dnn/coco_labels.txt \
    --input-pipe /run/mpa/hires_small_color/ --delegate gpu \
    --output-prefix yolo --skip-frames 0
Config file parameters:
ParameterDefaultMeaning
model/usr/bin/dnn/...path to the .tflite model file
model_architectureMOBILE_NEThow to interpret the model’s output tensors. One of MOBILE_NET, MOBILE_NET_CLASSIFIER, YOLOV5, YOLOV8, YOLOV11, EFFICIENT_NET, POSENET, FAST_DEPTH, DEEPLAB. An unrecognized value exits at startup.
norm_typePIXEL_MEANinput normalization: PIXEL_MEAN scales to [-1,1], HARD_DIVISION to [0,1] (used by the YOLO family), NONE leaves [0,255]. A wrong value doesn’t error — it silently degrades accuracy.
requires_labelstruewhether the model needs a labels file
labels/usr/bin/dnn/coco_labels.txtpath to the labels file
input_pipe/run/mpa/hires_small_color/full path of the camera pipe to consume. The wizard enumerates live camera pipes on your system to choose from.
delegategpuhardware acceleration: gpu (float16 models), nnapi (quantized int8/uint8 models; automatically selects the best accelerator), or cpu (XNNPACK, multi-threaded). If a delegate fails to apply, the server prints an error and falls back to plain CPU.
skip_n_frames—frames to skip between inferences. For a 30Hz input, 5 gives ~5Hz output; 0 processes every frame.
allow_multipletrueallow multiple server instances; output pipes get the output_pipe_prefix prepended
output_pipe_prefixmobilenetprefix for this instance’s output pipes
Output
With the default configuration (allow_multiple true, prefix mobilenet), the overlay stream is published at /run/mpa/mobilenet_tflite — in general <output_pipe_prefix>_tflite. Set allow_multiple to false to get the un-prefixed names tflite / tflite_data, which some consumers expect. The stream is a normal camera pipe: view it with voxl-portal, convert to ROS with voxl_mpa_to_ros, or log it with voxl-logger.
Each model provides a task-specific overlay, with an fps counter and inference timer in the top left.
voxl-portal-tflite
Object-detection models additionally publish <output_pipe_prefix>_tflite_data, a metadata pipe with one struct per detection:
// struct containing all relevant metadata to a tflite object detection
typedef struct ai_detection_t {
    uint32_t magic_number;
    int64_t timestamp_ns;
    uint32_t class_id;
    int32_t  frame_id;
    char class_name[BUF_LEN];
    char cam[BUF_LEN];
    float class_confidence;
    float detection_confidence;
    float x_min;
    float y_min;
    float x_max;
    float y_max;
} __attribute__((packed)) ai_detection_t;
The detection pipe also accepts a runtime control command: send set_cam <pipe> to it to switch the input camera on the fly without restarting the server.
Useful flags when running the server by hand: -d (debug output), -t (per-stage timing breakdown), -p <file> (use an alternate config file — this is how multiple instances run), -c (load config and exit).
Benchmarks
Stats were collected across 5000 inferences, using the hires [640x480x3] camera as input, on an older tflite runtime — treat them as relative guidance rather than current absolutes. Current releases pipeline pre-processing, inference, and post-processing on separate threads, so end-to-end throughput is higher than single-pass numbers suggest.
ModelTaskAvg Cpu Inference(ms)Avg Gpu Inference(ms)Avg NNAPI Inference(ms)Max Frames Per Second(fps)Input DimensionsSource
MobileNetV2-SSDliteObject Detection33.89ms24.68ms34.42ms34.86750349[1,300,300,3]link
EfficientNet Lite4Classifier115.30ms24.74ms16.42ms48.97159647[1,300,300,3]link
FastDepthMonocular Depth37.34ms18.00ms37.32ms45.45454546[1,320,320,3]link
DeepLabV3Segmentation63.03ms26.81ms61.77ms32.45699448[1,321,321,3]link
Movenet SinglePose LightningPose Estimation24.58ms28.49ms24.61ms34.98950315[1,192,192,3]link
YoloV5Object Detection88.49ms23.37ms83.87ms36.53635367[1,320,320,3]link
MobileNetV1-SSDObject Detection19.56ms21.35ms7.72ms85.324232082[1,300,300,3]link
MobileNetV1Classifier19.66ms6.28ms3.98ms125.313283208[1,224,224,3]link
Newer YOLOv8 and YOLOv11 models ship with the server (/usr/bin/dnn/yolov8n_float16.tflite, yolov11n_float16.tflite) and are the recommended starting point for object detection.
Custom Models
You do not need to modify or rebuild voxl-tflite-server to run your own model, as long as its outputs match one of the supported architectures (model_architecture above). The workflow is: convert your model to .tflite, copy it to the target, and point the config at it.
YOLO (Ultralytics) — export directly to TFLite; no frozen graph is involved (Ultralytics no longer produces one):
from ultralytics import YOLO
YOLO("best.pt").export(format="tflite")   # produces best_saved_model/best_float16.tflite
Under the hood this goes PyTorch → ONNX → onnx2tf → TFLite. Our voxl-train-yolov8 repo provides a complete training + export environment with working dependency pins (notably onnx2tf>1.17.5,<=1.22.3).
TensorFlow models — use the modern converter on a SavedModel or Keras model:
import tensorflow as tf
converter = tf.lite.TFLiteConverter.from_saved_model("path/to/saved_model")
converter.target_spec.supported_types = [tf.float16]   # float16 for the gpu delegate
tflite_model = converter.convert()
open("model_float16.tflite", "wb").write(tflite_model)
Other PyTorch models — export to ONNX first, then convert with onnx2tf, or use Qualcomm AI Hub with the ‘RB5 (Proxy)’ device.
Quantization determines which delegate you can use: float16 models for gpu, full-integer (int8/uint8) models for nnapi.
  1. Copy your .tflite (and labels file, if applicable) to /usr/bin/dnn/ on target.
  2. Run voxl-configure-tflite, choose Custom - specify all parameters manually, and supply the model path, architecture, normalization type, labels, input pipe, and delegate (or pass the equivalent flags shown in Configuration).
  3. Restart the service: systemctl restart voxl-tflite-server.
The input tensor size is read from the model automatically, and camera frames are resized and color-converted for you. YOLO-family models use norm_type HARD_DIVISION.
If your model’s output tensors don’t match any supported architecture, add one: a new enum in include/model_helper/model_info.h, a mapping in get_model_type() in src/main.cpp, a case in create_model_helper() in src/model_helper/model_helper.cpp, and a ModelHelper subclass (under include/model_helper/ and src/model_helper/) overriding post_process() and worker() — preprocess() and run_inference() have generic base implementations you can usually keep. The existing helpers (YOLOv11 simply reuses the YOLOv8 helper) are good templates. To surface your model as a wizard preset, add an entry in scripts/voxl-configure-tflite-wizard and the architecture to the bash completion.
The wizard supports this directly: run voxl-configure-tflite, and when asked how many instances to configure, answer 2 or more. It writes one config per instance (/etc/modalai/voxl-tflite-server_2.conf, …) with distinct output_pipe_prefix values and updates the systemd service to launch each instance with -p <its config>. Each instance publishes under its own prefix (e.g. /run/mpa/yolo_tflite, /run/mpa/depth_tflite).
The board heats up much quicker when running multiple models. Adding an external fan when benchtop testing helps combat the extra heat.
Current Limitations
Limitations of the current implementation:
  • Only the model_architecture values listed above are supported. YOLO support means v5, v8, and v11 (v11 shares the v8 decoder). A model with any other output layout requires extending the server in C++.
  • Detection thresholds are compile-time constants, not configurable: SSD/MobileNet score 0.6; YOLOv5 box 0.40 / class 0.20 / NMS 0.50; YOLOv8/v11 score 0.45 / confidence 0.25 / NMS 0.5. Changing them means rebuilding.
  • One model and one camera per server instance. Run more models with multiple instances (see above). Switching cameras at runtime (set_cam on the control pipe) works for object-detection models only.
  • Camera input formats: YUV and RAW8 (stereo variants use the left frame). RGB pipes are not handled without a code change. Frames above 4K are rejected, the input resolution is locked at the first frame (which is itself skipped while building the resize map), and mid-stream resolution changes are not supported.
  • Model input dtype must be float32, int8, or uint8 — and quantized inputs receive raw image bytes with no scale/zero-point handling. In practice: export custom models as float16 and run the gpu delegate; that is the tested path.
  • Inference pauses when nothing consumes the output pipes (a power optimization). If you’re testing over adb with no portal or inspect tool attached, it will look dead — attach a consumer, or run with -d/-t which disables the optimization.
  • Delegates fail soft: if the requested delegate can’t apply (or the name is unrecognized), the server quietly runs on CPU — check the startup output. There is no Hexagon delegate; nnapi picks its accelerator automatically.
  • The service is capped at 4 GB RAM by systemd and drops frames under backpressure rather than queueing.
  • Use the short CLI flags (-d debug, -t timing, -p <conf>); the long-form flags are currently miswired.
  • Supported platform: the QRB5165 family (VOXL 2 / VOXL 2 Mini).
Troubleshooting
For general service debugging see Debugging Services.
Custom model runs but produces no detections. Triage:
  1. Stop the service and run the server in the foreground: systemctl stop voxl-tflite-server, then voxl-tflite-server -d.
  2. If the output repeats Error in TensorData<float>: should not reach here, your model’s output tensor dtype doesn’t match what the server expects — this is a model-export problem, not a labels problem. Re-export unquantized (float16) following voxl-train-yolov8, and use the gpu delegate.
  3. Verify detections flow with voxl-inspect-detections tflite_data -a (add your output_pipe_prefix if set) and visually in voxl-portal. If the overlay stream never appears in portal at all, the server failed at startup — read the foreground output.
  4. A missing labels file exits the server at startup; a labels file with fewer entries than the model has classes shows numeric class ids instead of names.
The board reboots when the server runs. Almost always power delivery, not software: viewing tflite output kicks off real inference, the CPU/GPU load spikes, and a worn power-cable contact browns out the board. Replace the 4-pin power cable between VOXL 2 and its power source (repeated unplugging loosens the contacts — a “wiggle fix” is temporary and makes it worse). A true kernel panic reboots into recovery mode, which distinguishes it from a power reset.
Building from source fails. The install_build_deps.sh branch argument must match the SDK branch of the source you checked out — ./install_build_deps.sh qrb5165 sdk-1.4 for the sdk-1.4 branch, dev only for tip-of-tree — and the required voxl-cross image version tracks the branch (current master needs voxl-cross ≥ 4.3). Mismatched deps produce compile/link errors deep in TensorFlow.
Not supported: custom YOLOv5 training assistance, RTSP streams as server input (MPA camera pipes only), and cropping/resizing inside the server — produce an appropriately-sized stream from voxl-camera-server instead (e.g. a small or MISP stream).
Demo
Source
Source code is available on GitLab
I want to use my Python script to pre/post-process inputs/outputs to the model, how can I do this? The inputs and outputs for the model are both done using libmodal-pipe which only supports C/C++ and so there isn’t a way to directly interface with Python. However, it’s possible to use libmodal-pipe to create a very simple wrapper which consumes from a pipe, runs a Python executable, and then passes information along to another pipe. In the libmodal-pipe repo check out the examples dir for an example of setting up a basic pipe interface on VOXL.
Why is my model predicting less accurately when deployed on VOXL? The most common cause is a wrong norm_type — it fails silently and just degrades results; check what normalization your model was trained with. Beyond that, voxl-tflite-server does its own pre/post-processing on the image tensors which may differ from your local pipeline, and quantization can reduce accuracy versus the non-quantized original.
