VOXL ArduPilot
Support for VOXL 2 is in mainline ArduPilot now. This page will explain current status and will be updated as improvements are made.
For advanced / experienced users who see the VOXL 2 (and VOXL 2 mini) support in ArduPilot and want to start playing around with it here are some helpful tips.
So far it has only been tested on four different models of small to medium sized quadcopter (ArduCopter) and one small fixed wing (ArduPlane). Also, the VOXL 2 IO board (https://www.modalai.com/products/voxl2-io) is supported and that provides up to 8 PWM outputs for use with PWM ESCs on quadcopters or PWM servos for fixed wings. The VOXL 2 IO board has been tested on a quadcopter with 4 PWM ESCs and a fixed wing with PWM servos.
- Install a recent SDK (1.4.0+)
- Disable the PX4 service
voxl2:~$ systemctl disable voxl-px4
- Download and install the latest prebuilt ArduPilot QURT Debian package
- ArduCopter: https://firmware.ardupilot.org/Copter/latest/QURT/
- For example:
voxl2:~$ wget https://firmware.ardupilot.org/Copter/latest/QURT/voxl-ardupilot_ArduCopter_4.7.0-cb690799_arm64.debvoxl2:~$ dpkg -i voxl-ardupilot_ArduCopter_4.7.0-cb690799_arm64.deb
- ArduPlane: https://firmware.ardupilot.org/Plane/latest/QURT/
- ArduRover: https://firmware.ardupilot.org/Rover/latest/QURT/
- Add link to desired default parameters in \data\APM (optional)
- For example:
voxl2:~$ cd /data/APMvoxl2:/data/APM$ ln -s D0013.parm defaults.parm
- Enable the ardupilot service
voxl2:~$ systemctl enable voxl-ardupilot
There are a few default parameter files available in mainline here
The AutonomyDevKit parameters should also be correct for the Starling 2
Validate all parameter settings. Follow all relevant ArduPilot setup documentation to make sure that the vehicle is configured properly. Calibrate all sensors and the RC.
You can get the firmware builds directly from the ArduPilot servers or you can build it yourself. In order to build it you will need to procure the Hexagon SDK from Qualcomm and integrate into a build docker. This project will help get that all setup.
There is more build / setup info on the ArduPilot repo
Here is a forum post with more information
Test flight video here
Test flight video with VOXL 2 IO board and PWM ESCs here
