Configure MPA
voxl-configure-xxx scripts
MPA services all have an associated voxl-configure-xxx script to assist in enabling, disabling, and resetting service configuration files back to default. Each of these scripts will run as a wizard that asks questions if no arguments are given. For example voxl-imu-server:
yocto:/# voxl-configure-imu
Starting Wizard
1) yes
2) no
#? 1
wiping old config file
Creating new config file: /etc/modalai/voxl-imu-server.conf
Do you want to enable the voxl-imu-server
This is required for visual inertial odometry.
1) yes
2) no
#? 1
enabling  voxl-imu-server systemd service
starting  voxl-imu-server systemd service
Done configuring voxl-imu-server
yocto:/#
OR, you can tab-out arguments from the command line as a shortcut
yocto:/$ voxl-configure-imu {PRESS TAB}
disable         enable          factory_enable  help
The factory-enable option will reset voxl-imu-server.conf back to factory defaults, then enable the systemd service.
voxl-configure-mpa
voxl-configure-mpa is a top-level config script for configuring all of the individual voxl-configure-xxx scripts at once.
yocto:/# voxl-configure-mpa
-------------Options for End Users-------------
        Welcome to voxl-configure-mpa!
  This tool is here to help you configure the
   multitude of MPA (Modal Pipe Architecture)
           services in voxl-suite.
      As an end-user you have 3 options
  Start the configuration wizard that asks
  questions (recommended)
  voxl-configure-mpa --wizard
  Perform a reset back to how MPA services were
  configured at the factory
  voxl-configure-mpa --factory-reset
  Show this help message:
  voxl-configure-mpa --help
yocto:/#
Wizard Mode
Wizard mode will run you through each of the voxl-configure-xxx wizards, including voxl-configure-cameras.
Factory Reset Mode
VOXL Boards that were shipped as part of a kit (M500, Seeker, VOXL CAM, etc) were configured at the factory with kit-specific MPA configuration starting around June 2021 with the introduction of MPA. In these cases, the kit part number is saved to /data/modalai/factory_mode.txt and can be used to put your VOXL MPA services back to their kit-specific factory defaults by running:
Note this file will be wiped along with factory calibration files if you elect to wipe your /data/ partition while flashing a system image (which is not a recommended procedure).
