Qualcomm Flight RB5 SDK Camera Server
rb5-camera-server
The rb5-camera-server
allows you to publish data from any of the 6 cameras on the platform.
Camera Information
ID | Summary | Usage | Sensor | Pipeline |
0 | Front Stereo, Left | VOA (front) | ov7251 | 640x480, Bayer B&W 10bit, 30 FPS, hw synced with 1 |
1 | Front Stereo, Right | VOA (front) | ov7251, master | 640x480, Bayer B&W 10bit, 30 FPS, hw synced with 0 |
2 | Front Tracking | VIO (front) | ov7251 | 640x480, Bayer B&W 10bit, 30 FPS |
3 | Front Hi-res | FPV (front) | IMX214 | 4208x3120 (4k), Bayer RGGB 10bit, 30 FPS |
4 | Rear Stereo, Left | VOA (rear) | ov7251 | 640x480, Bayer B&W 10bit, 30 FPS, hw synced with 5 |
5 | Rear Stereo, Right | VOA (rear) | ov7251, master | 640x480, Bayer B&W 10bit, 30 FPS, hw synced with 4 |
Architecture
In summary, this is what’s happening:
Image Sensor
--> Kernel
--> CameraX/GST
--> rb5-camera-server
--> a named pipe getting frames
--> code reading from named pipe doing stuff
How to Build and Install
If you have a Qualcomm Flight RB5
, it comes pre-loaded with the software and there’s no need to re-install unless you want to. If you want to see the source, build and tweak it, the repo is COMING-SOON.
How to Use
Configure to Run on Bootup
Generally, we want to have the computer vision processing start up on bootup. On the Qualcomm Flight RB5
, that’s the default setup for camera IDs 0, 1, 2, 4 and 5 (the core computer vision sensors)
package installs with a configuration script. You can run the following after you adb onto the target.
- adb onto target
adb shell
sh-4.4#
- Enable the default computer vision cameras (0, 1, 2, 4, 5) to start on bootup by selecting
1) yes
sh-4.4# rb5-camera-server-configure
Would you like to enable the camera service?
This will start all cameras in a background process
1) yes
2) no
#? 1
View Service Status
We use a ‘templated’ systemd unit file…. so the services show up a little different:
0 | Front Stereo, Left | systemctl status rb5-camera-server@0 |
1 | Front Stereo, Right | systemctl status rb5-camera-server@1 |
2 | Front Tracking | systemctl status rb5-camera-server@2 |
3 | Front Hi-res | not started by default, used upon request for FPV stream |
4 | Rear Stereo, Left | systemctl status rb5-camera-server@4 |
5 | Rear Stereo, Right | systemctl status rb5-camera-server@5 |
For example, camera 0 after successfully starting:
sh-4.4# systemctl status rb5-camera-server@0
● rb5-camera-server@0.service - "rb5-camera-server-0"
Loaded: loaded (/usr/bin/rb5-camera-server; indirect; vendor preset: enabled)
Active: active (running) since Mon 2021-07-26 16:28:00 UTC; 15s ago
Main PID: 9522 (rb5-camera-serv)
Tasks: 4 (limit: 4915)
CGroup: /system.slice/system-rb5\x2dcamera\x2dserver.slice/rb5-camera-server@
└─9522 /usr/bin/rb5-camera-server -c0
Jul 26 16:28:00 qrb5165-rb5 systemd[1]: Started "rb5-camera-server-0".
Jul 26 16:28:00 qrb5165-rb5 rb5-camera-server[9522]: gbm_create_device(156): Inf
Use a Provided Test Client
If you want to test a camera, for example camera ID 5, run the following:
sh-4.4# rb5-camera-client -c 0
camera ID is set to 0
Waiting for server to start: /dev/rb5-camera-pipe-0
View Named Pipes in File System
The interface the rb5-camera-server
provides are named pipes where you can read camera frames and meta data from.
sh-4.4# ls -la /dev/rb5-camera*
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-0
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-1
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-2
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-4
prw-r--r-- 1 root root 0 Jul 26 15:45 /dev/rb5-camera-pipe-5
How to Change What Cameras Are Started on Bootup
Currently, the camera’s initialization setup is handled here:
/usr/bin/rb5-camera-server-configure
You’ll find usage like below, where you can enable/disable by ID:
# enables service which starts all cameras
enable_service () {
echo "reloading systemd services"
systemctl daemon-reload
echo "enabling /starting rb5-camera-server systemd service"
# front tracking
systemctl enable rb5-camera-server@2.service
systemctl restart rb5-camera-server@2.service
