Flight Core v2 Firmware
  1. Release Notes
    1. PX4 v1.14
  2. General User Guide
    1. QGroundControl FW Update
    2. How to Upgrade using px_uploader Tool
  3. Developer Guide
    1. v1.14+ PX4 Support
    2. Mainline PX4 Support
    3. ArduPilot Support
    4. Tools for Flashing
    5. How to Build PX4 Application
      1. How to Flash PX4 Bootloader with ST32CubeProgrammer
    6. Bootloader
      1. How to Build PX4 Bootloader
      2. How to Flash PX4 Bootloader with ST32CubeProgrammer
Release Notes
PX4 v1.14
Starting with PX4 1.14, our flight core and VOXL2-SDSP PX4 firmwares are now built from the same repo. The flight Core V2 firmware can be found here: http://voxl-packages.modalai.com/dists/fc-v2/
The SDK-* folder contains the PX4 firmware that’s tested with SDK-* running on VOXL.
Make sure you upgrade your flight core firmware with the file included in the voxl_SDK_*1.1.0.tar.gz SDK installer. The SDK install script will only flash VOXL, you will need to follow the instructions below to flash the flight core.
General User Guide
The FW update feature in QGC via USB requires QGC 4.3.0 and later.
Alternatively, to update the firmware, you can use the px_uploader tool.
This has been tested on OSX 13.1, Ubuntu 18.04, and Ubuntu 22.04 with success to update firmware over USB.
  • Ensure you have Python 3 and pyserial module installed (pip3 install pyserial)
  • Follow build guide below, or download the firmware from links above in release notes (e.g. modalai_fc-v2_default.px4)
  • Obtain the PX4 open source community tool (not a ModalAI tool):
git clone -b voxl-dev https://github.com/modalai/px4-firmware.git --recursive
cd px4-firmware
  • Exit QGC if running
  • Disconnect Flight Core v2 from USB
  • Run the following (note: your USB device name may be different and your path may be different, Linux default is /dev/ttyACM1, OSX default is /dev/cu.usbmodem01)
./Tools/px_uploader.py --port /dev/ttyACM1 modalai_fc-v2_default.px4 --baud-bootloader 1152000
  • Connect Flight Core v2 over USB (note, no external power needed)
  • Flight Core v2 boots into bootloader mode
  • The update should now begin
Developer Guide
v1.14+ PX4 Support
ModalAI makes some mods to mainline and maintains a branch here that is shipped on the product by default.
ArduPilot Support
ModalAI’s Flight Core 2 is integrated into ArduPilot by the great ArduPilot community. The engineers at ModalAI do not have experience with ArduPilot, so can not offer significant support. It is recommended to find support through the normal ArduPilot channels (boards & Discord). Hopefully ModalAI will gain experience with ArduPilot in the future.
ArduPilot pull request for ModalAI Flight Core v2 base hardware support Github
ArduPilot pull request for VOXL-compatible Visual Inertial Odometry support Github
Tools for Flashing
Recommended hardware: similar to STLink v2 or equivalent. Please install STM32CubeProgrammer to get the STM32_Programmer_CLI binary.
It is recommended to install voxl-docker on your host machine before building, instructions can be found here.
cd px4-firmware
voxl-docker -i px4io/px4-dev-nuttx-focal:2022-08-12
make modalai_fc-v2
After building, the bootloader binary is located at:
build/modalai_fc-v2_default/modalai_fc-v2_default.bin
The application is flashed at 0x08020000:
echo "programming application..."
STM32_Programmer_CLI -c port=SWD -w modalai_fc-v2_default.bin 0x08020000 -v
Bootloader
The bootloader is flashed at the factor and generally you do not need to build or flash it. But, if you want to customize the bootloader, the following can be used.
cd px4-firmware
make modalai_fc-v2_bootloader
build/modalai_fc-v2_bootloader/modalai_fc-v2_bootloader.bin
The bootloader is flashed at 0x08000000:
echo "erasing..."
STM32_Programmer_CLI -c port=SWD -e all
echo "programming bootloader..."
STM32_Programmer_CLI -c port=SWD -w modalai_fc-v2_bootloader.bin 0x08000000 -v
