This component is EOL, please see its replacement M0151
USB Expander and Debug Add-On Board User Guide
VOXL USB Expander and Debug Add-On board adds an additional USB2 connector and allows VOXL to be put into fastboot or emergency boot modes.
  1. Summary
  2. Board Connections
  3. Specification
  4. USB2 Host Pinout
  5. Connecting to VOXL
  6. Connecting a USB2 Peripheral
  7. Forcing the VOXL into Fastboot to Unbrick
  8. Using the Debug Console
  9. Forcing the VOXL into Emergency Boot
The VOXL USB Expander and Debug Add-On board provides:
  • Ability to connect an additional USB2 peripheral device to VOXL
  • A debug console for low level system debugging
  • A switch that will force VOXL to boot into fastboot mode (for reflashing the System Image if the unit is bricked in the field)
  • A switch that will force VOXL to boot into emergency boot mode (used at the factory only)
    • NOTE: newer versions of the board don’t have this switch populated
Board Connections
Specification
SpecicifcationValue
Weight5g
Debug Console ConnectorMicro USB, Female
Debug Console Mating ConnectorMicro USB, Male
USB2 Host Connector4 Position JST GH, Vertical, BM04B-GHS-TBT
USB2 Host Mating ConnectorJST GHR-04V-S
J1 ConnectorSamtec Inc, MPN: QTH-030-01-F-D-K
J1 Mating ConnectorSamtec Inc., MPN: QSH-030-01-L-D-A-K
USB2 Host Pinout
Pin 1 is marked in the Board Connections graphic above.
PinValue
1VBUS
2USB_M
3USB_P
4GND
Connecting to VOXL
To connect the USB Expander and Debug Add-On board to VOXL:
  • Attach the daughter board’s J1 connector to VOXL’s J13 connector
A USB2 peripheral can be connected via a JST GHR-04V-S connector following the pinouts specified in the datasheet.
To validate the connection:
  • Power off the VOXL
  • Attach the USB Expander and Debug Add-On board
  • Ensure the FASTBOOT labeled switch is set to off
  • Ensure the EMERG BOOT labeled switch is set to off
    • NOTE: if your board is missing the EMERG BOOT switch, this is OK as its default un-populated state is OFF
  • Attach the USB2 peripheral
  • Power on the VOXL
  • Connect a Micro USB cable to VOXL’s USB port and connect to a Linux PC
Open the terminal in the Linux PC and run the following:
adb shell
Now you’re inside VOXL, run the following, where in this use case we’ve attached a Flight Core board to the USB2 Host connector (showing up as the STMicroelectronics MCU):
/ # lsusb
Bus 001 Device 003: ID 0483:a32f STMicroelectronics
Follow the unbrick procedure found at docs.modalai.com/unbrick-voxl
You’ll need two MicroUSB cables for this procedure.
  • Connect a second Micro USB cable to the Add-On board’s Micro USB port and connect to a Linux PC. It may display as FT232R USB UART and will exist as /dev/ttyUSB0
  • Power on the VOXL
Open Terminal A in the Linux PC and run the following command (if screen isn’t installed, first run apt install screen):
screen /dev/ttyUSB0 115200
[HIT ENTER]
Open Terminal B in the Linux PC and run the following commands:
adb shell
reboot
You should now see debug information in Terminal A:
[10] Opening SSR Glink Port success
[20] Glink Connection between APPS and RPM established
[40] UFS init success
[80] pm8x41_get_is_cold_boot: cold boot
[90] Unable to locate /bootselect partition
[90] Loading (boot) image (57376768): start
[300] Loading (boot) image (57376768): done
[310] use_signed_kernel=1, is_unlocked=1, is_tampered=0.
[310] decompressing kernel image: start
[630] decompressing kernel image: done
[640] Best match DTB tags 291/00000008/0x00000003/30001/20009/10013/0/0/940319e2/51297
[650] Using pmic info 0x20009/0x10013/0x0/0x0 for device 0x20009/0x10113/0x0/0x0
[650] cmdline: noinitrd rw console=ttyHSL0,115200,n8 androidboot.hardware=qcom ehci-hcd.park=3 msm_rtb.filter=0x37 lpm_levels.sleep_disabled=0 rootwait net.ifnames=0 androidboot.bootdevice=624000.ufshc androidboot.serialno=a0259b4a androidboot.baseband=apq root[670] Updating device tree: start
[680] Updating device tree: done
[680] RPM GLINK UnInit
[690] booting linux @ 0x80080000, ramdisk @ 0x82200000 (0), tags/device tree @ 0x82000000
[690] Jumping to kernel via monitor
This is typically done at the factory and not in the field by a normal user. To force the VOXL to boot into emergency boot mode:
  • Ensure the EMERG BOOT labeled switch is set to on
  • Attach
  • Power on the VOXL
The device will show up on a Linux PC as Qualcomm, Inc. Gobi Wireless Modem:
/ lsusb
Bus 001 Device 015: ID 05c6:9008 Qualcomm, Inc. Gobi Wireless Modem (QDL mode)
