Seeker Datasheet
  1. Overview
  2. High-Level Specs
    1. Flight Specs
    2. Processing Specs
    3. Radio Specifications
    4. 3D STEP Files
The VOXL Seeker is a compact development drone. Use cases are for reconnaissance, mapping and photogrammetry, indoor asset inspection, swarming, GPS denied navigation. See below for specifications.
High-Level Specs
Seeker-flowchart Seeker-labeled
Flight Specs
ComponentSpecification
Take-off Weight550g
Diagonal Size270mm motor to motor diagonal
6 inch propellers
Operating EnvironmentInside - with ModalAI VIO navigation
Outside - with GPS or VIO navigation
IP RatingNone
NDAA CompliantYes
Blue UAS Framework CompliantYes
Country of OriginUSA
Flight Time~27 minutes
Payload Capacity (Impacts flight time)50 - 100g
MotorsQTY. 4 T-motor F2203.5 1500kv Motors
PropellersQTY. 4 6 inch propellers
Frame270mm Carbon fiber air frame manufactured from 1/8” carbon panels
ESCsModalAI VOXL 4-in-1 ESC V2
Battery11.1V 3S 3000mAh 10C Li-Ion Battery - XT30
3S SONYVTC6 (recommended) 18650 (triangle orientation packaging)
Landing GearCustom landing gear (front only)
Maximum Speed5m/s per PX4 setting
Maximum Height122m per PX4 setting
Geographic Limits SystemPX4 Geo Fencing
GPSUblox Neo-M8N module
Power ModuleModalAI Power Module v3 - 5V/6A
Fail SafePX4 Safety Configuration
Battery4S with XT60 Connector (6S with expanded battery standoffs), 4S weight 336g
Operating Temperature+5C to +40C
Wind PerformanceContinuous 20MPH, Gusts over 25MPH
Processing Specs
CPUQualcomm® Snapdragon 821
Sensors1 ICM-42688-P IMUs
2 Barometers (BMP338 and TDK ICP-10100)
GPS (Holybro 2nd GPS)
Magnetometer Connection (Dronecode compliant)
Spare SPI and GPIO port
Image SensorsTracking camera OV7251-A36
Time of Flight Module 68FX053B
Front OV7251-A50 stereo cameras
Additional I/O2 GPIO
I2C
1 SPI
Operating SystemLinux Yocto Jethro with 3.18 Kernel
Open ApplicationsDocker
ROS
PX4 Software
ModalAI SoftwareVOXL®-SDK
Video TransmissionWi-Fi (2.4GHz or 5GHz) or Cellular (multi-band, carrier dependent)
Developer ConnectivityQGroundControl
RViz
ADB (Android Debug Bridge)
RadioFrequencyPowerRegulatory
Remote ControlSpektrum DSMX Receiver (2.4GHz)
Wi-Fi2.4GHz / 5.8GHz175mW / 83mWUS FCC ID:PPD-QCNFA324 Japan MIC ID: 003-140224
4G Cellular (Optional)4G Modem Datasheet
3D STEP Files
