ROS Installation on VOXL 2
ROS must be installed on both the Host computer and on VOXL. This page guides you through this process.
1. Set up ROS on Host PC
Install
You can use whichever distribution of ROS 1 on your host PC (i.e. ROS Melodic on Ubuntu 18.04). Follow the ROS wiki instructions to install ros-melodic-desktop-full: http://wiki.ros.org/melodic/Installation/Ubuntu
Environment Setup Script
We will set up a my_ros_env.sh script on the host pc:
me@mylaptop:~/$ touch ~/my_ros_env.sh
me@mylaptop:~/$ echo ". ~/my_ros_env.sh" >> ~/.bashrc
Then paste the following into your my_ros_env.sh script. This is where you will edit IP addresses as necessary.
#!/bin/bash
# Script loads ROS envrionment variables and sets IP addresses
# load main ros environment
if [ -f /opt/ros/melodic/setup.bash ]; then
elif [ -f /opt/ros/kinetic/setup.bash ]; then
elif [ -f /opt/ros/indiego/setup.bash ]; then
source /opt/ros/indigo/setup.bash
fi
# if a catkin workspace is setup then make sure the launch
# files and run files are available in the ROS PATH
if [ -f ~/catkin_ws/devel/setup.bash ]; then
source ~/catkin_ws/devel/setup.bash
fi
if [ -f ~/catkin_ws/install/setup.bash ]; then
source ~/catkin_ws/install/setup.bash
fi
# ignore ROS_HOSTNAME, it only causes problems and overrides ROS_IP
unset ROS_HOSTNAME
# configure ROS IPs HERE
export ROS_MASTER_IP=192.168.8.1
export ROS_IP=192.168.8.91
# ROS_MASTER_URI is derived from ROS_MASTER_IP
## bonus alias to ssh into ros master
alias sshh='sshpass -p oelinux123 ssh -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null root@${ROS_MASTER_IP}'
The script above provides an alias ‘sshh’ which allows you to ssh remotely into your VOXL using default credentials. Update ROS_MASTER_IP and ROS_IP to match your network configuration. On your host machine, also be sure to update ROS_MASTER_IP and ROS_IP to match this VOXL IP address.
You will need to install sshpass to use the aforementioned alias.
# ON HOST PC
me@mylaptop:~/$ sudo apt install sshpass
Troubleshooting
Note: Due to SSH environment variable issues using the default terminal, we recommend that users with host Ubuntu machine versions newer than Ubuntu 14.04 use XTerm (not the default terminal) to connect to VOXL via SSH while using ROS.
2. Set up ROS on VOXL 2
Tutorial Video
Install ROS
VOXL 2 can use apt package management, which allows flexibility on what ROS version to install, and allows us to keep the core system image smaller. For these reasons, we leave it up to the end user to select what to install.
To install ROS Melodic (as an example), connect VOXL 2 to the internet (see the WiFi guide for help on this) and run the following:
voxl2:/$ apt-get update
voxl2:/$ apt install -y libyaml-cpp-dev
voxl2:/$ apt install -y ros-melodic-ros-base ros-melodic-image-transport
If you get the error: “Unable to locate package”, add the ros repo and key to apt using the following:
voxl2:/$ sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu $(lsb_release -sc) main" > /etc/apt/sources.list.d/ros-latest.list'
voxl2:/$ sudo apt-key adv --keyserver 'hkp://keyserver.ubuntu.com:80' --recv-key C1CF6E31E6BADE8868B172B4F42ED6FBAB17C654
voxl2:/$ sudo apt update
Launch
Source ROS setup script:
voxl2:~/$ . /opt/ros/melodic/setup.sh
Run the voxl_mpa_to_ros node, which uses this launch file /opt/ros/melodic/share/voxl_mpa_to_ros/launch/voxl_mpa_to_ros.launch
voxl2:~/$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
You should get similar output:
... logging to /home/root/.ros/log/81ccbc5c-34ac-11ed-80c6-00c0caafca29/roslaunch-m0054-2535.log
Press Ctrl-C to interrupt
started roslaunch server http://m0054:45955/
SUMMARY
PARAMETERS
* /rosdistro: melodic
* /rosversion: 1.14.13
NODES
auto-starting new master
process[master]: started with pid [2557]
setting /run_id to 81ccbc5c-34ac-11ed-80c6-00c0caafca29
process[rosout-1]: started with pid [2568]
process[voxl_mpa_to_ros_node-2]: started with pid [2571]
MPA to ROS app is now running
Found new interface: hires
Found new interface: stereo_front
Found new interface: stereo_rear
Found new interface: tracking
Found new interface: imu_apps
Found new interface: voa_pc_out
List Topics
In a new shell, run the following:
voxl2:~$ rostopic list
/hires
/imu_apps
/qvio/odometry
/qvio/pose
/qvio_overlay
/rosout
/rosout_agg
/stereo_front/left
/stereo_front/right
/stereo_rear/left
/stereo_rear/right
/tracking
/voa_pc_out
Next Steps
See the MAVROS test example for VOXL 2.
