Microhard Add-on Datasheet
VOXL expansion board for Microhard pDDL modules: connectors, power, and mechanicals.
This expansion board plugs directly into VOXL and supports pDDL modules from Microhard (not included).
Once a module is installed and connected to VOXL, this unit can be paired with the ModalAI Microhard USB Dongle.
Manual
  1. Specification
    1. Block Diagram
    2. Part Numbers
    3. Physical Specification
    4. Power Consumption
  2. Board Connections and I/O
    1. Top of Board
    2. Bottom of Board
    3. USB Connections
    4. LEDs
    5. CFG Switch
  3. Configuration
    1. Slave Configuration
  4. Connector Pinouts
    1. J4 - USB Port 3
    2. J5 - USB Port 4
  5. Mechanical Drawings
    1. 2D Drawings
    2. 3D Drawings
  6. Additional Pictures
    1. Disassembled
    2. Assembled with VOXL
Specification
Block Diagram
View in fullsize
Part Numbers
Part NumberSilkscreen MarkingDescription
MDK-M0048-1-01M0048 REV AMoved to LAN7500 ethernet controller for better compatibility with Android
VOXL-ACC-MH-1M0012 REV AInitial Release
SpecicifcationValue
Weight12g
Dimensions49 x 40mm
Antenna Connector?? UFL-R-SMT-110
Recommend Antennas
Debug Console Connector?? SM04B-SRSS-TBLFSN
Debug Console Matimg Connector?? SHR-04V-S-B
USB2 Client Connectors4 Position JST GH, Vertical, BM04B-GHS-TBT
USB2 Client Mating ConnectorJST GHR-04V-S
J1 Connector (bottom of board)Samtec Inc, MPN: QTH-030-01-F-D-K
J1 Mating ConnectorSamtec Inc., MPN: QSH-030-01-L-D-A-K
Power Consumption
M0048 Configuration5V Power Consumption (mA)
Baseline (USB Hub, Glue Logic, All LEDs ON)315
Baseline plus Qty-2 USB Peripherals at Max 500mA*1375
Baseline + Qty-2 DS USB* + Microhard 900MHz @ 10dBm2800
Baseline + Qty-2 DS USB* + Microhard 900MHz @ 30dBm3700
Baseline + Qty-2 DS USB* + Microhard 2400MHz @ 10dBm2500
Baseline + Qty-2 DS USB* + Microhard 2400MHz @ 30dBm3100
Top of Board
Bottom of Board
USB Connections
You can connect up to two USB-clients to the USB2 Host ports on the top of the board. A MCBL-00009 cable can be used, this is a 4-pin JST to USB Female Type A cable.
You can connect the carrier board to a host computer using the USB port on the bottom of the baord. Connect to a host comptuter with MCBL-00010, which is a 4-pin JST to microUSB female cable.
LEDs
IndexLEDDescription
1TXFlashes GREEN indicating wireless TX traffic
2RXFlashes GREEN indicating wireless RX traffic
3RSSI-3Flashes GREEN to indicate the Received Signal Strength on the wireless link
4RSSI-2Flashes GREEN to indicate the Received Signal Strength on the wireless link
5RSSI-1Flashes GREEN to indicate the Received Signal Strength on the wireless link
6CPUSolid GREENindicates power to module and normal operation, flashing indicates boot or FW upgrade status
7LANCan be programmed to flash GREEN to indicate MH Link to the Ethernet Controller on board
8LAN/100Used in conjunction with 9. Can be programmed to flash GREEN to indicate Link and Speed or Link and Speed and Activity
9LAN/ACTUsed in conjunction with 8. Can be programmed to flash GREEN to indicate Link and Speed or Link and Speed and Activity
105VIlluminates solid GREEN indicating 5VDC USB bus power enabled
11Port3Illuminates solid GREEN indicating Port 3 USB power enabled
12Port4Illuminates solid GREEN indicating Port 4 USB power enabled
Index 8 and 9 (LED LAN/100 and LED LAN/ACT ) config options.
Index 8 (LAN/100) config flags
SPD_LED_FUNCTIONSpeed (Mbps)Index 8 (LAN/100)
0No LinkOFF
010OFF
0100Flashes
01000Flashes
1No LinkOFF
110OFF
1100BLINK
1100BLINK
Index 9 (LAN/ACT) config flags
LED_2_FUNCTIONIndex 9 (LAN/ACT)
0Link and Activity LED
1Activity LED
CFG Switch
Can be used to reset all settings to default values required for a Slave module.
Configuration
Slave Configuration
To reset all settings to the default values required for a Slave module, press and hold the CFG Button, once the CPU LED begins to flash, continue to hold for 5 seconds, then release.
The module will then reset all settings to the default values required for a Slave module
Connector Pinouts
J4 - USB Port 3
  • Connector - 4 Position JST GH, Vertical, BM04B-GHS-TBT
  • Mating Connector - JST GHR-04V-S
PinDescription
15VDC (500mA max)
2D-
3D+
4GND
J5 - USB Port 4
PinDescription
15VDC (500mA max)
2D-
3D+
4GND
Mechanical Drawings
2D Drawings
3D Drawings
M0048_MICROHARD_WITH_SOCKET_LAN7500.stp
Note: These 3D files contain all components on them. Some board configurations do not install “DNI” certain connectors or components. Please refer to the included diagrams and design schematics for more detailed information
Additional Pictures
Disassembled
Assembled with VOXL
