VOXL Camera Server
Table of Contents
  1. VOXL Camera Server
    1. Overview
    2. Hardware Configuration
    3. Software configuration
    4. HAL3 Streams
    5. Camera Server Config File
      1. General Settings
      2. Preview Stream Settings
      3. Small Video Stream Settings
      4. Large Video Stream Settings
      5. Snapshot Stream Settings
      6. libmodal exposure settings
    6. Constant Quantization vs Constant Bitrate Mode
      1. SDK 1.3.5+
      2. Pre SDK 1.3.5
    7. Config File Example
    8. Camera sensor options and capabilities
      1. Supported Resolutions
    9. Geo-tag Snapshots with GPS
    10. Troubleshooting
      1. Debugging Exposure Settings
      2. Supported Configurations
    11. Source Code
VOXL Camera Server publishes MIPI Camera images and video to MPA pipes to allow multiple clients to utilize each camera. It is one of many MPA services that publish image data. See the previous page to read more about the MPA camera interface.
Example services that are clients for voxl-camera-server include voxl-qvio-server, voxl-portal, ROS, and voxl-streamer.
VOXL Camera Server uses Google’s HAL3 API to access the Qualcomm ISP pipeline, with hardware-accelerated H264/H265 video compression (via libvoxl-codec in current releases).
MIPI camera interfaces and drivers are very complicated, requiring careful schematic and PCB design to connect. Driver bringup requires deep knowledge of the Qualcomm camera stack and kernel. These are not USB webcams and cannot be plugged in willy-nilly to whatever port you fancy.
ModalAI provides a set of supported camera configurations to cover a range of use cases for the VOXL 2, and VOXL 2 Mini.
QRB5165 based platforms (VOXL 2 and VOXL 2 mini) are more flexible but it would impossible for us to support the thousands of possible camera configurations. Therefore we suggest starting with a supported camera configuration, seeing how the voxl-configure-cameras tool sets up the drivers and voxl-camera-server config file, then modifying to suit your use case from there.
Only connect and disconnect cameras while VOXL is powered off!!
The following sensor types are supported code reference:
  • ov7251
  • ov9782
  • ov64b
  • ov2311
  • ar0144 (plus ar0144-rotated, ar0144-color, ar0144-12bit variants)
  • imx214
  • imx412 (plus imx412-fpv-misp)
  • imx565 (plus imx565-color)
  • imx577
  • imx664 (plus imx664-fpv)
  • imx678
  • pmd-tof
  • pmd-tof-liow2
  • boson (plus boson-fpv)
voxl-configure-cameras is a top-level helper script used to set up camera sensor drivers and the/etc/modalai/voxl-camera-server.conf config file. It will write default settings for the selected camera configuration as a starting point for further customization if necessary. If you want to change some aspects of the camera server behavior such as disabling a camera or changing video encoding settings, you can do so by modifying that file and restarting camera server with systemctl restart voxl-camera-server.
HAL3 Streams
HAL3 can provide multiple simultaneous image streams with different formats and resolutions. On QRB5165 (VOXL 2) up to 3 simultaneous streams can be enabled per camera.
voxl-camera-server’s config file is set up to configure 4 different streams with specific intended use cases. The streams are not activated until a client is connected.
ModePurposeFormat
previewLow latency uncompressed images computer vision algorithmsNV12 or RAW8
small_encodedCompressed video for wireless stream (See voxl-streamer)H264 or H265
large_encodedCompressed video for saving to diskH264 or H265
snapshotSave full-quality ISP processed JPG to disk or to pipeJPG
FPV and low-latency products additionally use a MISP stream family (en_misp, misp_venc_*, misp_channels[], and electronic image stabilization via en_eis) — those parameters are documented on the Electronic Image Stabilization and Low Latency Streaming pages.
The primary stream for computer video sensors such as the OV7251 Tracking camera and stereo pairs is the preview stream. For example, voxl-qvio-server takes a preview stream in RAW8 format as its input for the tracking sensor.
voxl-camera-server V1.4.5 and above has the ability to use hardware acceleration to compress H264 and H265 video. This is provided by the small_encoded and large_encoded streams. voxl-streamer is configured to stream the hires_small_encoded stream by default. Note that if you want to change the resolution of the RTSP stream provided by voxl-streamer you need to set it in voxl-camera-server.conf since it’s voxl-camera-server that’s encoding the video!
Finally the snapshot stream is unique in that it’s not a steady stream at constant framerate but instead takes a snapshot when it receives the “snapshot” command through any of that camera’s control pipes. This triggers the Qualcomm ISP to do the same pipeline as clicking the shutter button in your smartphone’s camera app!
All of these parameters are valid for every camera or stereo pair. However many of them will be hidden in the config file to reduce clutter where they are not applicable for a particular camera or configuration. For example, the preview stream params are hidden on IMX214 hires sensors since out of the box only the two video streams and snapshot streams are enabled. But, you could opt to disable one of the default streams and enable the preview stream.
The Camera Server config file is in json format and contains an array of camera, each of which may contain the following values:
General Settings
type: sensor type string — see the supported sensor list above name: name used as prefix for pipes published by this camera
enabled: true by default. Set to false to disable the camera.
camera_id: This is the the id of the camera as enumerated by HAL3
camera_id_second: id of the secondary camera when running a stereo pair. Omit or leave as -1 for monocular.
independent_exposure: true or false to enable independent auto exposure for a stereo pair. Default: false
fps: framerate
ae_mode: Auto exposure mode “off”, “manual”, “auto”, “isp”, or “lme_msv”
standby_enabled: enable decimated framerate when CPU reports standby mode, only for TOF (default false)
decimator: TOF framerate decimator when in standby mode
en_preview: Enable the preview stream (true or false)
preview_width: Width of the preview stream image (default sensor dependent, e.g. 640 for ov7251)
preview_height: Height of the preview stream image (default sensor dependent, e.g. 480 for ov7251)
en_raw_preview: publish the raw (pre-ISP) frames instead of ISP-processed ones. (The old pre_format key is no longer used and is removed from configs automatically.)
en_small_video: true or false to enable the small video stream
small_video_width: default 1024
small_video_height: default 768
small_venc_mode: “h264” or “h265”
small_venc_br_ctrl: “cqp” or constant quantization or “cbr” for constant bitrate
small_venc_Qfixed: Quantization to use for cqp mode
small_venc_Qmin: Minimum quantization to allow in cbr mode
small_venc_Qmax: Max quantization to allow in cbr mode
small_venc_nPframes: number of P frames to use between I frames (default 9)
small_venc_mbps: target bitrate for cbr mode (default 2)
en_large_video: true or false to enable the large video stream
large_video_width: default dependent on sensor, typically full resolution
large_video_height: default dependent on sensor, typically full resolution
large_venc_mode: “h264” or “h265”
large_venc_br_ctrl: “cqp” or constant quantization or “cbr” for constant bitrate
large_venc_Qfixed: Quantization to use for cqp mode
large_venc_Qmin: Minimum quantization to allow in cbr mode
large_venc_Qmax: Max quantization to allow in cbr mode
large_venc_nPframes: number of P frames to use between I frames (default 29)
large_venc_mbps: target bitrate for cbr mode (default 40 for h264, 30 for h265)
en_snapshot: true or false
en_snapshot_width: default dependent on sensor, typically full resolution
en_snapshot_height: default dependent on sensor, typically full resolution
snapshot_jpeg_quality: JPEG quality for saved snapshots
exif_focal_length, exif_focal_length_in_35mm_format, exif_fnumber: EXIF metadata written into snapshots
When using libmodal exposure (lme_msv) instead of the ISP’s autoexposure you have more control, this is exposed through the following parameters.
ae_desired_msv: the desired mean sample value, a.k.a. the average value of pixels that the auto exposure algorithm should try to achieve in frame
ae_k_p_ns: the desired p_ns for the exposure algorithm
ae_k_i_ns: the desired k_i for the exposure algorithm
ae_max_i: the desired max_i for the exposure algorithm
ae_filter_alpha: a low-pass filter constant that filters the calculated MSV to slow down responses - the filter used is an IIR filter
ae_ignore_fraction: maximum percentage of saturated (255) pixels that will be used in calculation of MSV. If there are more saturated_pixels / total_pixels, then additional saturated pixels are not used to calculate MSV. This helps prevent image getting too dark if there are large blobs of very bright light
ae_slope: ratio that specifies how much gain vs exposure should be changed when trying to achieve desired MSV. Both gain and exposure linearly affect the pixel brightness, but gain and exposure have different effects on the image quality - mostly in the sense that gain affects granularity and that exposure affects motion blur.
ae_exposure_period: controls the duration where the cells of the camera sensor are exposed to light
ae_gain_period: the gain period associated to the auto exposure (think of this as an amplification factor of the pixels)
As of SDK 1.3.5, CBR mode for h264 and h265 is working properly with some (bitrate) limitations
SDK 1.3.5+
CBR (Constant Bit Rate)
  • *_venc_mbps parameters is used to specify desired video bitrate in Mbit/s
  • CBR has the following limitations on VOXL2 :
    Encoder ModeFPSMin Bitrate (mbps)Max Bitrate (mbps)
    H264301.55.0
    H264601.510.0
    H265303.010.0
    H265603.020.0
    • if desired mbps is lower than the above min bitrate limit, camera server will override the value and set it to min
      • if camera server does not limit the min value, encoder will use MAXIMUM possible Mbps
    • if desired mbps is higher than the limit, encoder will automatically use the maximum value from above
    • _venc_Qmin value should be set to a low value (default 15), allowing encoder to adjust QP to achieved the desired bitrate
    • _venc_Qmax should be set to a high value (in the 40-50 range, maximum 51), allowing encoder to adjust QP to achieved the desired bitrate
    • note that this limitation is not a Hardware limit, it is due to a mis-configuration of the encoder. The fix ([OMX] Fix FPS Hack workaround and fix CBR mode, libvoxl-codec 0.1.3, pulled in by voxl-camera-server 2.2.32) is included in SDK 1.7.0, which is in pre-release at the time of writing; see the SDK 1.7 release notes. SDK 1.3.5 through SDK 1.6.x carry the limits in the table above
    • lower bitrates for h264 / h264 are supported by voxl-streamer application, which can encode raw frames to video and serve rtsp stream
CBR + CQP
  • This is a hybrid mode that uses Constatnt Quantization when there is little motion and Constant Bitrate to limit the maximum bitrate
  • In order to use this mode, select cbr as the bitrate control, however also adjust the Qmin parameter, as described below
  • _venc_Qmin value can be used to lower the bit rate when video is mostly still (value needs to be tuned for use case)
  • As the amount of motion in the image increases, the encoder’s bit rate controller will increase QP (reduce quality), if needed, (up to Qmax) in order to keep the bitrate capped at the desired bitrate
    • Qmin (lowest quantization bound) specifies the lowest quantization that encoder can use, meaning the highest image quality
    • if the encoder would need to use a lower Qmin than is configured (in order to achieve target bitrate), the bitrate controller would be limited by the Qmin and resulting bitrate would be smaller than desired.
      • Sometimes this can be desired in order to avoid wasting bandwidth in CBR mode
      • When there is little motion, the actual bit rate may be smaller than specified in mbps parameter
      • However, when there is sufficient motion, the bitrate will increase and will be capped by the desired mbps value
      • Note: this results in a MAX bitrate instead of CBR mode, which sometimes is desired (low bit rate when there is no motion, capped bitrate during motion)
      • this value specifies the largest Quantization Parameter used in CBR mode when needed to increase quantization in order to keep bitrate at desired value (this typically happens during lots of motion in the image)
      • if Qmax is not large enough, the bit rate controller may not be allowed to increase the quantization parameter sufficiently enough to achieve (to lower) the desired bitrate
  • the following parameters are ignored: _venc_Qfixed
CQP (Constant Quantization Parameter)
  • small_venc_Qfixed / large_venc_Qfixed parameter is used to set the constant Quantization Parameter
  • constant QP does not mean constant bit rate. QP is used to quantize the pixel values but motion estimation will drive bandwidth usage
  • actual bitrate will also depend on video resolution and FPS (more pixels = more bandwidth)
  • the following parameters are ignored: *_venc_Qmin, *_venc_Qmax, *_venc_mbps
Pre SDK 1.3.5
Constant bitrate video compression works but there is a known issue with the hardware accelerated video compressor where a scale factor is applied to the desired bitrate that is dependent on resolution. This scale factor is roughly 13x for 1024x768 video and roughly 30x for 4K video. If you wish to use constant bitrate mode you will need to set a much smaller target bitrate in the config file than desired. Then use voxl-inspect-cam to measure the output bitrate during motion and while still until you find the config file bitrate value that achieves the desired result.
The default encoding scheme is “cqp” or Constant Quantization Parameter which is more useful in most scenarios as it allows the bitrate to drop automatically when there is little motion in the video. Simply tune the small_venc_Qfixed and large_venc_Qfixed quantization parameters to achieve the desired bitrate and quality while in motion. This will save bandwidth and disk space when the drone is still.
Config File Example
Whenever you run voxl-configure-cameras a new default camera server config file is created for that particular camera setup. Here is an example default config file for camera config #6 used on Starling. It was generated by an older release — a config generated today additionally omits pre_format (no longer used) and names the stereo secondary id camera_id_second — but the overall structure is unchanged.
    "version":  0.1,
    "cameras":  [{
            "type": "pmd-tof",
            "name": "tof",
            "enabled":  true,
            "camera_id":    0,
            "fps":  5,
            "en_preview":   true,
            "preview_width":    224,
            "preview_height":   1557,
            "pre_format":   "tof",
            "ae_mode":  "off",
            "standby_enabled":  false,
            "decimator":    5
            "type": "imx214",
            "name": "hires",
            "enabled":  true,
            "camera_id":    1,
            "fps":  30,
            "en_preview":   false,
            "preview_width":    640,
            "preview_height":   480,
            "pre_format":   "nv21",
            "en_small_video":   true,
            "small_video_width":    1024,
            "small_video_height":   768,
            "small_venc_mode":  "h265",
            "small_venc_br_ctrl":   "cqp",
            "small_venc_Qfixed":    30,
            "small_venc_Qmin":  15,
            "small_venc_Qmax":  40,
            "small_venc_nPframes":  9,
            "small_venc_mbps":  2,
            "en_large_video":   true,
            "large_video_width":    4096,
            "large_video_height":   2160,
            "large_venc_mode":  "h265",
            "large_venc_br_ctrl":   "cqp",
            "large_venc_Qfixed":    38,
            "large_venc_Qmin":  15,
            "large_venc_Qmax":  50,
            "large_venc_nPframes":  29,
            "large_venc_mbps":  30,
            "en_snapshot":  true,
            "en_snapshot_width":    4160,
            "en_snapshot_height":   3120,
            "ae_mode":  "isp"
            "type": "ov7251",
            "name": "tracking",
            "enabled":  true,
            "camera_id":    2,
            "fps":  30,
            "en_preview":   true,
            "pre_format":   "raw8",
            "ae_mode":  "lme_msv",
            "ae_desired_msv":   60,
            "ae_filter_alpha":  0.600000023841858,
            "ae_ignore_fraction":   0.20000000298023224,
            "ae_slope": 0.05000000074505806,
            "ae_exposure_period":   1,
            "ae_gain_period":   1
For the available camera configurations as well as the accepted FPS/Dimensions associated to each camera sensor, please follow the link here.
From voxl-camera-server 1.7.0 onwards, all resolutions a sensor supports can be compressed in real time by the hardware encoder.
Note: this feature is only available on VOXL 2
When GPS is being published via the voxl-mavlink-server, voxl-camera-server will geo-tag each snapshot captured with the latest GPS coordinates. The GPS data (latitude, longitude, altitude) will be saved in the JPEG Snapshot EXIF metadata. In order for this to occur, the user must have a valid GPS connected and actively publishing data from a MAVLink compatible flight controller, such as PX4 or ArduPillot.
You can verify GPS is being published with the voxl-inspect-gps tool.
In order to view the EXIF metadata of the photo, the user must pull the photo from the VOXL 2 (that lives in /data/snapshots) and then can look at the properties of the image via a double click or by uploading the image to a website that allows for metadata from the EXIF to be viewed.
Troubleshooting
For general service debugging — logs, restarts, running in the foreground — see Debugging Services.
From a command line, run voxl-camera-server -d0 to view the output of the camera-server initialiation process.
Send the following command to set the fixed exposure and gain:
voxl-send-command set_exp_gain
for example: voxl-send-command tracking set_exp_gain 20.0 100
The name-of-output-stream should match the pipe/stream name that you are using. Since there can be multiple streams for the same camera, you can use any stream to set this param.
The full set of control commands accepted on a camera’s control pipes: set_exp_gain, set_exp, set_gain, set_fps, start_ae, stop_ae, snapshot, snapshot_no_save, set_small_venc_mbps, set_large_venc_mbps, set_misp_venc_mbps, set_misp_venc_roi, set_misp_awb, set_misp_gamma.
Make sure you are using a supported camera configuration for the VOXL 2, and VOXL 2 Mini.
Source Code
The source code for VOXL Camera Server can be found here
