Using OpenCL inside a Docker Container on VOXL2
Introduction
OpenCL can be used within a Docker container on VOXL2 after following the correct setup instructions.
Create a New Directory on VOXL2
cd /home/root/
mkdir -p opencl-docker/deps
cd opencl-docker/deps
Generate the Required Dependencies using VOXL2 Native OS
apt install dpkg-repack
dpkg-repack qti-adreno
dpkg-repack libcutils0
dpkg-repack libsync
dpkg-repack qti-libion
dpkg-repack liblog0
You should have the following deb packages in opencl-docker/deps:
ls opencl-docker/deps
libcutils0_0-r1_arm64.deb liblog0_1.0-r1_arm64.deb libsync_1.0-r1_arm64.deb qti-adreno_1.0-r0_arm64.deb qti-libion_0-r1_arm64.deb
Install Docker on VOXL2
- follow official instructions https://docs.docker.com/engine/install/ubuntu/ , specifically:
curl -fsSL https://get.docker.com -o get-docker.sh chmod +x get-docker.sh ./get-docker.sh
Create a Dockerfile with the following contents in opencl-docker directory:
FROM arm64v8/ubuntu:22.04
# Install necessary dependencies
RUN apt-get update && \
apt-get install -y \
cmake \
build-essential \
libglib2.0-0
COPY deps /opt/deps
## Create required directory for qti-adreno install
RUN mkdir /usr/include/KHR
RUN dpkg -i /opt/deps/*.deb
Build the Docker Image:
cd opencl-docker
docker build -t opencl-docker:latest .
Create a Test Application
Create a source file opencl-query.c with the following contents
#include <stdio.h>
#include <stdlib.h>
#include <CL/cl.h>
int main() {
int i, j;
char* value;
size_t valueSize;
cl_uint platformCount;
cl_platform_id* platforms;
cl_uint deviceCount;
cl_device_id* devices;
cl_uint maxComputeUnits;
// get all platforms
clGetPlatformIDs(0, NULL, &platformCount);
printf("OpenCL platform count: %d\n",platformCount);
platforms = (cl_platform_id*) malloc(sizeof(cl_platform_id) * platformCount);
clGetPlatformIDs(platformCount, platforms, NULL);
for (i = 0; i < platformCount; i++) {
// get all devices
clGetDeviceIDs(platforms[i], CL_DEVICE_TYPE_ALL, 0, NULL, &deviceCount);
printf("OpenCL device count: %d\n",deviceCount);
devices = (cl_device_id*) malloc(sizeof(cl_device_id) * deviceCount);
clGetDeviceIDs(platforms[i], CL_DEVICE_TYPE_ALL, deviceCount, devices, NULL);
// for each device print critical attributes
for (j = 0; j < deviceCount; j++) {
// print device name
clGetDeviceInfo(devices[j], CL_DEVICE_NAME, 0, NULL, &valueSize);
value = (char*) malloc(valueSize);
clGetDeviceInfo(devices[j], CL_DEVICE_NAME, valueSize, value, NULL);
printf("%d. Device: %s\n", j+1, value);
free(value);
// print hardware device version
clGetDeviceInfo(devices[j], CL_DEVICE_VERSION, 0, NULL, &valueSize);
clGetDeviceInfo(devices[j], CL_DEVICE_VERSION, valueSize, value, NULL);
printf(" %d.%d Hardware version: %s\n", j+1, 1, value);
free(value);
// print software driver version
clGetDeviceInfo(devices[j], CL_DRIVER_VERSION, 0, NULL, &valueSize);
clGetDeviceInfo(devices[j], CL_DRIVER_VERSION, valueSize, value, NULL);
printf(" %d.%d Software version: %s\n", j+1, 2, value);
free(value);
// print c version supported by compiler for device
clGetDeviceInfo(devices[j], CL_DEVICE_OPENCL_C_VERSION, 0, NULL, &valueSize);
clGetDeviceInfo(devices[j], CL_DEVICE_OPENCL_C_VERSION, valueSize, value, NULL);
printf(" %d.%d OpenCL C version: %s\n", j+1, 3, value);
free(value);
// print parallel compute units
clGetDeviceInfo(devices[j], CL_DEVICE_MAX_COMPUTE_UNITS,
sizeof(maxComputeUnits), &maxComputeUnits, NULL);
printf(" %d.%d Parallel compute units: %d\n", j+1, 4, maxComputeUnits);
free(devices);
free(platforms);
return 0;
Build the Test Application
gcc -O2 -Wall -o opencl-query opencl-query.c -lOpenCL
Run the Test App Outside Docker
voxl2:~/opencl-docker$ ./opencl-query
OpenCL platform count: 1
OpenCL device count: 1
1. Device: QUALCOMM Adreno(TM)
1.1 Hardware version: OpenCL 2.0 Adreno(TM) 650
1.2 Software version: OpenCL 2.0 QUALCOMM build: commit # changeid # Date: 11/10/21 Wed Local Branch: Remote Branch: Compiler E031.37.12.01
1.3 OpenCL C version: OpenCL C 2.0 Adreno(TM) 650
1.4 Parallel compute units: 3
Spin up a Docker Container
--privilegedflag maps all the linux devices to the container- if this is a concern, the
--privilegedflag can be replaced with--device=/dev/kgsl-3d0 --device=/dev/iondocker run -it --rm --privileged -v `pwd`:/opt/code -w /opt/code opencl-docker:latest bash
Run the Test App Inside the Docker Container
root@f23c81c4a254:/opt/code# ./opencl-query
