VOXL FPV Racing 4-in-1 ESC Datasheet
M0138 high-current 4-in-1 ESC for FPV racing applications: specifications and pinouts.
  1. Hardware Overview
  2. Dimensions
  3. Specifications
  4. Connector Information and Pin-outs
  5. Power Connectors and Pads
  6. Neopixel LED Support
  7. PWM Inputs / Outputs
  8. GPIO
  9. Wiring Diagrams
    1. M0138-1 FPV ESC with Flight Core v2
Hardware Overview
This M0138-1 high-performance ESC uses 100A 40V MOSFETs and board layout optimized for demanding FPV racing applications. The ESC supports 100A burst current per channel and over 300A total burst current (usually limited by battery and connectors). Communicate reliably with low-latency digital UART from your flight controller to the 4-in-1 ESC.
This ESC has a dedicated 5V regulated power output to power VOXL 2 or Flight Core v2 with battery voltage and current monitoring support in PX4. Additionally the ESC can power a video transmitter and has the ability to toggle on and off.
Dimensions
M0138 VOXL Racing 4-in-1 ESC 3D CAD
  • Board dimensions: 45.5mm x 59.0mm
  • Mounting hole pattern: 30.5mm x 30.5mm, M3 (3.05mm)
Specifications
FeatureDetails
Power Input2-6S Lipo (6-26V). Supports 6S LiHV
VOXL Power Output5V @ 6A
VTX Power Output16.8V @ 500mA (switch on/off). Passthrough if Vbatt < 16.8
AUX Power Output3.3V / 5.0V @ 500mA (switch on/off, voltage selectable in software)
Payload ConnectorBattery Voltage, JST Connector, rated 4A
Performance40V, 100A+ Mosfets
 100A peak current per motor (<1s)
 40A continuous current per motor (with sufficient airflow, application dependent)
 Peak total board current 300A+ (<1s)
Software FeaturesOpen-loop control (set desired % power)
 Closed-loop RPM control (set desired RPM), used in PX4 driver
 Regenerative braking
 Smooth sinusoidal spin-up
 Tone generation using motors
 Real-time RPM, temperature, voltage, current feedback via UART
CommunicationsSupported by VOXL 2, VOXL 2 Mini, VOXL Flight, VOXL and Flight Core
 Bi-directional UART up to 2Mbit/s (3.3VDC logic-level)
Connectors4-pin JST GH for UART communication
 VOXL output: solder pads for 5.0V / 3.8V (depends on board variant)
 Payload connector: JST SM02B-SFHLS-TF(LF)(SN)
 VTX power output: solder pads
 AUX power output: solder pads
HardwareMCU : STM32F051K86 @ 48Mhz, 64KB Flash
 Mosfet Driver : MP6531
 Mosfets: Infineon BSC022N04LS (40V, N-channel)
 Current Sensing : 0.25mOhm + INA186 (total current only). 200A max sensing range
 ESD Protection : Yes (on UART and PWM I/O)
 Temperature Sensing : 4x internal to MCU, 2x external (top and bottom of PCB)
 On-board Status LEDs : Yes
 Weight (no wires) : 17.9g
 Motor Connectors: N/A (solder pads)
PX4 IntegrationSupported in PX4 1.12 and higher
 Available here in developer preview
ResourcesManual
 PX4 Integration User Guide
The operating input range is 2S to 6S (6 V to 26 V). Do not run this ESC on 7S or 8S packs. The 40 V rating of the MOSFETs and other components is design margin for transients, back-EMF and regenerative energy, not headroom for a higher cell count.
UART Connector J1
  • Used for UART communication with the ESC
  • Connector on board : BM04B-GHS-TBT
  • Mating connector : GHR-04V-S
  • Pre-crimped wires : (Digikey) AGHGH28K152 or similar
  • 3.3V signals (5.0V input is acceptable)
Pin >1234
Function >3.3V reference out (leave unconnected)UART RX (IN)UART TX (OUT)GND
The pinout matches the M0129 VOXL Mini 4-in-1 ESC UART connector.
All locations reference the board silkscreen (see the labeled diagram at the top of this page).
OutputLocationDetails
Battery input+++ / --- M3 plated through-holes (bottom side)2-6S LiPo, TVS protected
Payload output (connector)J2, JST SM02B-SFHLS, silkscreen +BATOUT-pin 1 = battery voltage (+), pin 2 = GND; rated 4A. Downstream of the current-sense resistor, so payload current is included in the ESC’s battery-current telemetry
Payload output (pads)solder pads beside J2same net as J2 (battery voltage / GND)
VTX outputsolder pad pair marked <4SOUT> beside J2battery voltage clipped to 16.8V (4S level); switched on/off via VTX_VREG_ENABLE (see GPIO below)
VOXL power output+VXL- / -GND- pad pair, top side next to J15.1V (VOXL 2 variant) or 3.8V (VOXL 2 Mini variant) from a 6A-rated regulator
AUX outputVAUX pad in the AUX IO group, bottom edge3.3V (default) or 5.0V selectable; switched via AUX_VREG_ENABLE
Motor outputs12 castellated solder pads around the board edgethree phases per channel, silkscreen ID<n>:A/B/C (channel n, phase A/B/C)
The AUX IO pad group on the bottom edge also carries a ground reference pad G for the PWM/Neopixel signals (see image below).
  • Single Neopixel RGB LED outputs is available, up to 32 LEDs
  • Use test point labeled RGB in the AUX IO section of the ESC
  • The I/O pin is connected to ESC ID0 PB8 (3.3V levels)
  • VAUX output provides 3.3V output for the LED array
  • ⚠️Solder carefully to test points and use strain relief to avoid damaging the pads
  • Test tools: voxl-esc-neopixel-test.py
  • Integration with PX4 is done via voxl_esc driver and modal_io_bridge
  • Two independent PWM output pins are available, one pin per ESC channel
  • Use test points 0P and 3P (AUX IO section of the ESC)
  • PWM pin 0P is connected to ESC ID0, 3P -> ESC ID3 (3.3V levels)
  • PWM output is available in firmware in 39.18 or later
  • Operating mode of PWM pins
    • PWM input is disabled on this ESC because only two I/O pins are available
    • PWM output can be enabled by sending specific message to the ESC via UART interface
  • PWM output mode specifications
    • 3 frequency modes (50hz, 200Hz, 400hz)
    • enable or disable timeout (0.5s). If timeout is enabled, PWM output will be disabled (set to low state) after 0.5s of no commands
    • output range 0-2200 us with 0.05us resolution, special value of 2201us will force HIGH state (can be used as GPIO)
  • Test tools: voxl-esc-pwm.py
    • this tool can only be used while PX4 is not running, since it needs direct access to the UART port
  • Integration with PX4 is done via voxl_esc px4 driver and modal-io-server. voxl-send-esc-pwm-cmd (part of voxl-io-server, whose source is not publicly available)
    • this tool will send a control message to PX4 (voxl_esc driver) and the driver will forward the PWM command to the ESC
GPIO
Signal NameMCU PinFunction
VTX_VREG_ENABLECH0 PF0VTX Power Control
AUX_VREG_ENABLECH0 PA12AUX 3.3 / 5.0V Regulator Power Control
AUX_VREG_ADJUSTCH0 PA11AUX 3.3 / 5.0V Regulator Voltage Select (disabled)
Wiring Diagrams
