ModalAI Electronic Speed Controller (ESC)
Documentation for ModalAI's high-performance, closed-loop Electronic Speed Controllers (ESCs) that use a digital interface (UART, i2c in future).
ModalAI’s Electronic Speed Controllers (ESCs) are high-performing, closed-loop speed controllers that use a digital interface (UART, i2c in future).
Brief Overview
Brushless Electronic Speed Controllers (ESCs) are devices that consist of hardware and software for controlling three-phase brushless DC (BLDC) motors. ESCs communicate with the flight controller, which instructs the ESCs how fast the motor should spin.
ModalAI’s ESCs implement the following advanced features:
  • Full integration with ModalAI VOXL and Flight Core PCBs
  • Bi-directional UART communication with checksum; status and fault monitoring
  • Real-time status and health reporting at high update rate (100Hz+ each)
  • Closed-loop RPM control for best flight performance
  • LED control from flight controller via UART
Feature Comparison
M0129
M0134
M0138
M0129 top and bottom
M0134 top and bottom
M0138 top and bottom
FeatureModalAI 4-in-1 ESC (M0129)ModalAI 4-in-1 ESC (M0134)ModalAI 4-in-1 ESC (M0138)
Nominal Input Voltage6.0V-16.8V (2-4S Lipo)6.0V-16.8V (2-4S Lipo)6.0V-26V (2-6S Lipo)
  6.0V-25.2V (2-6S Lipo) (M0134-6)
VOXL Power Output3.8V or 5.0V @ 5A (6A 30 sec)❌5.0V or 3.8V @ 6A
Aux Power Output1x 3.3V / 5.0V 500mA1x 5.0V 500mA1x 3.3V/5.0V 500mA, 1x 16.8V 500mA
Max Continuous Current Per Motor20A (thermally limited, requires airflow)20A (thermally limited, requires airflow)40A (thermally limited, requires airflow)
Max Burst Current Per Motor30-40A for <1s40-50A for <1s100A for <1s
MCUSTM32F051K86STM32F051K86STM32F051K86
MOSFET DriverMP6531AMP6530 (M0134-1)MP6531A
  MP6531A (M0134-3, M0134-6)
MOSFETsAON7528 (N)AON7528 (N)TBD
Current Sensing1x 0.5mOhm + INA186 (-20A..+110A)4x 0.5mOhm + INA186 (-10A..+55A)1x 0.25mOhm + INA186 (-35A..+200A)
ESD signal protection✅✅✅
Temperature Sensing✅ (internal to MCU)✅ (internal to MCU)✅ (internal to MCU + top and bottom)
On-board Status LEDs✅ 4x✅ 4x✅ 4x
External LEDs1x Neopixel LED output2x Neopixel LED outputs1x Neopixel LED output
Secure BootloaderYes (AES256)Yes (AES256)Yes (AES256)
Motor PWM Switching Frequency48, 24 Khz48, 24 Khz48, 24 Khz
Maximum RPM (6 pole pairs)50K+50K+50K+
PWM control input (1-2ms)✅✅❌
PWM output✅ 4x (shared with PWM input)✅ 4x (shared with PWM input)✅ 2x
Active Freewheeling✅✅✅
Disable Regenerative BrakingAlways enabledAlways enabled (M0134-1)✅ Option to disable
  ✅ Option to disable (M0134-3, M0134-6)
Tone Generation✅✅✅
Closed-loop RPM ControlYes (10Khz)Yes (10Khz)Yes (10Khz)
Number of UART ports2 (2Mbit+)2 (2Mbit+)1 (2Mbit+)
voxl_esc UART Protocol✅✅✅
UART connector typeJST GH 4-pinHirose DF13 6-pinJST GH 4-pin
UART Cable (for VOXL2)mcbl-00015mcbl-00029mcbl-00015
Weight without wires (g)5.99.517.9
Board Dimensions (mm)36.5 x 36.540.5 x 40.545.5 x 59.0
Mounting Hole Size, Pattern (mm)2.5, 30.5 x 30.53.05, 31.0 x 33.03.05, 30.5 x 30.5
Notes
Mechanical Drawings
PCB3D STEP
M00493D STEP
M01173D STEP
M01343D STEP
M01293D STEP
M01383D STEP
Other ESCs
M0049
M0049 top and bottom
M0117
M0117 top and bottom
FeatureModalAI 4-in-1 ESC (M0049)ModalAI 4-in-1 ESC (M0117)
Aux Power Output1x 4.5V, 1x 5.0V (adj) 600mA each1x 5.0V (adjustable) 600mA
Max Continuous Current Per Motor20A (thermally limited)20A (thermally limited)
Max Burst Current Per Motor40-50A (requires airflow and heat-spreader)40-50A (requires airflow and heat-spreader)
MCUSTM32F051K86STM32F051C6U6
MOSFET DriverMP6530MP6530 (M0117-1)
  MP6531A (M0117-3)
Individual Current Sensing4x 1mOhm + INA1864x 0.5mOhm + INA186
Temperature Sensing✅✅
On-board Status LEDs✅✅
External LEDsNeopixel LEDsN/A
PWM control input✅✅
Disable Regenerative Braking❌ Always enabled❌ Always enabled (M0117-1)
  ✅ (M0117-3)
Tone Generation✅✅
Weight without wires (g)9.59.5
Board Dimensions (mm)40.5 x 40.540.5 x 40.5
Mounting Hole Size, Pattern (mm)3.05, 31.0 x 33.03.05, 31.0 x 33.0
Noteslimited availabilitylimited availability
VOXL 4-in-1 ESC Datasheet
M0117 4-in-1 UART ESC: specifications, connectors, and pinouts.
M0129 and M0134 mini 4-in-1 ESCs for vehicles under 750 g: specifications and pinouts.
VOXL FPV ESC 4-in-1 Datasheet
M0138 high-current 4-in-1 ESC for FPV racing applications: specifications and pinouts.
Manual
VOXL ESC Tools: test, calibrate, flash, and diagnose ESCs from a PC or from VOXL.
VOXL ESC Calibration
Calibrate ModalAI ESCs for closed-loop RPM control - safely
PX4 Integration
Configure PX4 on VOXL 2, VOXL Flight, or Flight Core to drive VOXL UART ESCs.
VOXL ESC FAQ
Common questions about ESC variants, wiring, firmware, and troubleshooting.
