SDK 1.3.X Release Notes
Available now at https://downloads.modalai.com
SDK 1.3.X Support Matrix
PlatformPCB TargetsSupport Status
VOXL 2M0054-1, M0054-2, M0154-1, M0154-2Yes
VOXL 2 MiniM0104-1Yes
VOXLM0006-2No
VOXL FlightM0019-2No
Qualcomm Flight RB5M0052-2No
Flight Core v2M0087-1No
Flight Core v1M0018-1No
The SDK-1.3.5 release on the QRB5165 platform use the 1.7.10 system image. See here for system image release notes.
  1. SDK 1.3.5 Package List and Changelog
    2. SDK 1.3.5 Full Changelog (from SDK 1.3.3)
  2. SDK 1.3.3 Package List and Changelog
    1. SDK 1.3.3 Package List
    2. SDK 1.3.3 Full Changelog (from SDK 1.3.2)
  3. SDK 1.3.2 Package List and Changelog
    1. SDK 1.3.2 Package List
    2. SDK 1.3.2 Full Changelog (from SDK 1.3.1)
  4. SDK 1.3.1 Package List and Changelog
    1. SDK 1.3.1 Package List
    2. SDK 1.3.1 Full Changelog (from SDK 1.3.0)
  5. SDK 1.3.0 Package List and Changelog
    1. SDK 1.3.0 Package List
    2. SDK 1.3.0 Full Changelog (from SDK 1.2.0)
  6. SDK 1.3.X Test Matrix
    1. SDK 1.3.0 Test Status
Release date: October 3, 2024
Package list and changes from SDK-1.3.3 to SDK-1.3.5
PackageVersionAPQ8096QRB5165
apq8096-dfs-server0.3.1 (unchanged)
apq8096-imu-server1.1.0 (unchanged)
apq8096-libpng1.6.38-1 (unchanged)
apq8096-rangefinder-server0.1.3 (unchanged)
apq8096-system-tweaks0.2.3 (unchanged)
apq8096-tflite2.8.3-1 (unchanged)
libapq8096-io0.6.0 (unchanged)
libfc-sensor1.0.7 (unchanged)
libmodal-cv0.5.8 –> 0.5.11
libmodal-exposure0.1.0 –> 0.1.1
libmodal-journal0.2.2 (unchanged)
libmodal-json0.4.3 (unchanged)
libmodal-pipe2.10.1 –> 2.10.2
libqrb5165-io0.4.6 (unchanged)
librc-math1.4.2 (unchanged)
libslpi-link1.0.0 (unchanged)
libvoxl-cci-direct0.2.1 (unchanged)
libvoxl-cutils0.1.1 (unchanged)
modalai-slpi1.1.19 (unchanged)
qrb5165-dfs-server0.2.0 (unchanged)
qrb5165-imu-server1.0.1 (unchanged)
qrb5165-rangefinder-server0.1.3 (unchanged)
qrb5165-system-tweaks0.3.0 (unchanged)
qrb5165-tflite2.8.0-2 (unchanged)
voxl-bind-spektrum0.1.1 (unchanged)
voxl-boost1.65.0 (unchanged)
voxl-camera-calibration0.5.6 –> 0.5.7
voxl-camera-server1.9.8 –> 2.0.1
voxl-ceres-solver2:1.14.0-10 (unchanged)
voxl-configurator0.7.7 –> 0.8.5
voxl-cpu-monitor0.4.8 (unchanged)
voxl-docker-support1.3.1 (unchanged)
voxl-elrs0.2.1 –> 0.2.2
voxl-esc1.4.4 –> 1.4.7
voxl-feature-tracker0.3.14 –> 0.4.1
voxl-flow-server0.3.6 (unchanged)
voxl-gphoto2-server0.0.10 (unchanged)
voxl-jpeg-turbo2.1.3-5 (unchanged)
voxl-lepton-server1.2.2 –> 1.2.3
voxl-lepton-tracker0.0.1 –> 0.0.2
voxl-libgphoto20.0.4 (unchanged)
voxl-libuvc1.0.7 (unchanged)
voxl-logger0.4.3 –> 0.4.7
voxl-mapper0.2.0 (unchanged)
voxl-mavcam-manager0.5.6 –> 0.5.7
voxl-mavlink-server1.4.2 (unchanged)
voxl-modem1.1.3 (unchanged)
voxl-mongoose7.7.0-1 (unchanged)
voxl-mpa-tools1.1.9 –> 1.2.3
voxl-mpa-to-ros0.3.9 (unchanged)
voxl-mpa-to-ros20.0.2 (unchanged)
voxl-neopixel-manager0.0.3 (unchanged)
voxl-nlopt2.5.0-4 (unchanged)
voxl-opencv4.5.5-2 (unchanged)
voxl-open-vins0.4.12 –> 0.4.14
voxl-open-vins-server0.2.59 –> 0.2.75
voxl-osdnone –> 0.0.1
voxl-portal0.6.9 –> 0.7.0
voxl-px41.14.0-2.0.79 –> 1.14.0-2.0.84
voxl-px4-imu-server0.1.2 (unchanged)
voxl-px4-params0.4.7 –> 0.5.3
voxl-qvio-server1.0.4 (unchanged)
voxl-remote-id0.0.9 (unchanged)
voxl-reset-slpi0.0.1 (unchanged)
voxl-ros2-foxy0.0.1 (unchanged)
voxl-state-estimator0.0.2 (unchanged)
voxl-streamer0.7.4 (unchanged)
voxl-tag-detector0.0.4 (unchanged)
voxl-tflite-server0.3.4 (unchanged)
voxl-utils1.4.2 –> 1.4.3
voxl-uvc-server0.1.7 (unchanged)
voxl-vision-hub1.8.3 –> 1.8.9
voxl-voxblox1.1.5 (unchanged)
voxl-vpn0.0.6 (unchanged)
voxl-vtx1.0.3 –> 1.1.0
voxl2-io0.0.3 (unchanged)
libmodal-exposure  (0.1.0 to 0.1.1)
0.1.1
    * fix gain update period bug, which resulted in old gain to be applied if gain update period was set to 1
libmodal-pipe  (2.10.1 to 2.10.2)
2.10.2
    * inconsequential fix in error print text
voxl-camera-calibration  (0.5.6 to 0.5.7)
0.5.7
    * add handling for camera pipe not existing
voxl-camera-server  (1.9.8 to 2.0.1)
2.0.1
    * add boson sensor type
    * add C37 config
2.0.0
    * fix C36 config
1.9.9
    * add C36 - M0173 w/ imx412 and dual ar0144
voxl-configurator  (0.7.8 to 0.8.5)
0.8.5
    * D0008: update default services
0.8.4
    * add thermalflow experimental mode
0.8.3
    * D0008 swap lepton to manual mode
0.8.2
    * Json option for calibration check
    * add starling 2 max rev2 question to voxl-configure-sku
0.8.1
    * D0008 logic tweaks
0.8.0
    * add voxl-vtx support
0.7.9
    * add D0008 V5 support (C36)
voxl-elrs  (0.2.1 to 0.2.2)
0.2.2
    * Fixed OS detection and enabled Multiarch
voxl-esc  (1.4.5 to 1.4.7)
1.4.7
    * fpv esc param tweak
1.4.6
    * enable pwm outputs
    * enable gpio toggling
    * add check for valid baud rate in params upload script
    * esc firmware v39.20
voxl-feature-tracker  (0.3.14 to 0.4.1)
0.4.1
    * add voxl-test-feature-extraction tool
    * improve overlay and command line options
    * make output pipe name an extenstion of input pipe
0.4.0
    * big cleanup, bugfixes
voxl-lepton-server  (1.2.2 to 1.2.3)
1.2.3
    * transition to only doing bulk reads
voxl-logger  (0.4.3 to 0.4.7)
0.4.7
    * auto-logging daemon mode
0.4.6
    * support auto-logging service, log when vehicle is armed
0.4.5
    * OV support updates
    * added VFT feature logging
voxl-mavcam-manager  (0.5.6 to 0.5.7)
0.5.7
    * update mavlink_sys_id logic
voxl-mpa-tools  (1.1.9 to 1.2.3)
1.2.3
    * starling 2 max hw rev 2 extrinsics
    * add name print to voxl-inspect-extrinsics
1.2.2
    * fix d0008_v5 extrinsics
1.2.1
    * add voxl-inspect-vio tool
1.2.0
    * add d0008_v5 extrinsics
voxl-portal  (0.6.9 to 0.7.0)
0.7.0
    * fix url port lookup
voxl-px4-params  (0.4.7 to 0.5.3)
0.5.3
    * D0008: modify default flight modes
0.5.2
    * d0008 in-field tuning updates
0.5.1
    * update osd params
0.5.0
    * add flow_offboard exp params
0.4.9
    * VFC updates
    * add initial D0015 param set
0.4.8
    * D0008: param updates
voxl-px4  (1.14.0-2.0.79 to 1.14.0-2.0.84)
1.14.0-2.0.84
    * fix gpio not toggling if turtle mode enabled
1.14.0-2.0.83
    * Added a remote OSD capability
1.14.0-2.0.82
    * Major update of HITL. Now includes way to send VIO data externally to voxl-vision-hub for VFC.
1.14.0-2.0.81
    * Make i2c driver mutex one per bus instead of a single static one
    * Add support for D0015 fixed wing
1.14.0-2.0.80
    * Make sure correct OSD driver is started based on platform and VTX model
voxl-utils  (1.4.2 to 1.4.3)
1.4.3
    * add wwan0 to network prefs
voxl-vision-hub  (1.8.3 to 1.8.9)
1.8.9
    * fix buffer overflow in imu manager
    * add factory_enable_vfc_starling_flow option
1.8.8
    * fix OSD formatting
1.8.7
    * Changed backtrack to only be active while button is pressed, not on toggle
    * add factory_enable_vfc_fpv_flow configuration option
1.8.6
    * Added backtrack feature to VFC
    * HITL support in VFC
    * Added optional method to drop out of VFC if desired flight mode is not available
1.8.5
    * Updated Voxl Flight Controller (VFC) parameters for FPV
1.8.4
    * Integration of Voxl Flight Controller (VFC) into voxl-vision-hub
voxl-osd (initial release)
Release date: August 5, 2024
Package list and changes from SDK-1.3.2 to SDK-1.3.3
libmodal-cv0.5.8 (unchanged)
libmodal-exposure0.1.0 (unchanged)
libmodal-pipe2.10.1 (unchanged)
voxl-camera-calibration0.5.6 (unchanged)
voxl-camera-server1.9.8 (unchanged)
voxl-configurator0.7.7 –> 0.7.8
voxl-elrs0.2.1 (unchanged)
voxl-esc1.4.4 –> 1.4.5
voxl-feature-tracker0.3.14 (unchanged)
voxl-lepton-server1.2.2 (unchanged)
voxl-lepton-tracker0.0.1 (unchanged)
voxl-logger0.4.3 (unchanged)
voxl-mavcam-manager0.5.6 (unchanged)
voxl-mpa-tools1.1.9 (unchanged)
voxl-open-vins0.4.12 (unchanged)
voxl-open-vins-server0.2.59 (unchanged)
voxl-portal0.6.9 (unchanged)
voxl-px41.14.0-2.0.79 (unchanged)
voxl-px4-params0.4.7 (unchanged)
voxl-utils1.4.2 (unchanged)
voxl-vision-hub1.8.3 (unchanged)
voxl-vtx1.0.3 (unchanged)
voxl-configurator  (0.7.7 to 0.7.8)
0.7.8
    * update OSD handling
    * load OSD params
    * add more modem definitions
voxl-esc  (1.4.4 to 1.4.5)
1.4.5
    * make querying more robust
    * update D0013 params
    * add multi-arch support
Release date: July 31, 2024
Package list and changes from SDK-1.3.1 to SDK-1.3.2
libmodal-pipe2.10.0 –> 2.10.1
libqrb5165-io0.4.5 –> 0.4.6
libslpi-linknone –> 1.0.0
modalai-slpi1.1.17 –> 1.1.19
qrb5165-system-tweaks0.2.6 –> 0.3.0
voxl-camera-server1.9.6 –> 1.9.8
voxl-configurator0.7.2 –> 0.7.7
voxl-esc1.4.3 –> 1.4.4
voxl-lepton-server1.2.1 –> 1.2.2
voxl-logger0.4.1 –> 0.4.3
voxl-mavlink-server1.4.1 –> 1.4.2
voxl-modem1.1.2 –> 1.1.3
voxl-mpa-tools1.1.8 –> 1.1.9
voxl-mpa-to-ros0.3.8 –> 0.3.9
voxl-px41.14.0-2.0.77 –> 1.14.0-2.0.79
voxl-px4-params0.4.5 –> 0.4.7
voxl-state-estimatornone –> 0.0.2
voxl-vision-hub1.8.0 –> 1.8.3
libmodal-pipe  (2.10.0 to 2.10.1)
2.10.1
    * add raw10 + raw12 support
libqrb5165-io  (0.4.5 to 0.4.6)
0.4.6
    * remove unused google test stuff in build (for now)
qrb5165-system-tweaks  (0.2.6 to 0.3.0)
0.3.0
    * add option to swap softap wifi mode between 2.4 and 5ghz
voxl-camera-server  (1.9.6 to 1.9.8)
1.9.8
    * update D0013: C31 - dual ar0144
1.9.7
    * fix bug where snapshots had double exif blocks, thanks @hlyvko !
    * add milliseconds to snapshot file name to support rapid snapshots
    * keep either small video or preview streams running when using only snapshots to keep AE alive
    * OMX buffer fix to remove automatic memcopy
voxl-configurator  (0.7.2 to 0.7.7)
0.7.7
    * add OSD driver handling and -X option to sku builder for certain drones
0.7.6
    * D0008: re-enable voxl-mavcam-manager
    * D0008: no VIO by default
0.7.5
    * D0008: enable voxl-streamer
0.7.4
    * lots of changes for D0008 and experimental workflows
0.7.3
    * add modem config to wizard
voxl-esc  (1.4.3 to 1.4.4)
1.4.4
    * add pyc binaries for python 3.11 and 3.12
    * add test script for pwm output command
voxl-lepton-server  (1.2.1 to 1.2.2)
1.2.2
    * config mode for M0173 with rotated image for Starling 2 and Max
voxl-logger  (0.4.1 to 0.4.3)
0.4.3
    * fix bug logging vio_data_t and qvio_extended R_imu_to_cam extrinsics
0.4.2
    * replace runtime dependency libpng-dev with libpng16-16
voxl-mavlink-server  (1.4.1 to 1.4.2)
1.4.2
    * allow different mavlink dialects between autopilot and gcs (don't discard crc-failures on that traffic)
voxl-modem  (1.1.2 to 1.1.3)
1.1.3
    * add microhard config option
voxl-mpa-to-ros  (0.3.8 to 0.3.9)
0.3.9
    * add camera_info and cal data
voxl-mpa-tools  (1.1.8 to 1.1.9)
1.1.9
    * add voxl-send-esc-pwm-cmd tool
voxl-px4-params  (0.4.5 to 0.4.7)
0.4.7
    * D0008: fix some EKF2 params not setting
0.4.6
    * update D0008 params from source
voxl-px4  (1.14.0-2.0.77 to 1.14.0-2.0.79)
1.14.0-2.0.79
    * Add VTX GPIO to voxl-esc
1.14.0-2.0.78
    * Add VIO quality to OSD
voxl-vision-hub  (1.8.0 to 1.8.3)
1.8.3
    * update backtrack default rc channel -> 10
    * added rc monitoring for backtrack mode handling
1.8.2
    * more stringent check when detecting autopilot sysid like we do in mavlink server
1.8.1
    * add factory_enable_backtrack option
libslpi-link (initial release)
voxl-state-estimator (initial release)
Release date: July 15, 2024
Package list and changes from SDK-1.3.0 to SDK-1.3.1
libmodal-cv0.5.6 –> 0.5.8
libmodal-pipe2.10.0 (unchanged)
libqrb5165-io0.4.5 (unchanged)
modalai-slpi1.1.14 –> 1.1.17
qrb5165-system-tweaks0.2.6 (unchanged)
voxl-camera-calibration0.5.4 –> 0.5.6
voxl-camera-server1.9.4 –> 1.9.6
voxl-configurator0.6.6 –> 0.7.2
voxl-elrs0.2.0 –> 0.2.1
voxl-esc1.4.3 (unchanged)
voxl-feature-tracker0.3.10 –> 0.3.14
voxl-lepton-server1.2.1 (unchanged)
voxl-logger0.4.1 (unchanged)
voxl-mavlink-server1.4.1 (unchanged)
voxl-modem1.1.2 (unchanged)
voxl-mpa-tools1.1.6 –> 1.1.8
voxl-mpa-to-ros0.3.8 (unchanged)
voxl-open-vins0.4.11 –> 0.4.12
voxl-open-vins-server0.2.53 –> 0.2.59
voxl-portal0.6.6 –> 0.6.9
voxl-px41.14.0-2.0.73 –> 1.14.0-2.0.77
voxl-px4-params0.4.2 –> 0.4.5
voxl-reset-slpinone –> 0.0.1
voxl-utils1.4.1 –> 1.4.2
voxl-vision-hub1.8.0 (unchanged)
voxl-vtx1.0.2 –> 1.0.3
voxl-camera-calibration  (0.5.5 to 0.5.6)
0.5.6
    * print pass or fail to the image overlay when complete
voxl-camera-server  (1.9.4 to 1.9.6)
1.9.6
    * update to C29 config
    * OMX encoder settings tweak
1.9.5
    * add C32 camera config for D0008
voxl-configurator  (0.6.6 to 0.7.2)
0.7.2
    * Starling 2 rotate lepton image
0.7.1
    * toward D0015 support
    * better support for extras "-X" bitmask in SKU
    * print out extras names and modem configs in inspect-sku
0.6.10
    * vins custom cam config handling
0.6.8
    * add ghost radio helper to setup
    * add c29 extrinsics fro D0012 Starling 2 Max
    * print transmitter name in voxl-inspect-sku
    * add C29 as suggested config for D0012
0.6.7
    * D0008 add suggestion for C32 cam config
voxl-elrs  (0.2.0 to 0.2.1)
0.2.1
    * Add support for flashing iFlight Commando8 version 2 transmitter (FW: v3.4.2)
    * Small QoL update to debug python script for ELRS firmware development
voxl-feature-tracker  (0.3.10 to 0.3.14)
0.3.14
    * make search params, sorting, and pixel filters configurable
voxl-mpa-tools  (1.1.6 to 1.1.8)
1.1.8
    * add D0015 extrinsics
1.1.7
    * add option to print a single measurement and return in voxl-inspect-vibration
    * voxl-inspect vibration now defaults to imu_apps for ease of use
    * new extrinsics for D0012 Starling 2 Max with C29 config (with TOF)
voxl-portal  (0.6.6 to 0.6.9)
0.6.9
    * health check page under debug shows inspect services, calibration files and live vibration values
    * system check page under debug which runs the voxl health check
0.6.8
    * Debug tab now has inspect services and system check
0.6.7
    * new page under debug for health check which runs a health check and displays the results in a table
voxl-px4-params  (0.4.2 to 0.4.5)
0.4.5
    * split out MPC params from Starling 2 drones
    * add disarm when kill switch is hit
    * tuning improvements
0.4.4
0.4.3
    * update commando switch params
voxl-px4  (1.14.0-2.0.73 to 1.14.0-2.0.77)
1.14.0-2.0.77
    * Set the minimum scheduling interval for voxl2_io module to 5ms in order to fix rc input lag when all pwm outputs are disabled
1.14.0-2.0.76
    * Fixed a small memory leak in uORBManager.cpp
1.14.0-2.0.75
    * Moved to a new larger heap exposed by newer SLPI image and added some diagnostics
1.14.0-2.0.74
    * Added new artifact mode to the voxl2 startup scripts
voxl-utils  (1.4.1 to 1.4.2)
1.4.2
    * fix bug causing dpkg-query errors
voxl-reset-slpi (none to 0.0.1)
    * initial release
Release date: June 3, 2024
Package list and changes from SDK-1.2.0 to SDK-1.3.0
libfc-sensor1.0.5 –> 1.0.7
libmodal-cv0.4.0 –> 0.5.6
modalai-slpi1.1.12 –> 1.1.14
qrb5165-rangefinder-server0.1.1 –> 0.1.3
voxl-camera-calibration0.5.4 –> 0.5.4
voxl-camera-server1.9.1 –> 1.9.4
voxl-configurator0.5.6 –> 0.6.6
voxl-elrs0.1.3 –> 0.2.0
voxl-esc1.4.0 –> 1.4.3
voxl-feature-tracker0.3.2 –> 0.3.10
voxl-flow-server0.3.3 –> 0.3.6
voxl-lepton-server1.2.0 –> 1.2.1
voxl-lepton-trackernone –> 0.0.1
voxl-logger0.4.0 –> 0.4.1
voxl-mavcam-manager0.5.3 –> 0.5.6
voxl-mavlink-server1.4.0 –> 1.4.1
voxl-modem1.0.9 –> 1.1.2
voxl-mpa-tools1.1.5 –> 1.1.6
voxl-mpa-to-ros0.3.7 –> 0.3.8
voxl-open-vins0.4.4 –> 0.4.11
voxl-open-vins-server0.2.18 –> 0.2.53
voxl-portal0.6.5 –> 0.6.6
voxl-px41.14.0-2.0.68 –> 1.14.0-2.0.73
voxl-px4-params0.3.8 –> 0.4.2
voxl-qvio-server1.0.2 –> 1.0.4
voxl-tflite-server0.3.2 –> 0.3.4
voxl-utils1.3.9 –> 1.4.1
voxl-uvc-server0.1.6 –> 0.1.7
voxl-vision-hub1.7.4 –> 1.8.0
voxl-vtxnone –> 1.0.2
voxl2-ionone –> 0.0.3
qrb5165-rangefinder-server  (0.1.1 to 0.1.3)
0.1.3
    * add test option to voxl-inspect-rangefinders
    * mods for M0157
0.1.2
    * add config option for rangefinders on M0173
voxl-camera-calibration  (0.5.4 to 0.5.5)
0.5.5
    * increase tolerance for extrinsic reprojection error
voxl-camera-server  (1.9.1 to 1.9.4)
1.9.4
    * add C31 camera config
    * fix exif GPS data
    * add exposure max for liow2 TOF to conf
1.9.3
    * add initial m0173 configs
    * enable rotating TOF debug images to portrait mode for starling
    * add max exposure control for TOF
    * enable more framerates for TOF
    * fix TOF setup bugs
    * set LIOW2 TOF to default 10hz
    * tune point cloud processing params for LIOW2
1.9.2
    * fix -C22 for D0013
voxl-configurator  (0.5.6 to 0.6.6)
0.6.6
    *added a -j/--json option to voxl-check-calibration
0.6.5
    * force no RF assistance in flight (px4)
0.6.4
    * support hot swap between E1 and E2
0.6.3
    * update E4 config
0.6.2
    * D0012/D0014 fixes
    * update transmitter list and logic
0.6.1
    * add -X option for lepton
0.6.0
    * add voxl-streamer config customization based on camera config
0.5.9
    * only scan ELRS when necessary
0.5.8
    * start D0012 and D0014
0.5.7
    * enable M0065 experimental mode
    * start D0015 implementation
voxl-elrs  (0.1.3 to 0.2.0)
0.2.0
    * Add M0139 support
    * Update logic/cleanup voxl-elrs script
    * Update voxl-configure-elrs to support 4 PWMs for M0139
    * Fix bug in voxl-configure-elrs default CLI arg usage
    * Add ability to check current PWM config from voxl-configure-elrs
    * Update M0139 firmware to ELRS 3.3.2
    * Update PWM defaults
voxl-esc  (1.4.0 to 1.4.3)
1.4.3
    * improve spinup reliability on Starling 2 Max
1.4.2
    * add misc params for tmotor 2203_5 1500kv with 6042_3 gemfan prop
1.4.1
    * add params for Starling 2
voxl-feature-tracker  (0.3.2 to 0.3.10)
0.3.10
    * Change default features to 30 and change default L/R cam pipes
0.3.9
    * Fix bug with multicam duplicate packets
0.3.8
    * Fix overlay bug
0.3.7
    * Added syncing between camera groups
0.3.6
    * Updates to support new libmodal-cv functionality
0.3.5
    * Fixes for ar144 camera
0.3.4
    * added option to track using the CVP feature tracker
0.3.3
    * add support for using 16-bit images and method to convert to 8-bit based on current and previous images
    * add parameters fast_threshold, min_temp_delta, hgraphy_min_pts
    * relax some parameters related to cornerSubPix and findHomography
    * add updates to timing data
voxl-flow-server  (0.3.3 to 0.3.6)
0.3.6
    * use fixed height of 3m for range in voxl-flow-service.service
    * bug fix - actually use dt for flow vs gyro diff check
    * add feature to use simple relative height difference from start for range
0.3.5
    * Change tracker to voxl-lepton-tracker
0.3.4
    * add support for 16-bit images
voxl-lepton-server  (1.2.0 to 1.2.1)
1.2.1
    * new mode for Lepton on M0173
    * add factory_enable_manual option to voxl-configure-lepton
    * cleanup i2c traffic
voxl-logger  (0.4.0 to 0.4.1)
0.4.1
    * Fixed CP Error Message
voxl-mavcam-manager  (0.5.3 to 0.5.6)
0.5.6
    * fix broken ip autodetect
0.5.5
    * Changed camera names from cameraX to underlying pipe name for easier identification
0.5.4
    * Refactored the code into C++ to more easily support multiple connections each configured via the configuration file
voxl-mavlink-server  (1.4.0 to 1.4.1)
1.4.1
    * bugfix in mission delay feature
voxl-modem  (1.0.9 to 1.1.2)
1.1.2
    * added doodle-cli.sh helper script
1.1.1
    * doodle conf update
1.1.0
    * perf testing scripts
voxl-mpa-to-ros  (0.3.7 to 0.3.8)
0.3.8
    * fix encoded video
voxl-mpa-tools  (1.1.5 to 1.1.6)
1.1.6
    * new extrinsics for d0012 and d0014
voxl-portal  (0.6.5 to 0.6.6)
0.6.6
    * Camera List refreshes every second
    * render tof point clouds other than just "tof"
    * fix tof confidence and intensity buttons
voxl-px4-params  (0.3.8 to 0.4.2)
0.4.2
    * Improved all Starling drone tunes
0.4.1
    * VOXL 2 IO experimental params
    * increase GPS SACC required for position mode
    * update vins params
0.4.0
    * Add helpers for Starling 18650 batteries
0.3.10
    * Changed order of setting EKF2_GPS_CTRL and EKF2_HGT_REF for cases where it will cause an inconsistency
    * Added a set of VOXL 2 default parameters
    * Changed some sleep durations for voxl-px4 restarts
0.3.9
    * initial d0012 and d0014 prarams
voxl-px4  (1.14.0-2.0.68 to 1.14.0-2.0.73)
1.14.0-2.0.73
    * Brought in update GPS drivers submodule with tx packet consolidation
1.14.0-2.0.72
    * Removed set default parameters logic. Will now be done externally
    * Updated dependencies on libfc-sensor and modalai-slpi
1.14.0-2.0.71
    * Added SLPI reset on px4 shutdown
1.14.0-2.0.70
    * Added option to skip Spektrum protocol byte validation
    * Add HDZero OSD driver
    * More voxl-esc cleanups and fixes
    * voxl2_io cleanup and fixes
1.14.0-2.0.69
    * Clean up voxl-esc init code so that version checks are done there and not in main loop
voxl-qvio-server  (1.0.2 to 1.0.4)
1.0.4
    * fix sample vio mask
1.0.3
    * add config option for tracking_front and tracking_down
voxl-tflite-server  (0.3.2 to 0.3.4)
0.3.4
    * Allow YUV422 formatted images to be piped into tflite
0.3.3
    * Fix enabled timing printouts
voxl-utils  (1.3.9 to 1.4.1)
1.4.1
    * added a -j option to inspect services script for json output
1.4.0
    * add platform config to voxl-version
voxl-uvc-server  (0.1.6 to 0.1.7)
0.1.7
    * add standalone option for multiple instances
voxl-vision-hub  (1.7.4 to 1.8.0)
1.8.0
    * Added the lost link backtracking feature with configurable amount of backtracking time
    * add textfile waypoint following feature
voxl-lepton-tracker (Initial Release)
voxl-vtx (Initial Release)
voxl2-io (Initial Release)
SymbolDefinition
YesPassed
In progressIn Progress
FailedFailed
NoNot Supported
ArchitectureDescriptionIndoor Test StatusOutdoor Test Status
D0001m500NoNo
D0003SeekerNoNo
D0004Qualcomm Flight RB5 5G DeprecatedNoNo
D0005-4StarlingYesYes
D0006-4SentinelYesYes
D0011PX4 Autonomy Dev Kit, see: StarlingYesIn progress
D0012Starling 2 Max, see: StarlingYesYes
D0014Starling 2, see: StarlingYesYes
