Flight Core v2 Actuators
Hardware
ModalAI UART ESC
UART5 is exposed on J5
, which is mapped to TELEM2
in PX4 and available to Nuttx as /dev/ttyS4
This is the default port used by the ModalAI UART ESC Driver when enabled.
PLEASE NOTE in 1.13.2-0.1.1
and older, the recommended port is J1. It was changed to J5 starting 1.13.2-0.1.2
and newer.
Recommended is MCBL-00063 (6p JST ModalAI UART ESC Cable) for this interface.
Flight Core v2 J5
Pin # | Signal Name |
1 | NC |
2 | Flight Core v2 Tx, 3P3V (connect to ESC Rx) |
2 | Flight Core v2 Rx, 3P3V (connect to ESC Tx) |
4 | NC |
5 | NC |
6 | GND |
ModalAI ESC J2
M0049 based hardware J2
1 | NC |
2 | ESC Rx |
2 | ESC Tx |
4 | NC |
5 | GND |
6 | NC |
PWM/DShot
8 PWM channels exposed on J7
1 | 5VDC (other pins are 3.3V, input or output if supplied at another pin) |
2 | PWM_CH1 |
3 | PWM_CH2 |
4 | PWM_CH3 |
5 | PWM_CH4 |
6 | PWM_CH5 |
7 | PWM_CH6 |
8 | PWM_CH7 |
9 | PWM_CH8 |
10 | GND |
Software
ModalAI UART ESC Driver Source
An open source PX4 driver is available at src/drivers/actuators/modalai_esc.
PWM/DShot
Standard PX4 drivers used.
