SSH to VOXL
Instructions
If your host computer is on the same network as the VOXL, you can SSH into it.
If the VOXL is setup as a Soft AP, the IP address is 192.168.8.1
, otherwise you’ll need to find it’s IP address with ifconfig
as described in the previous step.
me@mylaptop:~$ ssh root@192.168.8.1
(password: oelinux123)
Later, in the ROS Host PC Setup Instructions, you will configure an alias to speed up the ssh process.
Known Running ROS Through SSH
The cause is a known issue with the Ubuntu terminal emulator. The solution is to use another terminal emulator such as xterm instead of Ubuntu’s default terminal.
Next Steps
Next, we can Install and Upgrade Software.
