VOXL FLIR Server
  1. Overview
  2. Installation
  3. Running voxl-flir-server
  4. Configuring voxl-streamer to work with voxl-flir-server
  5. Source
voxl-flir-server is an application to send video frames from the FLIR Lepton SPI camera to Modal Pipe Architecture (MPA) pipes. This server is used in conjunction with voxl-streamer. For Flir UVC enabled cameras with USB interfaces such as the Boson 640 and PureThermal Mini Pro with Lepton use voxl-uvc-server instead.
Installation
voxl-flir-server is installed via ipk package. It is currently only available as a dev package.
yocto:/home/root/ipk# voxl-configure-opkg dev
yocto:/home/root/ipk# opkg update
yocto:/home/root/ipk# opkg install voxl-flir-server
voxl-flir-server is a command line application and can be started on the command line:
yocto:/home/root# voxl-flir-server
Use the -h option to view online help:
yocto:/home/root# voxl-flir-server -h
Usage: voxl-flir-server <options>
Options:
-d                Show extra debug messages.
-v                Show extra MPA debug messages.
-h                Show help.
The voxl-streamer configuration file /etc/modalai/voxl-streamer.conf needs to have a configuration record for the FLIR Lepton:
"flir": {
    "input": {
        "interface": "mpa",
        "mpa-camera": "flir" },
    "output": {
        "stream": {
            "rotation": 0,
            "width": 160,
            "height": 120,
            "bitrate": 1000000 } }
Then run voxl-streamer with this record using voxl-streamer -c flir
Source
Source code is here.
