Introduction
A large share of the ModalAI software stack is written in C/C++ and so if you intend to develop applications for VOXL there’s a decent chance you’ll need to use the language. However, C/C++ is a complicated language with a very dated build system, and as such editors like VSCode can struggle to understand these projects out of the box leading to a ton of red squiggles and errors while trying to work on the project. In addition to being visually distracting, this also massively limits the functionality of these modern IDEs: features like code completion function lookup/referencing will all mostly struggle to work. In this document, I’ll outline the main ways you can set up a development environment for C/C++ to make working with the VOXL SDK a breeze.
Setup
Start by downloading VSCode from their downloads page. Also make sure to install the Dev Containers and C/C++ extensions as both will be needed to get the environment set up correctly. Also make sure to set up voxl-cross so that you’ll have the container to build in.
Process
- Open a terminal and launch the
voxl-crosscontainer usingvoxl-docker -i voxl-cross. Make sure to launch this in a directory above or at the project you intend to work on (e.g. don’t runt his command in~/git/voxl-portal/srcif you intend to work on~/git/voxl-portal/). - Open VSCode and
CTRL+Shift+Pto open and find the optionDev Containers: Attach to Running Container.... This will prompt you to pick a running container, you should pick the one corresponding to thevoxl-crossinstance you just spun up. From here you can useFile > Open Folderto open up the project you want to work on. - Open up
CMakeLists.txtat the root of the project you’re working on and look for the lineset(CMAKE_EXPORT_COMPILE_COMMANDS ON). If it isn’t already in theCMakeLists.txtfile, add it! This line generates a.jsonfile that tells theC/C++extension how to interpret our project. - Go back to the terminal with
voxl-crossin it and navigate to your project. Then run./clean.sh,./install_build_deps.sh qrb5165 devand finally./build.sh. Now check thebuild64directory that was created in your project. Inside there should be a file calledcompile_commands.json. - At the root of your project, run
mkdir .vscode && cd .vscode && touch c_cpp_properties.json, then open thisc_cpp_properties.jsonfile. Paste the following content:{ "configurations": [ { "name": "Linux", "compileCommands": "${workspaceFolder}/build64/compile_commands.json", "cStandard": "c11", "cppStandard": "c++17", "intelliSenseMode": "clang-x64" } ], "version": 4 }
And you should be set! A few things to keep in mind:
- Every time you shut down
voxl-crossand restart it, you’ll need to re-run the./install_build_deps qrb5165 devcommand to re-install the build dependencies for the project - These setup steps only apply to this project. If you go to another project you’ll need to do the same process as above. Fortunately you can just copy your
.vscodedir around for easier access. - If you change to a 32-bit build system the link to the compile commands file may change. The command
find . -name "compile_commands.json"can help you get the right path to that file so you can update yourc_cpp_properties.json.
